Engine noise in speakers
Okay... I've posted on this before and I thought I had it licked.. but apparently not.
I'm running my power down the right hand side of the driver's side floorboard. The RCA cables and speaker cables run down the left side of the driver's side in the wiring conduit. The ground is under 18" and connected to bare metal. I'm still getting the occasional whine out of my speakers... is there some high current in the conduit? I tried a noise suppressor and it didn't work. I would've posted this in the audio section but I'm looking for 5th gen specific info.
I had the same bad ground loop issue on my last car (Integra) - from multiple amps and other components. I bought a Phoenix Gold terminal block that all ground cables from the components attached to, then from the block one cable to the chassis (to bare metal). I bought hi-gauge cable with hi-quality wires (from a boat shop, by the foot). For all connection points, I used that conductive compound used for battery terminals. It did the trick.
I might suggest as far away from other wires/connections as possible. A super-good connection is key. I'm not sure of the area you are working in, but keep experimenting, or purchase some type of fancy grounding apparatus.
Sorry, I missed your first post regarding the problem. My understanding is that you have sort of custom amplifier somwhere in the rear side of the car and you need to wire it to power supply/speakers/some sort of low audio signal output. I think, the most clean ground is on the battery itself. The most honest way to do grounding would be to dedicate separate isolated high current wire (the same as for "+") for the "-" amplifier power connector and twist it to "+" wire - to minimize magnetic noise from amplifire power consumption itself. Then I'd suggest to put input wires in parallel with theese power ones, I mean - put it near along the same route, but don't twist to anything! Speakers wires should go directly to each speaker without using car body as one of the wires, twisted in pairs, along any possible route. BTW, many of the modern amplifiers have their ouputs isolated from ground. I'd connect the "-" power wire as close to battery as possible with one condition - there shouldn't be any significant current consumer between that point and front radio ground wire, I'd suggest to connect them in one point to battery "-". That way you should be able to avoid any ground noises. Probably too academic, but should work. General idea is to reduce the square between power ground and signal ground and also to eliminate noises from the body of the car.
Try This
try some of these...
1) try grounding the amps to same ground point as the receiver.
2) Disconnect antenna. If noise goes away, then buy an antenna noise filter.
3) (Power off) disconnect rca's from amp. Insert shorting plug (RCA plug with center pin connected to outside shielding) into amp's input jacks. If whine goes away, re-route rca cables. You may also want to try different rca cables...some are better shielded than others.
4) (power off) Disconnect speakers from amp. (Power On) If whine is still present, then re-route speaker wires.
5) Reroute power line away from center of the car but away from rca's and speaker wire.
6) Use thicker ground wire... equal to or thicker than the power wire.
good luck
good luck
here's a good flow chart
here's a good flow chart to diagnose and supress noise
http://www.crutchfield.com/infolib/S...sp?id=nonoise&
hope this helps!
I had the same problem and the same wire routing as you, but mine comes from the way I have the amps mounted. I will be repositioning them soon, and my noise will go away, but the damn whine is a pain in the ****!
Good luck.
hope this helps!
Good luck.
Re: here's a good flow chart
hope this helps!
Good luck.
hope this helps!
Good luck.
Mine is being caused where the power wire and RCS's come back together near the amp. I had them come in from opposite sides as much as possible and that god rid of most of it. It took me about a week to figure this one out and it was really ****ing me off. I can really sympathize with you.
hez8813
03-12-2020 12:06 AM
ballerchris510
09-11-2015 05:29 PM
