Important Thread Links!!!!!!!!!!!!!
The DIY threads
DIY headgasket
http://forums.maxima.org/oldthread.php?t=272031
Pathfinder TB
http://forums.maxima.org/oldthread.p...ght=pathfinder
SAFC II install
http://forums.maxima.org/oldthread.php?t=186503
SAFC settings
INTIAL SETUP SETTINGS
http://forums.maxima.org/oldthread.php?threadid=13458
SAFC settings for SCed 10PSI plus MEVI stock injectors
http://forums.maxima.org/oldthread.php?t=251643
removal of inline fuel pump
http://forums.maxima.org/oldthread.php?t=254243
temporary removal of SCer
http://forums.maxima.org/oldthread.php?t=254510
Homade Race Gas
http://forums.maxima.org/oldthread.php?t=329403
Install A Turbo Timer on a 4th gen
http://forums.maxima.org/oldthread.php?t=289898
ANTISTALL settings for EMANAGE
http://forums.maxima.org/oldthread.p...=1#post3243333
How to WIRE up the Z32 MAF
http://forums.maxima.org/oldthread.php?t=342180
http://forums.maxima.org/oldthread.php?t=351427
Alcohol/Meth/water Injection Thanks Slimer
http://members.***.net/stevemonroe/AlcoholInjMod.html
http://www.coolingmist.com/
http://snowperformance.net/
http://www.aquamist.co.uk/
http://www.alkycontrol.com/
Fuel Injector Threads
370 CC injector threads
http://forums.maxima.org/oldthread.p...300Z+injectors
http://forums.maxima.org/oldthread.php?t=341748
Injector Color Thread
http://forums.maxima.org/oldthread.php?t=263461
JWT SC ECU program
http://forums.maxima.org/oldthread.php?t=222514
JWT ECU, 370s, Z32 maf
http://forums.maxima.org/oldthread.php?t=253571
555CC Discussions
http://forums.maxima.org/oldthread.php?t=284822
Injector Seal Part Numbers
http://forums.maxima.org/oldthread.php?t=261982
Fuel Rail Modification
http://forums.maxima.org/oldthread.php?t=373297
Flywheel and Straight Pipe discussions
flywheel and boost discussion
http://forums.maxima.org/oldthread.php?t=255588
straight pipe or aftermarket cat
http://forums.maxima.org/oldthread.php?t=250988
Gapping of spark plugs discussion
http://forums.maxima.org/oldthread.php?t=296896
SAFC II article
http://www.prostreetonline.com/pso/p...p?articleid=33
Pre-Ignition and Detonation Basics
http://forums.maxima.org/oldthread.php?t=329405
Adjusting the Cartech fmu
http://forums.maxima.org/oldthread.p...25#post3312225
Compressor maps
http://forums.maxima.org/oldthread.php?t=350109
http://forums.maxima.org/oldthread.php?t=351021
GM MAP sensor info
http://forums.maxima.org/oldthread.php?t=397645
O2 Clamp for "lean tip-in"
http://forums.maxima.org/oldthread.php?t=402912
Autotune for eManage WB02 users
http://forums.maxima.org/oldthread.php?t=402843
Tuning with EGT
http://www.sdsefi.com/techegt.htm
Credit goes to Jay25 who already had all of this in different stickies. I just put it all in one place.
DIY headgasket
Pathfinder TB
SAFC II install
SAFC settings
Homade Race Gas
JWT SC ECU program
555CC Discussions
SAFC II article
Compressor maps
GM MAP sensor info
Tuning with EGT
Kyle Lee Cleveland
09-28-2015 09:01 PM
rbaker100
09-25-2015 07:52 PM
