Does 97 headlight fit in 95?
Old 01-30-2001, 05:05 PM
SupaC
I have 95 Max GLE, but i don't like the 95 headlights.
I want to put 97 headlight( the whole headlight casing of 97) in my car. But does it fit?
has anyone tried this?
also, i want to buy new bulbs, which ones are good?
i know PIAA is good but too expensive and i heard about other hyper white bulbs but ppl say that they don't last long (about 3 months).
what bulbs last long and looks good??
thanx
Old 01-30-2001, 05:23 PM
BrianV's Avatar
I think you need to swap out the bumper and grille at the same time. It's a different shape as well as a different inside design.
BrianV is offline
Old 01-30-2001, 05:25 PM
ny96max's Avatar
I was in the same situation as you. I had the stock 96 headlights with my Piaa 9004 super whites and they looked ok. I bought my new 97 headlights from EMAX95 and used the same Piaa bulbs in them and let me tell you, they are the closest to HID as your gonna get for the max. I tried every "super white bulb" out there APC, Eurolite, etc... they look good with that blueish tint to them, but they dont compare to the PIAA's. And because the lenses on the 97-99 headlights is one solid piece and not rippled looking like on the 95-96 the light is much clearer and more defined looking. I think they look brighter too. I also had to re-aim the headlights a few times to get them where i wanted them. That was the biggest pain but i got it finally.
As for the fittment, there was one thing that didnt line up exactly. When you remove the corner lense next to the headlight you will see x2 10mm bolts. The holes that are drilled out for them didnt line up with my 97 headlights, so i got my drill and a drilled the hole out to make everything line up. The rest of the bolts line up exactly.
I had my stock 96 grille on for a bit after the swap but then bought the SMX grille and still fits perfectly fine, no problems!!
E-mail me if you have any questions about the install.
[Edited by ny96maxse on 01-30-2001 at 07:27 PM]
ny96max is offline
Old 01-30-2001, 05:26 PM
gtr_rider's Avatar
HEy Brian.....
I think you could just put the 97's in with the regular 95 grill.
gtr_rider is offline
Old 01-30-2001, 05:28 PM
BrianV's Avatar
Yeah I'm not positive, but I'm just recalling what I thought I read about this stuff before. However, it does looks like our bumpers are shaped different, and the lights are slightly different in shape.
BrianV is offline
Old 01-30-2001, 06:29 PM
need4pwr's Avatar
It does fit
My sister has a 95 maxima se. well i got a set of the 97 maxima headlights for her car and the 97 corner lights. the headlight does fit with the stock light bracket for the 95 maxima. she still has the same grille (1995) and the same bumper. the only problem i ran into was that i had to keep the 95 wiring harness for the 97 corners cuz in the 95 the light stays on when you put the blinker on.
so in short, the 97 headlights do fit in the 95 maxima, but i would also do the 97 corner lights to match.
need4pwr is offline
Old 01-30-2001, 07:11 PM
clee130's Avatar
Since most ppl answered about the headlights, I'll answer about the bulbs
Try looking into some Philips Blue Visions. Real bright and at a fraction of the cost of PIAA's. They can be found at the local K-Mart, Pep Boys, AutoZone or the like. I changed from stock to imitation HID blue headlights. Looked cool but couldn't see crap when it rained. Now, it's much better. Use the search and read up about them. There was a huge long discussion and comparision about them a while back.
Good luck.
thanx
clee130 is offline
Old 01-30-2001, 10:13 PM
SupaC
Thanx Guys~
thanks for the info
Where should i buy the headlights from?
e-bay? i found one on e-bay. the price is $51.00 right now.
how much are they if u get them from nissan dealers?
does anyone know?
well, i guess i can just fit that on my car when i get them.. but ny96maxse said holes need to be drilled unlike the other guys said.
any other extra info would be appreciated.
Old 01-30-2001, 11:02 PM
Turtle turtle... Moderator
Turbo95Max's Avatar
hey
i have a 95 Max and i swapped 97 headlights into my Max. I had no probs with any bolts lining up except the harness for my corner lights cause i got the 97 ones to match. If you juss do straight headlight swap you should have you prob...
Turbo95Max is offline
Old 02-03-2002, 02:06 PM
Justin95SE's Avatar
how much did this cost you guys? nm
nm
Justin95SE is offline
Old 02-03-2002, 02:19 PM
gtr_rider's Avatar
To think, I still remember this post!
Old 02-03-2002, 08:12 PM
clee130's Avatar
I almost had a heart attack from the title of the thread.
Good thing I check the date of the posts.
clee130 is offline
Old 02-03-2002, 08:27 PM
Sports Button FTW
meccanoble's Avatar
all this info helped a lot but
ok, all that is fine and dandy, and i'll take it the SE model is just the same as GLE right?
meccanoble is offline
Old 02-03-2002, 08:46 PM
garbear's Avatar
headlights
thanx
Well I know that a 97 headlight assembly fits in fine because my right headlight is from a 97. Some punk kids with a rake broke my old one and I went to a junk yard and he pulled it off a 97 and it fit fine. No new grille needed.
Gary
garbear is offline
Old 02-03-2002, 09:27 PM
Sports Button FTW
meccanoble's Avatar
Re: headlights
Gary
how much u pay? man, i hope junk yards don't charge much for their stuff
Old 02-04-2002, 12:37 PM
garbear's Avatar
Re: Re: headlights
The junkyard guys charged me $55 for the whole thing. Better than 200 from the dealership.
garbear is offline
Old 02-04-2002, 06:35 PM
QBERT
new to .org and need info.
[QUOTE]Originally posted by ny96max
I have a 97 GXE and I want to get a SMX grill. I was wondering if there is any difference with the way the 95-96 grill will fit with the 97 bumber. I know you switched out the 96 lights to 97, but the bumper looks a little different to me.
Any help is appreciated.
Very Respectfully,
QBERT
Old 02-28-2003, 01:46 PM
rah_nigga's Avatar
what do u guys estimate for the total cost of a complete transformation of a 95 GLE to a 97 GLE front and back?
rah_nigga is offline
Old 05-07-2004, 06:21 AM
hhsguy150's Avatar
ill answer to ur bulb question 2
i did all this hardcore searching on the net for blue bulbs,tried all the high quality exspenive ones...didnt like em...so i go to advanced auto,pick up some apc ones...they r the best bulbs ive ever gotten...really blue....i prefer blue though, cuz plain white bulbs r just to common,u see blue lights comin and it stands out from evberything else..so try that,TRUST ME
hhsguy150 is offline
Old 11-26-2005, 03:58 PM
GrizzlyJonathan's Avatar
Headlights
I have a 96 Max andI bought 97 headlamps about a year ago and have had people flashing their brights at me ever since. I can not get those M/F's to fit right. I saw mentioned that there were "holes" to drill for a good fit. The way they are set up right now is that the beams point too high and they are adjusted as low as I can go. PLEASE HELP ME...
GrizzlyJonathan is offline
Old 11-26-2005, 09:07 PM
99grnmaxgxe's Avatar
WTF?!?!?! This thread is like 6 yrs. old!
99grnmaxgxe is offline
Old 08-26-2006, 04:40 PM
ben805's Avatar
well, I've done the 9004 to 9007 conversion on my 96 GXE with stock hardness, a huge improvement and well worth the 20min mod! But is it worthwhile to swap the headlight unit to 97~99? or should I better off spend the money on a PIAA 1400 driving light? I do lots of driving at night so in the past I can't see too well with the old POS 9004 LOL
ben805 is offline
Old 08-26-2006, 05:17 PM
aventerav's Avatar
It can probably be done with a little tweaking.
aventerav is offline
Old 08-26-2006, 05:19 PM
Bacon Lover
Tatanko's Avatar
Stop bringing up old threads!
Tatanko is offline
Old 09-06-2006, 11:22 AM
Saton472's Avatar
I wass wondering if anybody knows of a place where i can find a set of projector headlights for a 95 maxima gle
Saton472 is offline
Old 09-06-2006, 12:47 PM
f550maranello2's Avatar
u cant put a projector in those cuz they have the diffusers built in.. it defies the purpose.....
geez holy 4 year old thread man...
f550maranello2 is offline
Old 09-06-2006, 01:19 PM
iAMIXAM!
loverholic's Avatar
actually its a five year old thread...lol
at least it did let me know that i can fit a 97 headlight right i my 96 GXE after everyone kept on saying it wont fit right...lol
loverholic is offline
Old 09-06-2006, 08:09 PM
Saton472's Avatar
im talking about a compleat replacment
Saton472 is offline
doctorpullit
10-28-2019 10:58 PM
trsandrew
17
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Pied
09-26-2015 03:29 PM
Noela
09-26-2015 08:22 AM
Quick Reply: Does 97 headlight fit in 95?
