Ae Shift Knob Into 2000 Se "how To"
Old 03-11-2003, 08:39 PM
kdeemax's Avatar
Ae Shift **** Into 2000 Se "how To"
Does any one have experience installing the AE shift **** into a 2000 SE? I just want to make sure I dont tear up the original factory one for nothing or worse yet ruin the shifter, Is there a HOW TO on this somewhere? Any modifications either on the shifter or on the AE ****? Any help would be great!!
kdeemax is offline
Old 03-11-2003, 08:57 PM
bdog's Avatar
Re: Ae Shift **** Into 2000 Se "how To"
I would like to know how to do that too.
bdog is offline
Old 03-11-2003, 09:02 PM
Clay Aiken has fancy genitals
asu174's Avatar
Auto or manual? Here are auto instructions, found in the FAQ section.
How to install an AE automatic shift **** on a 2000 model
Some modifications need to be done to the shift assembly (the part the shift **** attaches to) in order to get the AE shift **** to fit and work. Without the modifications to the shift assembly, the AE automatic shift **** will not work: the new shift **** is not plug-n-play on a 2000 model Maxima.
Once you modify the shift assembly, so that the AE **** will fit and work, your stock "T" shaped shift **** WILL NO LONGER WORK. This means once you switch you can not go back unless you purchase a new shift assembly. The shift assembly costs between $200~$300.
I took some notes as to what needs to happen to get the AE shift **** fitted and working on a 2000 model Maxima. I did not have a camera at the time I actually did the work, but I have summarized the key points on my website. The key points are the measurements and what needs to be modified. I took pics after I had everything done and some time later.
I do not include instructions on how to remove the center console, nor do I include instructions on how to disconnect the OD wires and reconnect the OD wires. You can PM me and I can assist with these two items.
Here are my notes:
http://www.fourthrock.com/maxima/mods.html and choose "Non-AE Automatic Transmission Shift **** Installation".
Good luck!
asu174 is offline
Old 03-12-2003, 06:43 AM
HSVMaxima's Avatar
If it's a manual you can use a strap wrench or a wrench and towel and just twist the **** off. You have to use some elbow grease because there it is glued on.
HSVMaxima is offline
Old 03-12-2003, 06:44 AM
mdeal's Avatar
The easiest thing to do would be to purchase a complete AE shift console and install the whole thing as a unit. The shift console comes with the **** already attached. Otherwise, see the instructions as indicated by asu174.
mdeal is offline
Old 03-12-2003, 06:59 AM
asu174's Avatar
......and originally written by you.
asu174 is offline
Old 01-24-2013, 09:21 PM
Slow Motion's Avatar
Link no longer works...
Slow Motion is offline
Old 04-17-2014, 03:30 PM
chrisconley1's Avatar
I see AE everywhere, what does that mean?
chrisconley1 is offline
Old 04-17-2014, 04:11 PM
The_Fixer's Avatar
Anniversary Edition please look at the date on the threads before replying because people will flame!
The_Fixer is offline
TKHanson
11-24-2018 01:39 AM
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
atriuum
09-28-2015 01:19 PM
Quick Reply: Ae Shift Knob Into 2000 Se "how To"
