Five speed auto question
Old 01-06-2003, 02:47 PM
03BlkSETE's Avatar
Alright, please let me know if this is a repost or idiotic so I can delete this post.
Is their any chance the five speed auto can switched out for our four speed unit?
I know anything is possible with enough money, so my question is, can this be realistically accomplished?
03BlkSETE is offline
Old 01-07-2003, 07:13 AM
03BlkSETE's Avatar
No replies so far. My post looks so lonely so I guess I'll have to answer myself.
Old 01-07-2003, 07:18 AM
03BlkSETE's Avatar
Re: Five speed auto question
First of all 03blksete, get a real screen name. Secondly this question is stupid. In addition to the new tranny you're going to need a new ECU. Are you going to attempt this? Aren't you one of those guys who has a hard time changing his oil. Get real. Delete this idiotic post before you're embarrassed further!
Old 01-07-2003, 07:25 AM
03BlkSETE's Avatar
Re: Re: Five speed auto question
Whoa!! Take it easy big guy. I was just throwing this question out there for a little brain storming. I mean aren't you a little bit excited about the possibility of having a 5 speed auto? And you are right, I haven't done much in a long time as far as working on my cars. I am trying to learn though, so cut me some slack, ok.
Old 01-07-2003, 09:27 AM
Eat, sleep, and sh*t 2JZ
DA-MAX's Avatar
maybe you need a visit a psychiatrist first.... talking to your self on the internet isn't normal!
but anyways why woule you want to swap out the tranny anyways??
DA-MAX is offline
Old 01-07-2003, 12:18 PM
BioMaxDDS's Avatar
i wish i could answer your question, but this thread is so funny
BioMaxDDS is offline
Old 01-07-2003, 12:41 PM
mAdD MAX's Avatar
Anyone notice the 5th gear ratio on the 5-speed auto? It seems to be quite high for an overdrive.
mAdD MAX is offline
Old 01-07-2003, 01:00 PM
03BlkSETE's Avatar
Well if the gearing is right it should provide better acceleration and possibly better gas mileage. I would think the first 3 gears can be used for acceleration and the 4th and 5th gears as cruising gears.
You may be right about the psychiatrist. My wife thinks I need one for spending too much time on this web site.: laugh:
Old 01-10-2003, 06:22 PM
03BlkSETE's Avatar
"That new 5AT is a different story, though. The gearing is much closer together than with the old 4AT. Even if the ET's are the same or slightly slower, the trap speeds should be up from 92 to around 94 or so.
Here's the gearing layout...
1st: 47
2nd: 72
3rd: 111
4th: 165
5th: 220
5th is obviously a very tall cruising gear, and 4th is the highway burner. But 1-3 are much closer together now and should give improved 1/4 mile and around town pep. The old 4AT was set at about 45, 80, and 128 which was much taller and wider."
The above is a quote from SteVTEC. He explains it better than me. I wonder what the 1/4 mile times would be with this tranny in the lighter 02-03's? Think you could run a simulation on that SteVTEC, just for fun.
Old 01-11-2003, 07:47 AM
Dyno plot says I have the most area under the Administrator curve
SteVTEC's Avatar
It's tough to get CarTest2000 to give accurate results for close comparisons like this because it has a lot of trouble in its launch algorithms as far as getting accurate 60' times. Running both cars from a 5mph roll-on eliminates the launch issues and eliminates one of the bigger variables for a more accurate/consistent comparison.
So running from 5mph...
02 Maxima 4AT: 5mph to 1/4 mile: 15.28 @ 92.2
02 Maxima 5AT: 5mph to 1/4 mile: 15.04 @ 93.5
Because the tire's rolling diameter of the 02/03 is smaller than the 04, this would have the effect of shortening the final drive ratio a bit more, so the 5AT gearing would look about like this on an 02/03:
1st: 42
2nd: 65
3rd: 100
4th: 149
So you could potentially gain a little over two-tenths on your ET, and about 1 mph on your trap from this swap. Probably not worth the money considering the enormous expense (the actual tranny, all of the shifting/control hardware, new ECU, technical issues).
SteVTEC is offline
Old 01-11-2003, 12:05 PM
woreyah's Avatar
It's probably very do-able since the 4 and 5 speed trannys are still an option in the 04 Max.
woreyah is offline
Old 01-12-2003, 08:39 AM
03BlkSETE's Avatar
1st: 42
2nd: 65
3rd: 100
4th: 149
Thanks for running than simulation. Yeah a swap would be beyond my means. I'm sure someone will do it eventually though.
Old 02-27-2003, 02:21 PM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
1st: 42
2nd: 65
3rd: 100
4th: 149
Steve,
Can you simulate runs to the top of 4th gear?
Thanks.
IceY2K1 is offline
Old 02-28-2003, 06:38 AM
SteVTEC's Avatar
Originally posted by IceY2K1
Steve,
Thanks.
Can you be a little more specific? There's not much that you can't simulate with CarTest. 0-130? Or a time to distance or something? Also, you're still talking about an 02, correct? Not the 01?
SteVTEC is offline
Old 02-28-2003, 08:21 AM
IceY2K1's Avatar
02/03 Maxima 4AT vs. 02 Maxima 5AT: Go from a higher roll say 65mph(bottom of 3rd) to the top of 4th gear.
I'm looking for any advantages/disadvantages for swapping from a 4AT to a 5AT in a 2K2-2K3. I believe(read guess) that the major difference is going to be in how the 5AT uses it's closer spaced gearing, especially once you hit 4th gear.
Just simulate a couple different senarios of higher rolling starts to top of 4th and 5th pleeeeeeease.
IceY2K1 is offline
Old 02-28-2003, 08:46 AM
SteVTEC's Avatar
From a 70 mph roll-on, the 5AT walks the 4AT, but not by a whole lot. There is definitely no ownage occuring. The difference at 1 mile is 0.2s (2.5 car-lengths at that speed).
For a 00-01, the results are a little better, with the 5AT swapped car now pulling about 3 car-lengths.
The reason there isn't much difference is becase of the new gear spacing arrangement. With a 5AT you will have much better performance than the 4AT up to about 100 mph. But look what happens after that. The 4AT is still running strong in 3rd gear up to about 130 mph. But the 5AT car is running in 4th, which goes up to almost 150 mph - a taller overall gear with less power at the ground. At the 1 mile mark from a 70 roll-on, the 4AT car is actually going faster (pulling) than the 5AT car. But not enough to make up 2-3 car-lengths that were lost.
SteVTEC is offline
Old 02-28-2003, 09:14 AM
IceY2K1's Avatar
Auuuugh, I gotcha! Thanks Steve.
Now if the 5AT didn't have such a tall final drive we might be in business, right? Also, what about the 18" vs. 17" rims, does that matter much? Basically, did your comparison simulate the 2K2-2K3 w/5AT having 17" rims?
BTW, there is no 2K-2K1 in this picture, I was just curious about swapping a 5AT into a 2K2-2K3.
IceY2K1 is offline
Old 02-28-2003, 03:20 PM
max...to the ma's Avatar
Re: Re: Re: Five speed auto question
go to a psychiatrist...its for ur own good
max...to the ma is offline
I<3 A32's
09-10-2015 11:07 AM
Max139617
09-06-2015 06:02 PM
Maxboy23
09-04-2015 06:04 PM
Johnny9595
09-03-2015 05:18 AM
sdotcarter
09-02-2015 09:53 PM
Quick Reply: Five speed auto question
