VE Fuel Injector Replacement How-To
OG Maxima.org Member
Hey fellas,
I know there's been a couple of issues these past few months pertaining to installing, removing, or R&R of the fuel injectors. In my "puny" research on the subject, I found a lot of info on the VG, but hardly any on the VE. Anyway, I replaced my injectors recently, so to help out all of us 92-94 VE owners, here's my write-up for the fuel injectors.
(please note that this is the "raw" version. I might mention pics in this, but I've got the pics I mention in my final draft that I'll link to my website soon...)
Replacing the Fuel Injectors
(edited from previous information supplied by B. Tisch)
Below are the procedures that I used in performing the replacement of my fuel injectors. I drew this up to serve as guidance for you, but I neither guarantee the results nor say that this is the correct procedure, although I did reference the Nissan Factory Service Manual, hereinafter ("FSM"), as well as info from the web sites of fellow Maxima enthusiasts Bryan Tisch and Matt Blehm.
Also note that this information is related to the 92-94 VE30DE engine, although I'm sure some of it can be applied to the VG30E engine, as well. If you have any doubts on your capability in performing this replacement, take your car to a certified mechanic.
What you need:
1. Intake manifold gasket; part number 14032-97E00
2. Throttle body gasket; part number 16175-53J00
3. E.G.R. gasket; Napa part number G31106
4. New / remanufactured fuel injectors/fuel rail assembly
a. The picture below depicts two injectors with different connectors.
b. The 90-91 injectors have the metal clip (smaller) harness connector and the 92-94's have clip-type (bigger) harness connector.
c. Also, Nissan made both blue and black dot injectors for our cars. I have been told you can use either one, but can't mix and match. I doubt it would hurt mixing and matching though, just so long as you get the right one for your car. The dot is on the harness connector.
The steps I performed:
1. Release fuel pressure to zero and disconnect the negative battery.
a. I did this by pulling the fuel pump fuse
2. Separate the accelerator cables from the throttle body.
a. They easily slide off. Tilt the butterfly valves back to get them.
b. Remove the cabling and routing from the intake plenum.
3. Unhook the electrical connector for the throttle position sensor and (if Cali-spec Maxima) exhaust gas temperature sensor. This is located right next to the E.G.R. valve.
4. Remove the intake elbow leading to the throttle body.
a. There are two clamps on each end, and one clamp on the underside of the elbow. There are also two "squeeze-type" clamps holding hoses on either side of the elbow, as well.
b. Mine took a flat-head screwdriver, but I think either a 7mm or 10mm socket will work, as well.
5. Label and unhook the hoses from under the throttle body.
a. This would include the E.G.R. valve, the E.G.R. control solenoid valve, the intake manifold collector, and (if equipped with a manual transmission) the power valve control solenoid and the power valve actuator.
6. Disconnect throttle sensor harness connector (a c-clip holds this, and other harnesses, in place.
7. Remove the intake manifold support bolts, located on the back of the intake manifold.
a. There are two brackets, with two bolts each. This takes a 12mm socket, and a little contortionist work, as the working space is very limited.
8. There is a large, c-shaped hose that's just to the right and behind the throttle body. I would recommend removing it, just so it is out of the way.
9. Remove the E.G.R. body from the back of the intake manifold.
a. This is held on by two nuts. I think they are 12mm in size.
10. Remove the hose that runs along the front of the intake manifold.
a. This is held on by two 10mm hex bolts that secure it to the manifold at 2.7-3-7 ft. lbs. torque.
b. At this point, I would probably also remove the following: the wiring harness for the back and front row of coils, the PCV hose behind the intake manifold, another smaller hose just above the PCV hose, and the vacuum hose railing (10mm).
11. Remove the intake manifold
a. There are six 6mm hex bolts that hold down the manifold at 13 - 16 ft lbs.
b. There is a special torque sequence that I observed in both loosening them and tightening them down. I posted that sequence some time ago, so a search will yield results. You will likely need to pry the manifold up and out, ensuring that no hoses, wires, etc., are still connected as you do so.
(NOTE) At this point, you should have the intake completely removed, which will leave 6 gaping holes in the top of your engine, which match up to the intake to the engine. There will likely be some remnants of the gasket there, as well. Plug up the intake holes before cleaning the gasket surface.
12. Remove the fuel injector harness wires.
a. For the 92,93,94's this is easy, as you just apply pressure on the harness and pull
b. For the 90 and 91's (and presumably 89's) there is a metal wire clip that you must pull out or partially out to remove the connector.
13. Remove fuel injector(s)
a. At this point, I removed the entire fuel rail assembly, since my replacement was a complete assembly. If you're doing this, then the bolts that hold it down are 6mm hex bolts, torqued at 2.7-3.7 ft. lbs. Otherwise, if you're just taking out the injectors themselves, use a pair of pliers and grip them tightly, turning the injectors back and forth before pulling upward. All should come out easily.
b. There should be two O rings per injector for the 92-94 injectors. I removed my entire fuel rail, so I'm only going by previous information, along with info from a Chilton's manual. The lower O-ring will likely stay in the fuel rail hole upon removal of the injector. Just stick your finger in and retrieve it. Be sure to replace with new "O" rings, per the FSM (didn't get the p/n - sorry).
14. Service and/or replace injector(s)
a. Apply motor oil or petroleum jelly to the O rings and carefully insert the new fuel injector. Instead of just pushing downward immediately, you should turn it back and forth, while applying downward pressure. You will see and feel the injector seat in how it should be. Before replacing, insure that the new ones spec out correctly with regard to resistance. The range of resistance allowed by Nissan is 10 –14 ohms.
15. While you're in there, clean intake manifold, and intake runners.
a. I used Carb clean to do this. I sprayed a good amount of Carb clean down the intake runners and used a cloth to wipe the dirt out. You may want to try a toothbrush if you've got that kind of patience.
b. Be sure to completely scrape away all remaining gasket material on both surfaces so as not to allow an intake leak after assembly.
16. Reinstall all parts in reverse order, keeping in mind the torque sequence and use the torque wrench so as to tighten the following to these torque specifications, per the FSM:
a. Throttle body bolts (2-step process) - (1)6.5-8 ft. lbs. (2)13-16 ft. lbs.
b. Intake manifold hex bolts, 13-16 ft. lbs.
c. E.G.R. valve bolts – 9-12 ft lbs.
d. Intake manifold support brackets - 12-15 ft. lbs.
17. Reconnect the negative battery terminal. 18. Start the engine and check for leaks.
And that should do it. If you've got any questions, feel free to ask me. I don't claim to be a pro, but I'll do the best I can to answer it.
What you need:
Re: VE Fuel Injector Replacement How-To
Originally posted by nubiannupe
Hey fellas,
What you need:
Hey fellas,
What you need:
Stephen
lil help
first thing in the morning start the car get a strong smell of fuel when you turn the vent on after that u can start it all day and never smell it again and got oil changed guy said motor was covered in gas but i cant find the leak need a lil help
12 year old thread bump. Impressive stuff!
How can we help you find a leak remotely? Check your fuel hoses and fuel rails and injectors when it's running. If you can't manage to find what sounds like a very large leak then perhaps you should take it to a professional.
Trace the fuel filter from the firewall and then from there to the engine/fuel rails. Get somebody to start it up in the morning while you check the fuel routing/hoses described above in the engine bay. Should be able to find it without too much trouble if you're just thorough
Saw this and saw Matt's post. I was about to say DAMN! I Haven't Heard/ Talk To You In A While. But nice bump. I'm willing to almost bet money its a rubber fuel line One of the 4 for the fuel rail. Since you said it was spotted during an oil change. I Bet it's those 2 small hoses for the bridge over the outlet for the upper radiator hose.
kjlouis
11-24-2018 06:09 AM
pkfinn
09-13-2015 08:01 AM
