ECU question....throttle position switch????
i just checked my ECU and i got a code, 1 slow 2 fast.... i looked that up and it means closed throttle position switch... what does that mean??? how can i fix it.. help!!!!!
From the Haynes manual:
Disconnect the wide open/closed throtle pos. sensor. Connect an ohmmeter to termals 5&6. Check for continuity at the switch with the throttle fully close and again slightly open. There should be continuity with the throttle completely colsed and no continuity with the throttle open.
If the reading are incorrect, replace the TPS.
HerpDerp1919
09-29-2015 02:02 PM
