Car ran, parked it, now it won't start
My wife used our 97 Max this morning and parked it in our driveway. I came out later to use the car but it would not start. I put the key in the ignition to start it but all that happened was a momentary click...then nothing. With my wife trying to start the car, I tested the voltage on the battery. 12.7V and never moved while she was trying to start. Apparently, something was blocking out the starter circuit. 4 hours later, I went to start it, and it started right up. No indication of overheating, system fluid levels, or anything. Go figure. Any suggestions as to what the problem might be?
Check your battery and starter connections. You may have some corrosion, or a loose connection. The other possibility is that your alternator is not charging your battery very well, and it took a couple of hours for the battery to charge itself enough to start. This happened last week to my girlfriends Subaru. She has a new battery, and the alternator went out. It was dead when she came out of the grocery store, but started right up two hours later when I went with her to get it.
i think ur ignition swtich is dead, mine went dead and did that alot. http://forums.maxima.org/showthread....gnition+switch
TAPOUT, Thanks for the feedback, but
I'll post my findings when I know what the heck happened.
Again, thanks all for your feedback...
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
BobMax
08-15-2015 12:35 PM
