382whp/380wtq
Old 02-14-2010, 09:45 AM
Demodded and Forgotten
rroderiques77's Avatar
382whp/380wtq
Had the Max at Speed Force Racing for a week and here are the results,
At 6.5 lbs, it put out about 380HP. Unfortunately, with the POS tires I had on the car, traction was a problem. As a result, I was slipping quite a bit on the dyno. I suspect that with better traction, I would have been well over 400 @ 8lbs.
Anyway, to be continued with some better tires....
I will also have some progress pics later
rroderiques77 is offline
Old 02-14-2010, 09:53 AM
perkman87's Avatar
Very nice numbers. Thats stock right...... lol
perkman87 is offline
Old 02-14-2010, 09:54 AM
Stock motor LOL
MoncefA33's Avatar
Very nice! Glad to see the SFR kit being put to use. What are you running for tuning?
MoncefA33 is offline
Old 02-14-2010, 10:02 AM
It was tuned with a Haltech
Old 02-14-2010, 10:09 AM
wirelessdude04's Avatar
nice numbers
wirelessdude04 is offline
Old 02-14-2010, 10:12 AM
TurboA32's Avatar
Originally Posted by rroderiques77
Stock motor LOL
stock 3.5? you better be safe about about how much boost and hp you put into that thing it might fall apart.
TurboA32 is offline
Old 02-14-2010, 10:22 AM
MoncefA33's Avatar
Standalone?
Old 02-14-2010, 10:37 AM
I know. Wont be going anything above 8 PSI
Old 02-14-2010, 10:43 AM
tookrzy4u192's Avatar
nice numbers! plan on going to the track anytime soon?
tookrzy4u192 is offline
Old 02-14-2010, 11:02 AM
As soon as I find some tires
Old 02-14-2010, 11:34 AM
streetzlegend's Avatar
380 is pretty impressive for just 6psi, what turbo do you have? be a little careful at those power levels and remember that limiting yourself to just 8psi dosnt mean your being safe, its not the boost level that you have to look at, its the actual power output your producing, you can have 15psi on a crappy turbo and make 390hp and the motor wont be stressed as much as a REAL turbo at 15psi making 500whp.
streetzlegend is offline
Old 02-14-2010, 12:33 PM
It is a Turbonetics T4. And I understand what you mean. I would like to put out no more than 400HP on a stock motor, however much boost it requires.
Old 02-14-2010, 12:55 PM
Shouldnt be an issue getting 400 however I suggest you focus all your attention on how well tuned it is, no shortcuts, no aggressive tuning, low timing, and make the power with boost instead of higher timing and leaner a/f.
Old 02-14-2010, 04:52 PM
NiZMo1o1's Avatar
nice # s !
NiZMo1o1 is offline
Old 02-15-2010, 05:41 AM
Shift_Max's Avatar
Was the haltech unit spliced in and hardwired?
By the way where is the thread for the build lol
Nice numbers though
Shift_Max is offline
Old 02-15-2010, 06:44 AM
Nice numbers though
Soon...
Old 02-15-2010, 06:51 AM
Turbo 4th Gen
93altima's Avatar
congrats nice numbers
93altima is offline
Old 02-15-2010, 09:17 AM
Turbo 3.5
t6378tp's Avatar
If you were spinning the drum at 8psi and made 380 at 6.5psi I am pretty sure you already hit your goal it's just not on paper yet
very impressive to make that kind of power on 6.5psi
t6378tp is offline
Old 02-15-2010, 09:33 AM
BigFonsz's Avatar
Nice numbers!!
If you are going to run 8lb daily you might want to use the same gas station. Keep some octane booster on you and done let the tank go dry. Do u have the stock ks or something else to pick up knock?
BigFonsz is offline
Old 02-15-2010, 10:56 AM
Grand_hustle17's Avatar
Damn thi is well
Grand_hustle17 is offline
Old 02-15-2010, 11:09 AM
Standalone?
Correction to that. SFR used a Split Second FTC.
Originally Posted by BigFonsz
Nice numbers!!
Yeah, I hear you there. I am definetely not running 8lbs daily. This car is not even my DD anyway. I am running the stock ks.
Old 02-15-2010, 11:12 AM
Yeah. We were pretty damn impressed as well. That run was right out of the box with the motor cold. which I am sure helped. The SSIM and 3" exhaust also helped out quite a bit. Tires on the other hand
nycnissans
secondtonone317's Avatar
very nice, try not to boost in high gears at low RPMs
secondtonone317 is offline
Old 02-15-2010, 12:03 PM
SLOW
Nealoc187's Avatar
Very nice numbers, how did you confuse a Split Second box with a $2000 haltech though lol...
Nealoc187 is offline
Old 02-15-2010, 12:04 PM
Casanova's Avatar
impressive!
Casanova is offline
Old 02-15-2010, 12:45 PM
BkGreen97's Avatar
why?
BkGreen97 is offline
Old 02-15-2010, 01:04 PM
1swtmax's Avatar
Great read. I`m getting ready to put on the SFR IM and going back to the dyno. So I should also be able to lower my high boost setting to about 8 psi and still hit just over 400 whp. Right now with the factory IM its pushing 9.5 psi at 395 whp.
1swtmax is offline
Old 02-15-2010, 02:31 PM
I was debating if the runners on my SSIM were smooth enough. If not, I probably would have gotten Tim's manifold. For now, mine appears to be ok.
Old 02-15-2010, 02:49 PM
acet's Avatar
Whats the trap time with those numbers?
acet is offline
Old 02-15-2010, 03:14 PM
1swtmax's Avatar
Sorry for not saying it before. Great job and great numbers. And don`t need to ask but how do you like driving the max now.
1swtmax is offline
Old 02-15-2010, 03:39 PM
Nothing as of yet. Need tires ASAP!!
I love it!!!! I drove it back from San Diego to Vegas after it was done and it was sweet!! I can actually light up the tires in 6th gear with Profec turned up high (8PSI). I just can't wait to hit the track...
Old 02-15-2010, 03:48 PM
1swtmax's Avatar
Come on, light up the tires in 6th gear. What are you driving in, snow.lol You must have the really bad tires.
Yea, about the track. Get ready to be disappointed. You will have a very hard time launching. But once you get out of the hole, hold on. I`m at 395 and 412 and spin all of first and second and half of third then it grips and takes off. But at that time, the damage is done. One thing is impressive is the mph in the quarter but as far as time, sucks.
If your looking for tires at the track make sure you go with slicks not drs.
1swtmax is offline
Old 02-15-2010, 04:21 PM
kind of off-topic, but i haven't seen any track times from you.. if you don't want it posted, you could PM me
to OP, i recommend slicks as well!
Old 02-15-2010, 04:23 PM
digitalbow's Avatar
Lol - agree.
I think it's because he had SFR do all of the work.
OP - Would you mind sharing what supporting mods you have? 382 whp at 6.5 psi (yes, it's PSI, not LBS) is very good.
Do you have pictures of the install?
You mentioned that the turbo has a T4 flange, but which turbo are you using (model, wheel size, a/r, etc)?
digitalbow is offline
Old 02-15-2010, 05:03 PM
BkGreen97's Avatar
Originally Posted by digitalbow
Lol - agree.
Also in for the info and pics mentioned above...
But just have to say wonderful numbers... SFR is doing wonders for you guys, very impressive numbers... Best of Luck, bfg kdw's grip pretty darn well when looking for daily driving tires..
Old 02-15-2010, 06:59 PM
aic96max's Avatar
numbers are good numbers. this is expected 2002 up turbo numbers using stock timing and just an additional injector controller.
buddies shop in miami did an altima ser with a gt30 and was on par. 6-7 psi put up about 385 whp, though he left it at 8 psi bc of stock timing..
how do you like the split second unit? i was looking into that since im trying to avoid the whole piggyback and ecu mission. are you using the unit that controls one or two injectors?
aic96max is offline
Old 02-15-2010, 09:19 PM
Lol - agree.
Yes. SFR did all the work. I don't know enough about the subject to attempt a build like this. That is why I paid someone else to do it. SFR does a great job.
Pictures will be up later you guys. SFR has the majority of them and also the pre-dyno run. Tim said it ran around 280whp and that I want to see for sure.
Supporting mods are 3" custom catback, SSIM with block off plate, Phenolic spacers, Synapse 38mm wastegate, Synapse 50mm BOV, 440cc injectors and Walbro 255.
Old 02-16-2010, 05:40 AM
Shift_Max's Avatar
mind if i ask what you paid when it was finished?
Old 02-16-2010, 06:09 AM
Quickywd01's Avatar
it is LBS, pounds per inch squared. Everyone uses shortcuts.
Lol - agree.
Quickywd01 is offline
