4th Generation Maxima (1995-1999)Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Sponsored by:
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Do you have an air chisel? and large hammer? That is what I use... and you mean the steering knuckle that the ball joint is on?
__________________ Gen4 Black on Black leather 5spd SE |Shaved Rear w/ Black Nissan logos | TK Premium Tints, 25% rear/35% sides/5% sunroof|5k HIDs | AE Black trim Headlights |shade bumper lens| Stillen K&N Short ram WAI | LSS Y-pipe |Magnaflow catback w/4" chrome tip |Voodoo shift knob | New European Leather wheel cover | Strut tower bar | Coming soon H tech drop with Tokico Ills/ w Hankook V12's & 5X114.5 BP rims but still undecided|
whack the side of the knuckle where the ball joint runs through it while you're pressing down on the control arm. use a decent sized hammer- 1-2lb is good. not some dinky little 8oz POS. hitting it there will cause the metal to momentarily distort and the ball joint will pop loose after a few hits.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
DONOT use a pickle fork, you will destroy the rubber boot on the BJ. I like the hammer method and it has worked for many yrs consistently. Take the cotter pin off, remove the nut on top of the BJ, and then whack it on the steering knuckle meets the LBJ. It will pop out in no time..
Reason: Edited to add removing the BJ nut
Yeah, I need a "dependable" daily driver because my Starion isn't hacking it! lol But the Maxima needs some TLC as well. The bushing in the LCA is shot, I need a new timing chain tensioner, tires, starter (lifetime warranty but I need to replace it), O2 sensor and clean out the EGR system. There's probably more but that's my list so far!
So, is there a snap ring on the ball joint or not? I have heard of one being there but only to hold it to the LCA, not the spindle/hub. You typically just bang the LCA and/or hub and it pops free.
I went and got a real hammer and a pickle fork (I'm replace the whole LCA that has a new ball joint in it so I don't care about the old ball joint). I'll try the hammer first so I can try to keep the old ball joint as a spare.
I thought that huge bolt holding the LCA to the body would be my problem spot but that way easy! lol
I thought you were trying to remove it from the LCA as well for replacement. The snap ring only applies when removing it from the LCA. That's what I get for not reading....
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
It's cool! Yeah, only trying to get it out of the hub to replace the LCA as a whole...
Good thing your keeping her but man thats a long repair list and sounds like its getting a bit longer.
Good luck with the repairs. Hope to see you around soon.
