Lighter Flywheel.
Lighter Flywheel.
Anyone use this yet?
With a UDP and a lighter flywheel teh VQ35 would scream up and down. What do you guys think? Worthy investment?
http://performancenissanparts.com/ca...oducts_id=5833
Peace,
Kam
Peace,
Kam
I think it is very worthy. I lvie near Performance Nissan and I have bought many parts from them for my former Spec V and my present Maxima. I talked to a guy in the parking lot who had a 350Z with lightened flywheel and he said it really made a difference in the way the engine revved. I also know from my racing experience that lightened flywheels work. When my clutch needs replacing, Im getting a lightened flywheel. Remember, when you lighten rotating mass, its like losing 3-4 times the actual weight of the item. If your flywheel is 15 lbs lighter, than its like losing 45 lbs or so off the car in dead weight.
It depends upon the gear you are in.
The effective radius of the weight removed makes a difference too.
Assume 10 lbs removed at a radius of 5", and a 12" radius of the driven tyre.
Also assume a gear ratio of 14:1 in first.
That combination would give you 10x14x5/12 =58 lbs "lighter"
And the benifit is less in the higher gears.
Originally Posted by kamilkluczewski
What does all that mean??
If you remove weight from the rim of the flywheel it makes more difference to the butt dyno than if you remove the same weight from the center of the flywheel.
You cant remove too much weight from the rim because that is where the ring gear is that the startermotor drives against.
For a typical lightened flywheel you are looking at the equivalent of shaving 50-100lbs from the car in first gear, steadily reducing to 10-25lbs off in Top gear.
Mike
I just went through the maths for you so you would be able to work it out for your flywheel, and used some numbers that are close to real life.
Mike
Mike
So basically the engine goes VROOM VROOM alot quicker?? But how does that increase you gas mileage?
Kam
Kam
Kam
Originally Posted by blakstarz
I think I read in a previous post somewhere, that installing this is a pain and it's a rather pricey installation job....is that true?
Depends on how u drive. If u drive a lot of highway miles, than it lasts more miles. If u do "jackrabbit" starts, it could go out very quickly. And who really gives a shzit about mileage. The feeling of a light flywheeel and revvy engine is worth it.
You should ask (i think it was Jason) at Perf. (if he's still there) about the flywheel/clutch combo he had on his 350z (before he sold it)...(hm...those where the days...sigh). WHOA. SO MUCH power throughout the band. It may have only gained 1hp "Peak" but the midrange power boost felt like 50hp increase. There might still be videos. If not I'm sure i might still have it.
OH yeah, trade off is that it was very hard to drive. Might take a week to learn it. At that early time you could only buy the crazy Tilton clutch whose engagement point was very very tight. Since then there have been a few more clutches that are compatible with the extremely lightweight (7 lbs) flywheels.
Originally Posted by DeusExMaxima
Kamski: U can score lightened flywheels at lots of places. I think Performance Nissan has them, and Jim WOlfe too. Google it, bro!!!
Kam
The final drive isnt affected by changing ur flywheel. There are bolt ons. I was just looking at them the other day, but I dont recall the website. They are out there for sure.
Violator
09-09-2015 10:14 AM
Black VQ
02-11-2001 09:10 PM
