rolling your fenders...
Old 05-07-2004, 02:28 PM
mclee45's Avatar
anybody rolled their fenders? How do you do it? Is it a do it yourself job or do i need a professional to do it for me? I'm getting 18s and want to make sure I dont rub so I want to roll my fenders. A writeup would be nice too if someone has it. thanks
mclee45 is offline
Old 05-07-2004, 06:45 PM
white m3 guy's Avatar
ok umm you def dont have to roll fenders for 18's you can fit 20's on maximas, and second dont ever roll your fenders youll end up cracking your paint
white m3 guy is offline
Old 05-07-2004, 06:50 PM
6spmax's Avatar
What is rolling the fenders?
6spmax is offline
Old 05-07-2004, 07:01 PM
350 Detroit Muscle
Ammi's Avatar
Whole purpose is to fit larger and/or wider wheels
Ammi is offline
Old 05-07-2004, 08:28 PM
6spmax's Avatar
Yeah, thanks. That's QUITE obvious from the first poster's comments. What I want to know is what is involved-i.e-cutting away parts of the fenders.
6spmax is offline
Old 05-07-2004, 09:00 PM
mad2kmax's Avatar
i'm interested in this also. my car is dropped 2 inches in the rear and right now there is no fingergap between the rear tire and the fender, and i'm rolling around in my stock 16's. I want to upgrade to 19's one day but i'm afraid that they won't fit b/c of the drop. i would also like to put spacers on the rear but if i do that, it would slam right into the fender the first time that i hit a hard bump. so, please, do tell someone.thanks
mad2kmax is offline
Old 05-07-2004, 09:12 PM
ChinoSanXXL's Avatar
Fender Rolling...............
click on this link:
http://www.overboost.com/story.asp?id=131
You can also rent the fender rolling tool from Tire Rack....
Hope this helps.....
ChinoSanXXL is offline
Old 05-07-2004, 10:07 PM
mad2kmax's Avatar
thanks for the info. i guess if i decide to do this that i'll get a professional bodyshop to do it for me. ah... spendin' more money on my max, it just doesn't end... haha, no one ever said that the need-to-mod disease was cheap. thanks again for the info
mad2kmax is offline
Old 05-07-2004, 10:08 PM
myktek's Avatar
mike, y would u roll your fenders... my wheels/tires are fatter then yours and i only rub occasionaly....
myktek is offline
Old 05-08-2004, 06:07 AM
mclee45's Avatar
I'm not sure if I'm going to do it yet.. but just in case I rub like crazy when i put on the 18s.
mclee45 is offline
Old 05-08-2004, 09:15 AM
limsandy's Avatar
What size tires and wheel offset do you have?
~limsandy
limsandy is offline
Old 05-08-2004, 11:13 AM
mclee45's Avatar
he has 275/40/18 rears and 245/40 fronts... I'm planning on putting on 255/45/18 all around on mine
mclee45 is offline
Old 05-09-2004, 03:53 AM
Bandwagon Lover
Audtatious's Avatar
Old Skool = baseball bat.
Requires two people. One puts the bat between the tire and fender. The other rolls the car backward. Proper bat positioning will roll the fender as the tire will cause the bat to roll from front to back.
Of course, too much can cause the fender to bow it you do it wrong. Use at own risk....
Audtatious is offline
Old 05-09-2004, 03:48 PM
I miss the .org!
Triple8Sol's Avatar
All of these DIY methods seem scary. I'd have a shop do it...
Triple8Sol is offline
Old 05-09-2004, 05:56 PM
rob van dam's Avatar
fortunately i didnt have to roll mine. All 4 of my wheels are tucking and i have no rubbing so far. im on 225/40/18 tires....
rob van dam is offline
Old 05-09-2004, 06:34 PM
Bandwagon Lover
Audtatious's Avatar
Offset has an impact. Mines 40mm with 235-40-18's and no problems. I should be fine with an additional 5mm or so adapter as well...
Old 05-09-2004, 08:08 PM
chris'smax's Avatar
Man i don't know what series tire your running but my car is dropped 3.25 in the front and 3" in the back and i am running 19x8 and 10 mm spacers in the back. and i still have a 1/4 of a inch finger gap. It won't slam into the fender because wheels dont travel straight up upon impact, they will safely tuck into the fender.
chris'smax is offline
Old 05-09-2004, 08:11 PM
Eat Naaawwwzzzzz
KiLLeR2002se's Avatar
You dont need to roll em. Plenty of peeps here running 19s and 20s slammed w/o rubbing, me being one of those. My rear is slammed and tucked. Finger gap is actually NEGATIVE 1
and no rubs..
KiLLeR2002se is offline
Old 05-09-2004, 09:47 PM
limsandy's Avatar
and no rubs..
How do you get -1 finger gap with H&R?
~limsandy
limsandy is offline
HerpDerp1919
09-29-2015 02:02 PM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
05RLS2
09-27-2015 09:24 PM
Quick Reply: rolling your fenders...
