Go Back   Maxima Forums > Miscellaneous > Other Cars
Other Cars Strictly for information on cars that are not Maximas. This Forum should contain technical information and off-topic posts will not be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-12-2006, 10:23 PM   #1
Dyno plot says I have the most area under the Administrator curve
SteVTEC's Avatar
SAE Rating Confusion
Since this has been confusing to a lot of people, and Nissan/Infiniti still has a mix of rating systems in use, here is some real quick basic information.
SAE J1349 JUN 1995 = OLD
SAE J1349 AUG 2004 = NEW
SAE J2723 = certified = "voluntary" and based on top of J1349
http://www.sae.org/certifiedpower/details.htm
About SAE J1349 Certified Power
Power and torque certification provide a means for a manufacturer to assure a customer that the engine they purchase delivers the advertised performance. This SAE Standard has been written to provide manufacturers with a method of certifying the power of engines to SAE J1349 or SAE J1995. Document SAE J2723 specifies the procedure to be used for a manufacturer to certify the net power and torque rating of a production engine according to SAE J1349 or the gross engine power of a production engine according to SAE J1995. Manufacturers who advertise their engine power and torque ratings as Certified to SAE J1349 or SAE J1995 shall follow this procedure. Certification of engine power and torque to SAE J1349 or SAE J1995 is voluntary, however, this power certification process is mandatory for those advertising power ratings as "Certified to SAE J1349".
SAE Engine Rating Standard Prevents Numbers Fudging (an article on how GM will use SAE J1349 Certified Power, AEI May 2005, Vol 113 No.5, p 59 )
General Motors has become the first manufacturer to certify an engine's power and torque ratings using a newly adopted SAE standard (J2723), James Queen, GM Vice President, Global Engineering, announced during his keynote address at the SAE World Congress and Exhibition in April 2005. The world's largest automaker plans to certify all of its engines to the voluntary standard, and is encouraging its competitors to do the same. The LS7 engine for the 2006 Chevrolet Corvette Z06 was certified under the new standard this month. The 7.0-L V8 unit produces 505 hp (377 kW) at 6300 rpm and 470 lboft (637 Nom) at 4800 rpm. "The new voluntary SAE power and torque certification procedure ensures fair, accurate ratings for horsepower and torque as it uses third-party certification," said Queen. "SAE technical standards level the playing field, and this certification procedure is just the latest example of the value SAE has offered over the past century." To tout power and torque ratings as "SAE-certified," engine manufacturers must have an SAE qualified witness watch over the entire testing procedure to ensure that it is conducted in conformity to SAE standard J1349. Third-party witnessing is the main provision of J2723. An existing SAE standard, J1349, spells out how the actual testing is to be done. J1349 was updated last year to eliminate some ambiguities that allowed engine makers to cite power and torque ratings higher than the engine's actual capabilities. Engine makers are free to cite power and torque figures drived from testing conducted outside the scope of the SAE standards, but they may not claim the figures are SAE-certifed. "We feel that both the consumer and industry are well served by having accurate, consistent ratings from all manufacturers," said David Lancaster, a Technical Fellow in GM Powertrain and Chairman of the SAE Engine Power Test Code Committee that updated J1349 and wrote J2723. Data from a wide array of parameters (e.g., air:fuel ratio) will be collected during testing conducted to the SAE standards. SAE will create a database and offer it to industry in different packages and at different price points.
By Patrick Ponticel
So far ONLY GM is making it a point to officially "CERTIFY" their engine's power ratings across the board. DCX has done so but only on the 8.3L Viper engine. You can see the documentation below. And the whole "certification" process is entirely optional to begin with. Using the "NEW" standard (J1349 AUG 2004) is mandatory, however on all new or updated powertrains. Nissan and other manufacturers have gotten away with using older ratings since if you do not change the engines you are not required to restate the numbers. You MUST use the new standard on any new or updated powertrains though.
http://www.sae.org/servlets/epcdAppl...PAGE=epcdIntro
PLEASE DO NOT SAY that SAE J1349 AUG 2004 is "OLD". That is wrong period. It is in fact the NEW standard. J2723 simply tells a manufacturer how they go about officially "certifying" an engine.
__________________
Total Power Area Under the Curve Divided by Weight STILL oWnZ j0o
SteVTEC is offline   Reply With Quote
Old 04-20-2006, 11:23 PM   #2
Wanna Go Fast?™
MrGone's Avatar
When are they going to come out with a Metric system for Japanese cars?
MrGone is offline   Reply With Quote
Old 03-20-2009, 11:30 AM   #3
^ +1
__________________
IHATEMY2KMAXIMA
IHAVEA2KMAXIMA is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
