If you are from NJ or Philly, have a MEVI and need it installed, I will charge 150 to install the MEVI and vacuum lines. I will charge an additional 40 dollars to run all the wires from the engine bay into your car, in a clean style. With out the additional wire installation, I will make sure the MEVI is properly connected with all the appropiate vacuum lines connected and ready to be activated with the RPM switch wiring.
-Danny
godstrength@verizon.net
609/356-4247
