- underdrive pulley
- remove the side door thin strips
- exhaust
- Headlight problem...... I need help!!!
- Dul Exhaust
- Letting everyone know in advance...
- car problems again =(
- Oxygen Sensor Bosch or NGK/NTK
- can someone please help me out?
- New Maxima for me... ??
- I need spoiler opinions please
- Help! Can't find Steel Braided Brake Lines
- rear brake question?
- need answer asap!
- I found a good price from Neuspeed for 1 greddy exhaust!
- any one have any experience
- bad battery and/or alternator
- removing the side bars on the doors
- update
- Need to be sure!
- My Odometer And Trip Meter Stopped Moving
- I took my cat. converter out saturday...
- VE30DE and tranny tear down coming!
- front bumper
- low fuel light
- MOROE struts any good?
- more like 2k4 maxima, see the spy photo's??
- FS: 3rd Gen. Bose System w/ amps
- Tick...tikck...tick...
- Quick Question On Lowering
- 92 maxima NO Blinkers
- Stock intake pipe question
- Body kit
- midas...
- fog light bulb replacement
- ECU Reset Q's
- About to buy Konis
- Delayed Reverse..........................r
- SS Brake lines
- Put on PR CAI.... Problems problems problems !!!
- Hows the Adjustable Shortshifters...
- installed autodynamic headlight wire harness upgrade
- Noises?
- upper mid pipe
- poll on mods
- bulb question...
- Speedometer/odometer Questions
- tinting....
- indiglows 4 sale cheap
- sound increase....
- Help: auto tranny starting to chirp between gears?
- Diary of a JDM VE30DE engine swap
- 2k3 accord
- 93SE 1/4times?
- hard to shift, especially when car warm ?! =0\
- Need HELP!! Gas Leak!
- Leaky sun roof
- oil lleak?
- solution for the infamous noisy brake drums?
- custom led setup
- 1990 Gxe Engine
- toronto area nissan meet sept. 14&15
- Exedy Clutch Kit
- VTC vs. JWT ECU
- when do these lights go on?
- fstb end lengths -- do they need to be equal?
- Problems with radio and security system
- Transmission Messing Up Help!!!
- I've searched and I've searched, now I need a tranny expert
- what's up with custommaxima?
- first night with max and already had 2 kills
- Gps Screen
- Head upgrades
- I need the Bose code
- sucky bose
- maxima still not running quite right
- Whats the VG's Rev Limiter
- 1994 3rd Generation Maxima partiing out NYC
- TSW Trophy
- My brothers car again....
- I would like to..
- possible to drop a z31 in a 89-91 SE?
- is my transmission ****ed up?
- secret recipe of a turbo 3rd gen :p
- WTS reverse indiglo guages
- exhaust studs - size
- Need New Muffler
- spark plugs
- Need Bose Color Codes!!
- maxima question =)
- fuel injector 24 ohm
- cigarrete lighter light....
- First Lowered Maxima in New Zealand!!
- hew Head Unit.... wtf do i do with bose
- template for CAI
- Pacesetter STS
- pics of blue leds
- Somethin i read in...(gasp) Super Street..
- Something fell off from my car on freeway
- Need Fuel Pump Help....hellllppp!
- Interior Pics w/ Brushed Aluminum or Gray/Silver Accents
- Clutch went on me at school today....
- wheel spacer studs
- Stillen front lip has been installed
- VE coolant temperature
- Doing VTC's this W/E - where to find TSB?
- What codes do you get when the CEL is not on?
- help, shifter vibratingmore than normal...
- maxima runs like crap and here are the compression readings
- First pics of Max O/D's TURBO 92 GXE--->
- Just a thought I had today about Tranny trick(auto)
- Is there a way to take of the O2 sensor?
- How can you keep K&N intake from wiggling?
- Thermostat or radiator question
- Air leaking from K&N!
- Noise On Cool Day
- Rusted bolts please reply now
- How would this look?
- Fixed (installed) my A/T bushing
- stillen intake
- anybody got a bose HU from 93 or 94
- tire size question
- CHanging power steering hose HELP?
- can I still pull codes from the ECU?
- Automatic transmission shifting VERY hard after installing intake!
- What was the "Official name" for the burgundy color in the 1989 Max's
- Pics of the CF hood
- Intake install...
- Lowering springs........
- o2 sensor problems???or something else???
- BMW headlights
- Tranny seal Question
- Tinted tail lights
- Water in injection system? HELP?
- Police auctions?? Any good??
- Timing Belt Replacement
- VE motor questions
- Smell from front Brakes or ???
- New Max
- symptoms pf a bad feul pump?
- help
- Yo
- to cv joint or to axle?
- UPDATE good and bad
- "Engine Re-energizer" and other maintenance chemicals
- 92 SE tire pressure?
- rewiring 3rd gen corners
- 5-spd shift knob thread size
- Thermostat Install
- will ve from 5spd fit an auto?
- whatever happened to stillen diamond cut clear corners?
- '93 SE 5-spd. What is it worth??
- How do you fill the tranny fluid??
- 94 GXE 1/4 Times
- antenna mast
- Whinding Noise ??
- Brand new Refurbished Bose Equipment....
- Please help a newbie
- tint question
- aftermarket parts question
- auto shift boot question
- muffler tip question
- transmission removal???
- Tokicos Strut installed.....first major mod
- How to run intake piping
- Stupidest question; How do I remove the jack?
- Antenna problem..
- extra parts
- Remove Back Seat
- Mmm big rear brakes.. :)
- How can you take off wiring harness in trunk, and be able to put it back on?
- Window problem
- Throtte body
- Should I unstall cheap alarm, or a good one?
- stillen kit for sale?
- Where to get head bolts
- Rims for my Black Se
- What Head Unit?
- analog and digital dash question
- Gauge Bezel
- spark plug q.
- problems??
- I think my VTCs might have been grounded by last owner...grr... (detailed pics)
- SkyLine Sport Seats
- Brakes vibrate at low speed (possibly abs)
- problems... and lots of it
- Hybrid intake is in....
- can anyone help
- '93 se manual tranny question
- Please help: Horn / Relay Problem
- Exhaust
- i love my car
- ABS connector wire & Floor Jack....!!!
- Rear strut cartridge installation?
- Sensor problems
- Help - Keyless Entry Code
- What is this thing?
- think im asking stupid questions plz respond
- Help Needed from 3rd gener
- VE - odd "Shop-Vac" type sound...
- My CF hood is for sale.
- What to do for my first mods...
- What is that thing called in between the back two seats that folds down?
- VE ignition coils
- Best Strut Bar
- Wheel locks
- focuz muffler
- Anyone interested in a 3rd gen custom sub box...
- Farewell
- Rear Speaker Q
- tinting...
- intake question?
- No power on full tank.
- blue headlights???
- UR UDP prototype installed today
- me and my random ideas...
- Borla Turbo Muffler
- The BEST news ever!
- Transmedic Works!
- Question about bulbs...
- pic of my car
- My maxima run like crap 94 single oh
- Need new starter
- Just got my Popcharger!!
- Newbie question
- 89 Max ballpark price
- Cannot Decide on PR CAI or WSP CAI... WSP just can't get them in.
- Pop charger noises (besides the growl)
- mmmm boxes that arrive at your door...
- weird timing or fuel/air condition
- Brakes noise
- 1157 LED bulbs... better than normal 1157?
- Car body(paint and washing) questions..
- Interesting problems... All related? (Long)
- Pass them suckers
- axle popped out!!! twice!!!!
- WTB: stock muffler for 92-94 SE
- Needed: Driver's Side Control Console
- CRZ Driver getting problems
- Need help in heater repearing
- I am stranded... Please Help Me!
- do bearings fail in pairs?
- 3rd gen sightings in NY
- Update: Another round begins
- spring question
- so many things wrong now
- Piece of plastic under drivers side of car
- Pain in the A$$
- Difference between a 92SE and 94SE
