View Full Version : 3rd Generation Maxima (1989-1994)
  1. Keyless???
  2. Control Arm Bushings...Type?
  3. How I fixed my stalling engine problem
  4. va sniper!!
  5. coilovers????
  6. BMW M3 headlight conversion
  7. Heater Motor died please help
  8. Drivers seat back
  9. when i start my car......
  10. Re-painting the side moldings??
  11. I'm new and I have a question
  12. My heat bites
  13. I was slow but I took out some "Uncle Ben's" Boys
  14. Trunk Spoiler Rust
  15. how do i determine the model i have?
  16. how do i determine which model i have?
  17. is there any hope at all for a...
  18. What's going on with my A/T?!
  19. what's the best 1/4 mile for a n/a GXE?
  20. question question question
  21. is advancing the timing only for auto?
  22. Mods and Life expectancy
  23. power steering grinding?
  24. Pull to the left?
  25. 1992 Nissan Maxima SE
  26. Bad mileage, rough idle
  27. diagnostic at mechanics
  28. Installing rear 6x9 speakers HELP!
  29. '93 Maxima Steering
  30. Side Skirts
  31. Recalls
  32. CV boot replacement--Yes, Again
  33. anyone tried PFR5G-11?
  34. Transmission
  35. SE cluster vs GXE cluster
  36. Fuel injector harness help.>>
  37. Bodykit fitting
  38. 89 GXE parts for sale
  39. for the newbies asking for cheap mods...
  40. cup holders
  41. Autometer tranny temp gage still doesn't work
  42. New best 1/4 time but not what expected
  43. Not only is my speedo not work, but my OD as well?
  44. knock sensor removal..what size socket do I need?
  45. Body Work done pics* w/ shaved trunk
  46. Pacesetter STS
  47. What to do with my intake....
  48. VG30 intake, not VG33
  49. Pic of my 89' SE on 18"s...
  50. Muffler fell off today and it sounds awsome!!!
  51. Can BOSE headunit be used in regular Active System Maxima?
  52. Broke window, what to do?
  53. Window problems
  54. hey all, redone my site, check it out?
  55. BMW Headlight conversion and speed dif.
  56. ok i need to know this
  57. Has anyone experienced this problem w/92-93?
  58. new transmission?!
  59. White-grey smoke coming out from muffler for more than 10 minutes in the morning
  60. Car won't start when it rains.
  61. Will SE (white) gauges work perfectly in a GXE??
  62. Place with specifics on installing CAI?
  63. How to remove ABS Sensor
  64. Biggest worry of getting an SE...(VTC)
  65. Accord Intake sucessfully installed on 94 VG
  66. where does my head temp sensor plug in?
  67. Web page for max timing
  68. How do you install an XBox into a max
  69. Which is my '94? SE? GXE? GLE?
  70. Still the VTC grounding problem-Is there a mothed without cutting the wire?
  71. VG33 intake manifold
  72. Possible totaled maxima!
  73. 91 nissan maxima makes a creaky noise
  74. Help my clutch please
  75. My Maxima
  76. Need help someone please help
  77. i know OT, but this is what i gots now
  78. Body Dimensions for 3rd Gen
  79. feeling vibration at idle
  80. Engine stalls/surging at idle/low speed especially at cold
  81. Nopi 2002 Pictures
  82. Heater Core Replacement
  83. best strut for money
  84. How many 5spd SE 3rd gens that are red?
  85. How many 5spd SE 3rd gens that are red?
  86. Loud ticking noise..lifters?
  87. Terrible vibrations when accelerating
  88. HAS ANYONE REPLACED A 5-SPD in92se??
  89. Thanks! Still more problems with SE......
  90. Problems with power steering...
  91. best way to clean engine bay
  92. Cooling fan p/n
  93. Lower control arm
  94. Abs
  95. Bose speaker blown amp?
  96. can i see the lip?
  97. Maxima at the auction
  98. cheap o2 sensors?
  99. intrax fatigue
  100. How to remove factory Bose single-din headunit?
  101. How to remove factory Bose single-din headunit?
  102. vtc grounding
  103. leather seats from 4th or 5th gen?
  104. Clunkiness in rear when shifting....
  105. 92 maxima antenna
  106. how do i remove rust
  107. Light Housing Questions
  108. Tinted Headlight Covers!!!!!!!
  109. G35 rims or 21k 17s ? weight?
  110. Unclipped Air Box = Burnt ECU
  111. ss brake lines
  112. Engine surging/stalling/stuttering.
  113. Waxing Stains
  114. kinda dumb... lost picture
  115. cai
  116. Mirror-Polish Stock Rims...?
  117. If it weren't for bad luck I would have no luck at all :(
  118. 3rd Gen Stillen Kit...Check it out
  119. Lightweight wheels
  120. Pop Question Hotshot!
  121. Engine quits when transmission is engaged
  122. Flushing the radiator
  123. Fuel Injector?
  124. Non Freon Conversion--92 Maxima
  125. Matt did you relocate your cv boot pictures?
  126. Camshaft timing
  127. what kind of kit is that
  128. My speedometer went out...how do I fix it?
  129. cut intrax
  130. My poor side mirror...
  131. Power steering moooaaanns like a B**CH
  132. re-pinting bumper...
  133. Created New Car Domain Page...please See
  134. differences in ypipes
  135. Help with Vapor Recovery System
  136. Max Carpet
  137. HELP !! EGR Valve solenoid
  138. 92 Max w/trans problems $1599 to fix???
  139. fell off ramps
  140. Rear Brake Installation Nightmare
  141. alignment job question
  142. a/c getting weird on me
  143. How bad did I mess up my MAX?
  144. EXTREME newbie questions
  145. What is rice/ricer?
  146. Dash kits
  147. clear corners
  148. car wont start
  149. Having Problems with Cardomain site...Please Help
  150. which to do first?
  151. 3rd Generation door locks in cold weather
  152. For anyone that knows some stuff on turbos
  153. 2k2 Muffler
  154. Thinking about a 5 speed manual conversion.
  155. engine stuff
  156. OK, newbie's got some questions
  157. R33 tailights??
  158. CV Boot replacement
  159. Updated the cardomain site w/ new pics>>>
  160. Need your opinions
  161. Speaker
  162. Check out the new website...click on homepage<
  163. Distributer Cap and Rotor
  164. Possible side effect of lowering springs?
  165. is my tranny goin?
  166. apc filter.. wow
  167. timing belt change advice?
  168. what's going on
  169. New Look
  170. Updated my cardomain page! New Pics.
  171. re: repair the defrost light button
  172. WTB: Fuel injectors
  173. Are 95 Max Springs Same As 92????
  174. accident in my maxima today...
  175. A pillar removal?
  176. Help Real Quick!!!!!
  177. Rear brake pads?
  178. Sprint springs and stillen kit.
  179. engine crossmember...
  180. J-spec Gearbox question
  181. Tranny noise?
  182. Got dropped by a cadi
  183. 92 Max Se 5-spd For Sale
  184. Psyched!!!
  185. couple ?'s
  186. Automatic q.
  187. How do replace my shifter bushings??
  188. Remote keyless entry/part of Remote start install
  189. Trunk light location?
  190. New front bumper
  191. problem with amp install w/ bose
  192. Twin turbo Maxima?
  193. What do you think of these springs? Springtech
  194. fog replacements
  195. Replaced my fuel filter today
  196. I think Ball joints are gone need HELP
  197. At cross roads..!! please help...
  198. wow.. flushed ATF...
  199. Struts/Springs/Whatever
  200. WTB: 3rd Gen 5 Speed
  201. how would 17 x 7.5 rims with 205/40 tires fit ?
  202. I finally have created a cardomain page...
  203. Hood Pins 4 my CF hood
  204. ASP UDP Review
  205. Tight Tie-rod end bolt $%&*????
  206. Reverse Lights
  207. Transmission fluid question
  208. Price on Shaving doors?
  209. BMW headlight eyebrows installed
  210. Judge Judy
  211. VTC vs. Timing advance
  212. Do Springs go bad??
  213. Please advise! Periodical vibration...
  214. Pics of 3rd gen cf hoods
  215. *help* Corner Turning Light Istallation!
  216. Help with clutch install
  217. I Have A Gxe But!!
  218. Left corner light and turn signal
  219. 170k and first BIG problem (transmission?)
  220. Some new pics...
  221. exhaust leak
  222. 20in rims
  223. spark plugs again
  224. 90 GXE auto Fuel Gauge doesn't read full
  225. please advise! 225/60/16 too big?
  226. Stillen Body Work
  227. CF hood pics and lots of other pics....
  228. high speed flasher for turn signals
  229. Wing West Body Kit
  230. WSP y-pipe + hi flo cat makes a big diff...
  231. A/C Blower Woes
  232. goto group deals for a stillenbody kit
  233. HIGHLY Recommended CLutch Flywheel setup...
  234. To MOD a GXE, or save for an SE...?
  235. More clutch
  236. hey plz reply
  237. Arg, having some trouble. kind of long
  238. Updated CarDomain page:Nopi & mesh grill
  239. hey yall check out my Web page
  240. the downfall of the maximas...*dun dun dun*
  241. Aftermarket keyless entry, alarm's got mind of its own.
  242. Looking for an FSM for a 93' SE
  243. Nissan Dayz
  244. Security System Question 2
  245. Power window woes
  246. I have two cracks on my dashboard.Can this be repaired?
  247. Perfect newbie question
  248. ATTN: JWT ECU for VE owners!
  249. where are you guys from?
  250. Security System
