- Where do I mod next
- Syncro problem?
- transmission problems? please help.
- Nissan Catalytic Converter $50 Billion Dollars
- Indiglo Gauge question (they're already installed and working ;))
- 1993 Maxima with enacurate speedometer
- fuel pump
- Best tire size for 17" rims?
- What is the best way to remove a GOOD exhaust manifold stud?
- tinted windows/ inspection
- What's the speaker sizes for the 3rd Gens (non-bose)?
- Help uncloggin sunroof drain hoses
- Has anybody used the weaponR ram air intake?
- Piccies of my maxima
- whats the best suspension?
- broke a spring!
- PIAA Fog Light Models???
- Why does everyone hate the VG ?
- my moaning max
- 1991 SE Max ???
- Heat Shield Y Pipe Rattle
- Please Help??????
- Whats the first suspension upgrade????
- James..urgent read..
- need help w/92 Bose system
- Need help with my sister's 91 GXE
- Anything else to use for custom CAI tubing then flex pipe?
- what to do with pictures?
- Engine running rough
- winter
- big max needs an engine
- Power loss from exhaust leaks?
- Anyone tried that B&M trick shift trans fluid?
- Touchup Paint that Matches Factory:Where to Get
- 92 Maxima SE Running Like a TOP!! FINALLY
- tranny question..........?
- UR pulley installation estimate
- Loose Hose On Back Of Motor???
- Replacing Window Regulator
- Bose Relay question
- carsound cat
- smells like clutch burning WTF!??
- cam gears
- steering wheel problem
- I need power seats
- Please confirm parts needed (broken exhuast stud)
- Custom cat back?
- Customized cold air intake
- Is there a known problem with 3d gen fuel pumps?
- I think its a 93
- will 19's fit?
- auot tranny vacuum hose
- Clutch pedel questions??...Kinda URGENT
- That odd cylinder in the back of the rear arm rest.
- Plastic Engine Guards
- after seeing this i feel stupid...
- Tires for 16in wheels
- 2-3 cutloose 89 maxima
- Miles on a Maxima
- Lowering Springs
- Head Unit wiring cut...
- Planning to get stock Skyline R33 wheels
- Update on my Max accident.
- I Got A Big Problem And Need Help Fast!!!
- Parts!
- replacing disc brakes with ABS
- BMW headlights
- My car starts up strangly, and BMW lights
- '89 SE nightmare: intermediate stalling at any given time
- MAXIMA rear emblem question
- Turbo on 3rd gen
- 3rd gen, so many questions on my mind !
- Pics of my LCD / GPS / MP3 setup
- Lots of new pics...
- how many quarts of ATF
- wheels
- My newest "Mod"
- Is it possible to use a different model knock sensor?
- 17" 350z rims
- Daytime running lights problem
- Startup story ... Happy Ending
- ARGG....Dyno results inside>>>
- ypipe or manifold studs?
- Heater question
- ? on Sparkplugs
- It's all James' fault
- Macco paintjob.....
- real wheel bearings
- Genie Turbo 3 inch Stainless steel muffler for maxima
- need measurement
- general 3rd GEN questions
- where to buy ve30de??
- Engine management systems
- 3rd gen sighting in a magazine
- Removed my A/C compressor belt....Now no heater or a/c working!! HELP!
- Is this car worth buying ....
- 92 Maxima SE think I have problem Solved
- *** Anyone removed their tailights here? ***
- Apexi World Sport Exhaust ?
- Reset ECU after advancing timing?
- VG auto ran a 14.588 Record????
- Pathfinder intake
- Should I remove the exhaust manifolds?
- Open My Hood!
- Wheel ?
- tire pressure (2)
- Hissing/Rattling noise
- fuel leaking out guestion,
- Pezking4
- A questoin for someone who knows
- Moderator type question
- replacing bulbs on rear
- I Really Need Help From An Experienced Member
- raxles.com quoted me
- ypipe question
- Any one know how to disable the ABS?
- nokya purple
- pic
- Fuel Tank
- 1992 Maxima SE dumping fuel
- First Time under the hood
- tire pressure
- Engine sounds supercharged, wish it really was.
- Is it a good idea to have my fuel injectors flushed?
- Just bought a 91 SE
- AAAAAHHHHHH *mixture of cry/ yell*
- kyb agx
- digital dash
- 17" Tires Sizes
- motor swap
- rough idle
- racing...
- TIe rods or tie rod ends?
- The Mystery Spoiler: Identification
- How do you smoke your tires really well?
- DNAS420 back on the org??
- HELP!!! --- Chilton's CD Manual
- o2 Sensor replacement
- budget ypipe
- Altenator
- body kit info
- Smell gas (rookie needs help)
- lance...about speed sensor (dont know user name)
- Unorthodox Racing Underdrive Pulley Question
- Upper rad. hose leak...
- Basic Info How to Turbo Any Car Properly (NO BS!)
- ? On a Used 89 SE I bought
- anyone here with greddy?
- Broken exhaust manifold stud...is the entire hole threaded?
- How Can Put My Maxs Pics
- lights any idea's
- changing fuel lines
- Shift Kit on a 93 GXE
- Exhaust Manifolds........?
- Water Pump.......?
- Bose system fails intermittently
- 3rd Gen on Fairfax
- Seat belts and power locks out hmm???? help?
- maxima with octane front
- SE wheels
- "ticking noise"
- 19,000 mile maxima
- hey guys, do 3rd gen BOSE SYSTEMS have CD??
- Problems with '90 SE
- A Different Accord intake question
- Fuel Leak
- Wheel Bearings??
- New rotors or just brake pads?
- Eazy Brake Light Fix
- bmw headlight question
- J-30 need assistance
- A little run in with a NJ State Police
- Tranny problems
- Few changes on the max...
- JDM Engines: Where is a good place to get them?
- Any body for a wheel hub ?
- Just Ordered My New Exhaust System
- Oil Switch
- Max sold, who needs a FSM ??
- where to find e36 elipsoids
- new pics with Cobra SVT rims
- Problems with radio and electrical system
- Dame Trees!!! (accident)
- Hit and Run
- Fan Motor Replacement?
- fans not shutting off
- ATF & Filter Replacement
- for Pioneer Radio owners
- Car is freaking out suddenly..
- weird sound
- 4th gen springs on 3rd gen???
- Thermostat replacement??
- Y pipe with B pipe
- hydraulics?
- o2 sensor
- good price on SE?
- Headlight Socket Meltdown
- alignment questiom
- VE rebuild...parts?
- VG30ET proof, for those who need
- Another 3rd gen gone........
- I am totally baffled on this one (a little long)
- Where can I go to learn more about cars?
- Are the ecms interchangeable for 89-94?
- VG30ET for max
- 1992 Nissan Maxima Fuel Pump
- I know this seems to be a bad word but I have a question about Earl Scheib???
- know a good shop to go in Pasadena, California?
- Timing belt replacement
- Question on addco rear sway bar
- MAF Sensor FSM Question
- airbags
- OK, an end to spinning the tires for 3 sec with an auto
- Warpspeed Y pipe / ECU question
- Grounding VTCs actually engages the sprokets
- how to remove windshield trim
- cai intake hole
- c.v. shaft question. . . .
- I guess this is goodbye....
- Max suddenly running poorly - seeking diagnosis
- 15" Alloy Rims
- Do not prompt what oil better...
- Strange o/d button issue...
- trani oil which is the best ?
- Are SS Brake lines worth it?
- someone cracked my plastic trunk "taillight"
- Carbon Fiber hoods
- Another IDLE question
- for all with low profile tires
- Digital Clock in Dash/91MAX
- got cupholder tonight
- installed ypipe
- What's wrong with my alarm?
- will probe rims fit an 89 se?
- Taping sound in dash when key turned to ACC
- greddy...exhaut
- camber
- painted interior
- Steering wheel crooked after aligned????
- CF hood came yesterday!
- NTK sensor in Bosch box please help !!!
- rusted rotors
- Tire Selection.......
- I Ordered My Maxima.org stickers and......
- Problem with 1st gear
- car key is stuck in ignition
- Fuel Smell and o2 sensor, need help
- Please Help!!!
- simple question about gas gauge long explantation can you help
- engine replacement, but how far can it go?
