View Full Version : 3rd Generation Maxima (1989-1994)
  1. High performa exhuast sys.
  2. trans. oil change 94 SE
  3. new fuel injectors
  4. Bumper cover, OEM or cheapo?
  5. Need some help...
  6. Need Help - Can't remove driver's side CV halfshaft
  7. Learning how to solve my own problems?
  8. VE vtc's/vq35 vtc discussion..
  9. New Pretty Pictures And Videos of your Max Thread!
  10. I'm about to give up out of frustration
  11. ford 302 into 3rd gen
  12. Hungry Oil pan
  13. heater motor won't stop blowing in acc/on position
  14. Oh no it's cold and my car won't start.
  15. Floormats
  16. Maxima would not start
  17. Thumping sound when engine is cold
  18. Quick question
  19. Attn Chicagoland 3rd Gen Owners!
  20. Better TB coolant bypass method.
  21. Testing Injector resistance
  22. Clean your Throttle body!
  23. So you think you had rust problems...
  24. Bose Radio ???
  25. Steering issues..
  26. An interesting trip to work (electrical woes)
  27. GXE pulls to the right on acceleration
  28. Engine Problem or Tranny?
  29. Transmission failing...thinking about parting out the Max
  30. Hey, Cliff!
  31. I will be doing the whole exhaust system
  32. ECT Nissan VG OEM part numbers?
  33. power problem once again
  34. Need Help with 1994 SOHC
  35. Third gen is Decembers MOTM!!!
  36. FYI --> Blinking Air Bag light
  37. 5-Speed Swap Here I come
  38. Happy Bday MyGreenMax94 ** 56k Go get a bowl of cereal**
  39. My New Forum for balla mechanics!! :007:
  40. Idle fluctuation when brake applied
  41. *NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
  42. Front Bump Stops
  43. Busy weekend. (mods/repairs)
  44. Different Cranks in VG?
  45. saw on ebay wat yall think.......
  46. looking for thoughts on this problem
  47. Car stalling - Any ideas?
  48. just picked up a 90 se
  49. Has anyone tried?
  50. Soft top of doom...
  51. R.I.P 89' Max :'(
  52. Yes finally fixed!!
  53. quick VIN question
  54. 3rd Generation Forum Guidelines (Please Read Before Posting!)
  55. Alternator diode pack(where to purchase?)
  56. want anthor car dont know what to get
  57. I dont think this is good =\
  58. Brake Question
  59. nOOb question!!1!!
  60. Radiator
  61. What's the 4DSC?
  62. Some pictures of Max and CG2s max in the snow
  63. I screwed up, front tire bent....
  64. another exhaust problem
  65. My dedication to 3rd gens
  66. Random stalling
  67. quick q
  68. Anyone sold or bought a SE auto lately?
  69. What to look for?
  70. Fog Lights dont work
  71. what a difference a day makes
  72. Seatbelt Warranty
  73. Creame Colored Maxima Owners
  74. Project OCD Engine bay.
  75. self destructing brake light
  76. Auto seat belt not working
  77. Where's the airbag control module?
  78. Good bye crankshaft.
  79. Help with remote start
  80. random battery / abs light blinking
  81. Still have exhaust leak.
  82. taillight assembly... disassembly
  83. Fuseable Links
  84. AC/Heater Floor setting acting weird
  85. Rear MAXIMA centerpiece LED (pics)
  86. Weight Reduction for All GXE Owners
  87. Allen head size on intake plenum
  88. What needs to be removed to drop a tranny?
  89. Best way to clean around spark plugs
  90. phantom highbeam
  91. Freakin bearins are goin bad AGAIN
  92. My Fresh VE Swap (ALOT of Pics)
  93. Replacing Vacuum Hoses
  94. No fuel smell but it was leaking
  95. Some problems while trying to replace my ball joint
  96. abs
  97. Stumbling, injector problem?
  98. Maxi for sale
  99. Anyone want to rebuild my vtc's?
  100. VE question
  101. Clutch removal day
  102. MAX won't start
  103. Car makes a pop sometimes during acceleration..
  104. How do you bench bleed a master cylinder?
  105. grounded my VTC's......
  106. Alarm, Remote start install
  107. Pics of the new max 56k beware.
  108. 90 Max runs great when cold but rough once warmed up
  109. Vg INTAKES
  110. Battery relocation
  111. Oil Leak
  112. Ticking sound when i turn on the heater
  113. cheap superchargerd
  114. Weird clanking noise under hood
  115. did I get ripped off?
  116. Ebay suspension question
  117. grounding wire ques?
  118. Knock knock..
  119. 300zx exhaust manifold???
  120. question about front end shaking......
  121. L.E.D Install
  122. NEW MODS
  123. Proportional (brake) valve rusted?
  124. Both CV Boots torn - help
  125. help-remove the crankshaft pulley on 89 maxima
  126. Valve cover moddys
  127. Idle Bad when cold, Improves with warmup..
  128. Antenna Mast Replacement Videos. No more Asking!!
  129. Heater experts, drop some knowledge
  130. Windshield Wiper Linkage Q!
  131. Seat Belt warning chime and light
  132. Chime
  133. Which Battery
  134. 1990 Maxima SE running inconsistently
  135. VG tbelt sprockets
  136. Guess My New Mods..
  137. It's Official: Maxima is Parked for Winter
  138. Which wire is the power antenna trigger?
  139. Front Brake Pads need replacing
  140. new lca's
  141. Where can I get a metal maf adapter?
  142. Shifting notchy when engine on, but smooth when off?
  143. Fuel Injector additive
  144. Replacing struts (need advice)
  145. 93 Maxima GXE Fuel injectors
  146. Whats needed for 5-speed Swap?
  147. new alty and battery, but still fading lights??
  148. 3rd gen automatic Maxima does 12s in the 1/4 mile!
  149. YAY!..I'm keeping Blackmax :-)
  150. Just did rear disc swap on le GXE BUT....
  151. 92 SE isssues please help
  152. Fuel Pressure Regulator
  153. Warning to all 3rd gens out there!
  154. Broken/Dead Max, electrical?
  155. repair the door lock actuator
  156. Anyone knows ECU?
  157. cheapest place to buy crossed drilled rotors
  158. 94 Max GXE on the Blink - SOHC Auto
  159. Disconnecting torque converter
  160. Leaking brake line
  161. Went to the dyno today
  162. rear strut "clunks"
  163. 5k into my max, worth it?
  164. Turbo Charger for a '90 Maxima SE
  165. I'm Snow Upset
  166. How many/what kind of bulbs behing dash cluster?
  167. 300zx brakes size
  168. many oppurtunities need you guys to chime in
  169. Low Compression
  170. Few Questions?
  171. I know there's an audio forum, and I hate posting another speaker thread.....but.....
  172. Just wondering......
  173. Rear valve cover gasket
  174. Brake question
  175. "P" light comes on at start up...
  176. SOHC vs. DOHC
  177. Bad suspension bushing
  178. timing question.
  179. Removing the VG
  180. Got Me Some Fogz
  181. Synthetic MT fluid in the VE?
  182. Installed LEDs today...
  183. Installing an AMP in a 1993
  184. Odd Shift Interlock Prob
  185. Big break for the Max
  186. Gas tank
  187. Rusty
  188. Removing VG transmission
  189. Suspension
  190. Distributor Problem
  191. Fixing manifold studs...
  192. Driving a max with a bad injector
  193. Driver side halfshaft
  194. Bose Issues
  195. Tranny - Engine Mating Question
  196. My BOSE died!
  197. 4th gen injectors in a 3rd gen?
  198. Uh Oh! Another VTC thread!
  199. clock problem...again
  200. At last the tranny, clutch, and flywheel are off!!11!!!1
  201. extreme humidity causing FOUL smell
  202. Car stalling, please help with diagnosis
  203. Replacing steering wheel
  204. Weeping oil
  205. Brake calipers
  206. Axle Rusted stuck
  207. hood lift supports - where to buy
  208. 92 Manual trans locked up?
  209. Max Won't Start, Error Code 33
  210. ATLANTA MEET 2MORO!
  211. just picked up a 91 se
  212. NEED HELP with my MCC (manual climate control) PLZ HELP
  213. Computer boxes
  214. EZ out size for Manifold Studs
  215. Hey guys..need your support!
  216. clutch issues
  217. Tranny cooler received
  218. How To remove/rewire bose for aftermarket
  219. HD Radio
  220. Another Maxima!
  221. Best way to prep for sale
  222. O2 sensor question
  223. posted in the audio forums already but.....
  224. Two whole months of Maxima ownership!
  225. NEW EXHAUST VID!!! 2.5" all the way...
  226. I'm stupid and poor and need help.
  227. what do you think?
  228. (Code 33) But Not O2 Sensor?
  229. car starts, car doesn't start, and repeat...
  230. Another unidentified hose
  231. HID
  232. If Cars Could Talk, Do You Think Mine Would Thank Me?
  233. drivebelt replacement help
  234. Shock Sensor Add on..
  235. Pigtail connectors.
  236. Thinkin about sellin the VG...
  237. collection terminals
  238. Remote Starter Options
  239. Window and Climate Control problems.
  240. Heat...
  241. Max shaking and stalling
  242. mystery terminal
  243. Coolant Temperature Sensor
  244. questioning the y-pipe
  245. VG compression ratio
  246. Deatschwerks Injectors.
  247. More VE goodies!!!11!!!!1
  248. Aftermarket fog lights hook up!!
  249. Help with rough running / codes 21 33
  250. Bumped into an old friend at the junkyard
