View Full Version : 3rd Generation Maxima (1989-1994)
  1. Rough Idle when ingine is warm..What in the hell could it be?
  2. Speedometer & Odometer problem on '90 SE
  3. Help with shift lever lock-out on '90 auto
  4. 14 mpg!?!?! This car sucks!
  5. Help w/ Alarm problem
  6. How Easy Is It to Install....
  7. new master brake cylinder and dimming clock
  8. I can't understand my idle
  9. Does anyone know anything about AT Italia -->
  10. idler pully.... hissssing???? wtf
  11. Exhaust Problems
  12. Ebay Prices
  13. 93 max FSM
  14. Strange Sound while turning...
  15. magnaflow dealers
  16. Need some help...
  17. VE30 Rebuild
  18. Need help with finding tie rod end bushing/grommet
  19. Moderator
  20. Bags or Performance?
  21. Any ORIGINAL Owners Out There?
  22. New DVD Pictures!
  23. Rear end problems, need advice.
  24. Venom PCM
  25. Survey: B&M Trick Shift fluid
  26. 94 SE O2 Sensor
  27. Drove off a curb
  28. Rear Defrost
  29. Whats this?
  30. JWT ECU $$...is this right?!
  31. Gas mileage & Broken exhaust studs
  32. how to remove crowl panel?
  33. Best Octane To Use In VG30 Max?
  34. Battery and Brake light, Alternator
  35. Exhaust Stud Replacement? where?
  36. Variable Valve Timing, 1992, someone please tell me about it!
  37. I WANT 240 hp
  38. Fuel Filler Recall Update (I just cant win)
  39. Instrument Cluster from a '92
  40. Single disc player for 3rd gen
  41. Maximum Tuning VB mod problems.
  42. O/T: did your forum color just change...
  43. What IS coming out of the muffler?
  44. Stock Bose/Sony CD player
  45. water pump not so bad w/ help
  46. Bad ECU :(
  47. 6th Gen, 3rd Gen
  48. 2 Days In The Shop!! (recall)
  49. intake tubing
  50. Safety/accident stories? auto shoulder belt?
  51. ECU Setting
  52. re: oil burning smell
  53. 6th Gen Maxima
  54. Stereo Problems!
  55. Tranmission or ????
  56. maxima despair
  57. maxima despair
  58. 0-60 times?!
  59. unsteady idle after system install....
  60. Anyone replace tie rod ends?
  61. White 3rd gen in super street
  62. Intrax or ST's in the from, Eibachs in the back??
  63. Normal RPMs??
  64. Idle rough when warm
  65. Question about cryo treatment
  66. odd engine noise, suggestions?
  67. Dumbest thing u did in the snow in your max?
  68. High Idle
  69. my 3rd gen has a crazy-irratic idle in gear
  70. Aftermarket Steering wheels
  71. Cylinder Head Temp. Sensor DEAD!!! HELP!!!!!!!!
  72. Cost to rethread Engine Coolant bolt hole.....
  73. Hot & Cold air selector is stuck.
  74. struts and stuff
  75. Gruggling or water sound from dash
  76. Fuel Injectors - Black or Blue?
  77. If You Have a '90 GXE
  78. How much does the 5-speed tranny weigh?
  79. 92 Maxima Heater Issues
  80. weight differences
  81. high vs low idle
  82. monroe sensa-trac struts/shocks
  83. are e36 same as e38
  84. Would 5 spoke look better than 6 spoke?
  85. Need adapter to fit 2 din Bose HU in my 91
  86. Hey I know you guys must know what to do!!!
  87. Hey I know you guys must know what to do
  88. R.I.P. Jagworks
  89. What to buy?
  90. Tempermental Keypad
  91. Idle control screw??
  92. Funky Heater!!!
  93. Seatbelts
  94. Power Steering
  95. Poll: important decision
  96. Using stock rotors with 300zx calipers
  97. Problem with Keypad/Security System ?
  98. Does Anyone's Heather Totally Suck??
  99. New Pics
  100. Battery Options
  101. Mounts
  102. Rear and front speaker install...
  103. butterfly knife key
  104. Help! Broken antenna mast!
  105. pace setter short throw shifter???
  106. Automatic Tranny Survey
  107. car sluggish; slow trans. fluid leak (i think) or is it bc of the cold?
  108. Water pump replacement..............Check this out for me..........
  109. fuse keeps going out
  110. Thermostat on 91 Max?
  111. Degreaseing
  112. idiling
  113. shaking
  114. Weap Hole Blues
  115. adj suspension
  116. Shocks
  117. R-33 tail lights
  118. Dash-Switches bulb replacement
  119. What's the best degree to set the timing to?
  120. I need pwr Antenna
  121. gxe cup holders
  122. Misfiring and window not going up
  123. LCD Display for MP3/computer in trunk
  124. Transmission, Replacement Questions
  125. Replaced Master cyl and ABS pump still spongey
  126. soon to get a new maxima got Q's
  127. Bose radio suggestions
  128. Bosch O2 sensor: compatibility issues???
  129. VIN lookup
  130. Need info, think I have a floating valve
  131. intake maf adapter
  132. Great Deal On Bmw Ellipsoid W/ Halo!
  133. Anyone have Pics of a Maroon SE with Black int
  134. Do 1993 SE's have airbags?
  135. Greddy Exhaust and y pipe
  136. 300 zx shifter
  137. How can I fit a CAI in a VG?
  138. axles qustion
  139. Grille
  140. Hood Hydraulic Arm Props
  141. Vtc??
  142. Dead Cylinder Or Injector Seal Leak
  143. i need some info guys???
  144. Split Fire Spark Plugs
  145. 300zx headers?
  146. Z3 fender thingies
  147. Rubbing when lowered?
  148. Poor mileage
  149. Anyone Have Pix of Pearl White Max w/Stillen kit
  150. Bose HU problems and replacement questions
  151. crazy tach at low speed -->new car?
  152. Thinking of switching over to Intrax
  153. Engine Temp(remental) Gage
  154. VG-VE engine swap???
  155. Problem with "door locks & headlight/ignition key warnign chime"
  156. SO, Camber kit? HELP!
  157. alternator
  158. windshield removal
  159. Advanced Timing VG
  160. O/t...
  161. What can I do for the rear of a GXE?
  162. BYE BYE Maxima
  163. Snow driving
  164. WSP Y-pipe and HORRIBLE mileage
  165. New car decision
  166. Do I really need a camber kit?
  167. some fuel injector pics!! the good & bad
  168. need some help! with recall
  169. Spoiler Question.
  170. New Unorthodox Racing UDP question
  171. Anyone know about ground wire kits?
  172. Stereo channel display OFF.. then ON, then OFF!
  173. Slow performance in first couple seconds....
  174. Struts
  175. Winter driving
  176. Can't buy the ECCS Relay. What's it called that parts dept will understand?
  177. How Low Can You Go?
  178. Clock......
  179. Aftermarket Remote Entry Systems
  180. Does Anyone Know Who This is?
  181. gaw (story time!)
  182. 3rd Gen Meet!!! L@@K
  183. VTC's may be going
  184. CD changer question
  185. If you couldn't get another 3rd gen...
  186. heating problems
  187. starter woes
  188. What's the dummest/regretful thing you've ever...
  189. It Stinks
  190. Car shakes when letting out clutch in 1st(or any gear)....
  191. Cold Weather and Brake Problems.
  192. F/S--'91 Maxima (Tallahassee, FL)
  193. Camber adjustment
  194. So how long can I go without.....
  195. Those of you with worn control arm bushings...
  196. bose relay......I've searched!
  197. Vacuem Leak
  198. Just bought a 92 MAX
  199. Anyone need a motor from a 1990?
  200. One More Problem To The List. HELP!!!
  201. Just bought 1992, Need help on spuddering problem...
  202. Exhuasts, Y/B/X Pipes, Cat. Converters
  203. Some newbie questions regarding flexaning motor mounts....
  204. weird electrical problem
  205. Aiming Headlights
  206. Painted Trunk Reflectors?
  207. Update, but still need help ('89 SE nightmare: intermediate stalling problem ...)
  208. Car is Veering
  209. Grinding Sound
  210. Possessed gas gauge
  211. Window Arm Gone
  212. Problems with my '89
  213. Transmission or Something Else?
  214. Paint Quality/Durability
  215. fuel pump problem
  216. Maxima...Too Fast?
  217. Speed bumps
  218. Belt Squeal Question
  219. Installed Courtesy Clears...
  220. This nasty stalling problem again - sort of found where
  221. timing or fuel injection problem
  222. Way to go Chris
  223. stillen kit
  224. Not impressed at all!
  225. 24 Valve 91 Max?
  226. Starter and other qs.
  227. I have a big problem with 89 Maxima... Need Help!
  228. Where did the Brake Fluid go??????
  229. Favorite Maxima
  230. Valve Cover Gaskets
  231. Abbreviations...READ!
  232. How Many Miles....
  233. manual trany problem
  234. tick, tick, tick...not VTC's!
  235. Question on 1994 Acura Legend
  236. RosenKen, does the knock sensor have a ground?
  237. Foglights on 1990 SE
  238. Exhaust
  239. Lights, freezing and jerking ...help!
  240. Maaco and Earl Scheib question not about paint though.
  241. E brake light
  242. Not modding up my max anymore
  243. Ice on AC unit
  244. Stillen Body Kit
  245. Some 3rd Gen. questions from a Newbie...
  246. Please help - engine prob??
  247. power/comfort switch?????
  248. Manual trans fluid???
  249. Fog light problems
  250. Headlight problems
