View Full Version : 3rd Generation Maxima (1989-1994)
  1. IS300 muffler, a success!
  2. Please someone stop the hesitation
  3. Digital Dash
  4. rear speaker and cover
  5. rear speaker and cover
  6. Horrible starts
  7. Help MAX O/D
  8. New Record!! 14.93 @ 92.61 for a NA VE Auto
  9. My baby is gone, and I miss her already
  10. help on identifying
  11. My Mechanic Says...
  12. Has anyone done turbo on a VE before?
  13. Will VQ turbo manifold work on VE?
  14. Broken Manifold Studs !!!! $$$
  15. Source For tail light lens--92 Maxima
  16. Anyone in Colorado have a hood lying around?
  17. High (1000-1200 rpm) but stable idle with occasional surge to 2000rpm
  18. BIG mistake at 2am - Cross threaded Traverse Gusset?
  19. New pics from New Zealands very own!!!!
  20. fuel pressure regulator
  21. Lowering Springs
  22. Tranny dip stick
  23. My New Cardomain
  24. How to remove trunk lock key cylinder?
  25. no reverse lights.
  26. steering moan.
  27. Engine conversion
  28. Manual Tranny Issues
  29. Power Window problem. Please help
  30. what would happen if
  31. Windshield Wiper Linkage
  32. Auto to Manual, Maxima self-converts, details inside
  33. Electrical problems help!
  34. engine work as to heater
  35. Heater Solved
  36. How the hell do you get it off!!!
  37. carfax done
  38. Whats with the brakes?
  39. Big Problems!!!
  40. keyless entry pad bad on cold days
  41. Good news on tranny problem.
  42. Cap and rotor from Advanced Auto parts
  43. Wipers Linkage
  44. Gas Leak
  45. VTC Rewiring
  46. cd player
  47. Maxima V6 3.0 Repair manual.
  48. Looking for Opinions: Spoiler
  49. indiglo gauges
  50. Y-Pipe
  51. Exhaust manifold leak?
  52. Intermitent Starting
  53. Idle Issues since shortly after Knock Sensor Job
  54. Chugging like a diesel ! Help me!
  55. prefromance question
  56. bmw head lights
  57. will this be ok
  58. door hinge replacement...
  59. VTC's
  60. pics of 5th gen wheels on a 3rd gen
  61. my max is finally in the shop
  62. sound system
  63. strut bar
  64. New Pics from me.........
  65. Strut Recommendations
  66. buying maxima
  67. what does this wire go to?
  68. Troubles with my MAF
  69. Pic Comparison: Stock Y vs. WSP
  70. ok heres the update on my problem
  71. will these fit without , any trouble?
  72. Windshield wiper problem
  73. heating issues
  74. RPM's while at idle
  75. KYB Rear Shock Catridges
  76. Funny smell while at idle.......
  77. HUGE turning radius!
  78. Struts for a 94 SE Max
  79. VE Hores Power Mods
  80. Water pump write-up???
  81. Woohoo!!! Happy B-Day To Me!!!
  82. 90 GXE: Digital Dash issues...
  83. Premium petrol
  84. Merry Christmas for cryin' out loud!
  85. can some one please help me out
  86. Motor Mounts bad, or something worse?
  87. Heater question (brrrr!)
  88. 92 Gxe Wont Start In The Rain! -- Help!!!
  89. no power whats the deal
  90. imported engines
  91. Need Help!!
  92. VE 5-speed bolt to a VG?
  93. Merry Christmas
  94. Accord intake pictures...
  95. resonators
  96. Gauge Rings
  97. MAF- cause erratic idle??
  98. Got hit today....
  99. UDP Install gone wrong...help!
  100. how do you know about exhaust studs?
  101. grogglin tranny
  102. VG Heads on my 92 SE's VE?
  103. Comparison, 90GXE and 86 SE
  104. DaBox Update...Need Tranny Advice,
  105. Survey: Remote starter add-on.
  106. Timing belt on 91 SE VG
  107. Did I install a turbo or a pop charger?
  108. Are aftermarket taillights ever gona be made
  109. HELP! Fuel Rail/Line Replacement
  110. For A/T Maximas!
  111. I need tips from u guys???
  112. Above License Plate Lights
  113. Bent Rear Strut Assembly?
  114. how do you know if transmission died?
  115. How long do the stock struts last?
  116. Happy Holidays!!
  117. Tinted taillights or taillight covers......?
  118. Quick fix for leaky flex pipe?
  119. Need new tires
  120. onwers manual
  121. What could be the problem
  122. Cone Air Filter Size...
  123. Weighed tire + rim, better than I thought
  124. Tranny Once Again!
  125. Upper radiator hose
  126. New pic
  127. electrical problem?
  128. door sills
  129. removing b-pipe and muffler?
  130. Stillen made a battery tie-down
  131. I'm so screwed!
  132. Hard Shaking at 90 MPH
  133. How much did your springs/struts/sway bars cost?
  134. High Speed Exhaust Noise
  135. Need help, alternator I think
  136. burned ground in the ECU :(
  137. PCV valve location in VG engine
  138. 94 auto trans slips
  139. overheating help stat!
  140. heater/overheating
  141. Problem: clutch pedal bracket
  142. WTB: SE taillights
  143. Yet another VE Stalling/Idle problem
  144. sprint springs
  145. This is one sweet car...
  146. shes dying!!! i need help
  147. What Have You Topped Out At?
  148. My Wheel Well Fell Off!!!
  149. Engine wont start HELP!!!!!
  150. Installation of new ignition coils and plugs
  151. Does climate control work on 3rd gen?
  152. Is it worth replacing...
  153. Timing belt broke. YAY!!!
  154. Security system affecting startup???
  155. Grounding VTCs...
  156. Need Help!!!
  157. Good Deal?
  158. would dis fit in a 3th gen
  159. got my car back........it still hesheshesitates!
  160. CAI for 3rd gen. / problems with TPR CAI
  161. Would this work?
  162. How to tell diff between......
  163. Door Lights Always On
  164. sprint springs with kyb struts 1990 max 18 rims
  165. Transmission Fluid
  166. 93 GXE engine problem
  167. Mileage on a 1992 Maxima GXE
  168. How do you know if your knock sensor is bad or going bad?
  169. who has an engine block they want to sell me
  170. how do you replace fog bulbs?
  171. Suspension Components
  172. Good source for suspension parts?
  173. Engine noise/ wine ( with radio off)
  174. Tossa Mechanics
  175. Tranny advice?
  176. Bottom Line about VTC's!
  177. Changed my spark plugs - car running real rough...
  178. Got my car back from the body shop today...
  179. Carbon Fiber
  180. Question on radio wiring
  181. 3rd Gen, Good first car investment?
  182. leather seats
  183. taking the A/C belt off...
  184. Attn: Max Owners Need Advice
  185. How to redout your tail light
  186. vacuum gauge
  187. ngk wires
  188. i need definate answers (suspension related)
  189. i though my maxima career was going to be over today
  190. antenna problems again
  191. paint prep
  192. headliner replacement
  193. Needed, carbonfiber hood,drivers side fender, blinker, and headlight,and a se grill p
  194. Special Tool(s) for Control Arm &or ball joint, CV joint
  195. Australians with maximas
  196. 94-97 Accord Spoiler Question.
  197. Power/Comfort Button
  198. .Org support please....
  199. My 89 won't start/ has no spark
  200. I think I found a replacement for Jagworks
  201. carbon fiber door pieces
  202. finally got some pics
  203. what bars are in a suspension technique sway bar set?
  204. How do I replace manual shift knob?
  205. Cold Axles = Strange Noise
  206. What's Your Tint Like?
  207. Who in Boston had that gold Max/chrome rims?
  208. eibach springs
  209. What Do I do???????
  210. Power Lock Problems
  211. Where is Power Supply to Digi Dash
  212. My New max - '92 SE 5 Speed!
  213. Digital Dash - ECU/ECM (quick question guys any and all answers are appreciated)
  214. Y-Pipe
  215. rear tail lights
  216. got my new max (pics)
  217. The buzzer-like noise & engine-stalling before engine warmed up
  218. molded stillen body kit?
  219. flywheel swap
  220. auto and 5-speed motor mounts
  221. VTC engage disengage confusion cleared up.
  222. Need exterior paint color suggestions
  223. Automatic transmission problem.
  224. After market front bumper
  225. 4th gen owner inquiring about 3rd gen Max
  226. clutch question
  227. Does anyone have...
  228. Simple and cheap???
  229. Turbo?
  230. Walbro Connector!!!!!
  231. 90 Maxima Transmission help and manual search
  232. engine problems when wet
  233. Proof of "Electric Turbo" Scam: In case you actually considered one.
  234. Bosch or NGK?
  235. Q about driving with no OIL
  236. Water pump replacement was easy on my VE
  237. Removing door..
  238. Motm
  239. Adapter for Bose front speakers in '89?
  240. Car cutting of problem....PLEASE HELP!
  241. life of a tire
  242. Question on Angel Eyes
  243. tranny question... im a newbie.....
  244. hey guys with E36 conv....
  245. Fabric alarm module location
  246. Rear Bumper Cover Removal
  247. "Y" pipe rattle problem found
  248. K&N question...............?
  249. Thanks for help.
  250. Installing 99 Bose HU, think I have it figured out
