- purchasing a mig welder
- coil overs
- crank pully
- hi everyone
- aftermarket Radio problems
- Replaced the neutral start switch (PITA)
- Tranny Mount?
- knock sensor help desparately needed
- Alternator
- transmission problems
- Aerodynamic maxima? or TIME machine? what is it!
- Possible reasons for car running rich?
- Gas leakage from a hose on the top of the VG30E head
- Front Suspension Queastion
- What's a 300zx like?
- which combo is better?
- Question from an "old" maxima member
- Who says you cant fit 10" of speaker in the front doors
- Mesh Grill
- car is making a tick sound
- ??/??/?? tire q
- I have joined the Intrax ranks
- Someone spiked the Koolaid!
- Bose amp
- Stupid tranny dipstick
- I miss my car...
- Beware...The Car Cleaners
- removing rear seat
- Link between tick and running bad
- About to sell my 90 GXE and I need some parts
- FUEL GAUGE OR PUMP? need help
- need quick help, what do you all think?
- water pump
- 92-94 SE tails.
- fuel pump
- Check out my EBay auction for tons of 3rd gen parts
- Engine swap
- Window reg attacks again!
- Recycled Injectors?
- Cost of cruise control actuator?
- 92 SE Needs new clutch.........
- Found out vibration cause: Need some exhaust replacement advice guys
- Hermonic Balance pulley?
- reuse y pipe gaskets?
- what is that behind gas pedal?
- 4th Gen Frankencar Mid-Pipe works on the VE!!!!!!!
- Installing OEM Keyless Entry
- Back Seat
- Cruise control cancel switch (break pedal mounted)
- Head Lights
- steering wheel vibrates
- My automatic seatbelts (driver side)
- Gas Mileage & Heating
- I Think it's my Wire Harness...
- Here are the pictures i told i would post....
- steering wheel alignment
- Another Headlight Question...
- 5th Gen Mufflers
- Here's the seat problem in my '92:
- Corners...and H20?
- antenna wire
- Check this out, Custom Tails, Ebay
- Knock Sensor Bypass
- head unit not working....
- cost of light conversion
- Audio Install
- tires Q and i SEARCHED
- Having intermittent shift solenoid interlock issues
- Auto Climate Control
- Looking....
- While the motor is in the shop.
- new pics finally up
- Which rims?
- 92 GXE creeky front end
- injector problems caused by mechanic
- will '95 seats fit a '92?
- Does This sound like an exhaust stud gone? - - mp3
- New job
- Transmission problem : please HELP me decide
- Power steering fluid leaking
- VTC rebuild question
- burnt headlight plugs
- Decisions decisions....
- hesitation, then pull, please help!
- fixed VTCs...
- hurtin max
- Make Fun Of The Rookie!!!!!
- just got new sub and levoc shiftknob
- Headlights
- Master Cylinder vs. Fluid Level
- Help Please!!!! Bose Cd/cs Info
- fuel filter, seat belt, clock and dash lights
- Question Regarding the Fuel Injector Color Dot and its Location
- New pictures
- keyless entry
- shut down
- tips on adj the timing belt tensioner?
- keyless entry stopped working...
- shifter
- Car going in today (clutch repair)
- will this hold up in court??
- Searched already but another ? bout addco rsb
- Transmission Problems!!
- transmission problem!! Help please
- Nasty Sunroof Shade & clips/91 MaxSE
- Center Caps
- manifold
- 300z rims
- Whining noise is finally GONE
- Preventative Maintenance
- ? 4 VG owners with UR UDP is it worth it?
- slick 50
- VE Coil Packs
- VG30i or VG30e
- just ordered some redline d4 ATF...
- Been gone for a while but I'm back
- Help - 90 SE - heater blows warm- not hot!!
- Code 51??
- Spare Bose Parts
- need price advice
- weight
- all motor
- tranny q's
- idle speed adjusting screw
- temperature gauge problem.
- Engine vibration, part two
- 3 out of 4 windows have problems ! HELP!
- I Love My Max
- New to forum
- how to access and reset factory alarm
- Do worn axles make a clunking noise?
- sooo... coll.d..d..d.dd..
- Crazy security system! HELP!!
- eclipse intake on my maxima - pics
- Heater problems no more!
- My Weak Vg
- Any scale models?
- Two questions on the air system in the car(circulate?)
- Rain?
- Speedo...Cheers...
- Transmission Help PLEASE!!!
- Possessed Heater!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Shift Kit Install???
- Welcome to Kindergarden
- Ridiculous
- Urgent Help: Cannot start my maxima
- Anyone know about Autozones clutches?
- New Pics!!!
- Bullet Proof Motors
- nitrous and S-AFC
- Seeking advice with vibration issues after front and rear engine mount replacement...
- Intake resonator - What for?
- annoying problem
- Two Part Question
- I am so Frustrated!!!!!!!!!
- Would there be any problems using an Aasco flywheel and ASP UDP.
- Lets talk engine noise
- havent been here in a while
- Stillen Intake????
- Fender Lights
- how much for paint on the stillen front lip?
- tranny
- window washer fluid problem
- and i think i need a new starter
- VTC rewire gone bad
- engine tick, and a misfire HELP
- 1991 50th Anniversary edition???
- Governers?
- help
- WASSSSUp
- redline tranny fluid...
- My New Cardomain Page!
- air filters ???
- Pics of REYMAX77's maxima
- Pics of lowmax4's maxima
- Questions on testing injectors....
- painting body kit
- VE woes......
- Daytime Running Light Problem
- Anyone Have Pics With Intrax Springs With 18's
- Crazy Speedo Needle/91 Maxima SE
- How hard to change to heated seats on 3rd or 4th gen?
- Clean VE - pictures inside
- Strut Bearings and Camber Plates...
- i really appreciate the help the people of this org has givin me..
- where to get engine rebuild instructions on the net?
- It's Decision Time.......sell max for turbo car ?
- Speakers, continued
- diagnostics codes
- hesitating
- Electrical Problem
- bose problems. confusing ....
- seats
- Help? Car won't go into gear
- which injector to replace
- DAD racing seats
- Bosche +4 Spark Plugs
- Key code for 1989 Maxima GXE?
- Where and how much should NGK plug wires be?
- What could you do when changing a spark plug that would cause a injector to die?
- get rid of the undertone paint?
- VG knock sensor problems
- A/C control lights...
- injector help
- I'm finally a 14 sec Maxima!
- 90 Max Hard to Start
- When Do I know it's time for a new Radiator Hose?
- what to say
- Pics of my new rims on the car!!!!
- problem w/the vents
- 1990 Se Is Not Running Right I Need Help
- Brake Pads
- Brake distributor problem
- Anyone Replaced Front Engine Pipe
- Oval Dash ????
- Finally, no stall and hesitation!
- I finally got a Max!!!
- Anti-theft module wiring - yellow wire
- Indiglo Gauges (how hard)
- Who Has The Most HP?
- e36 lights w/ angel eyes
- congrats to craig
- Clear Corners
- What is the difference between the '90 - '91 and '92 - '94 suspension?
- Well I still have some really nasty hesitation since installing my Y pipe....
- F*ckin rare manifold :eek:
- Uh Oh...
- stuff coming out of the exhaust
- just a thought.
- spring/strut combo cheap
- e36 write up
- bad acceleration
- 1990 Se Not Running So Great Plz Help
- Ve Rebuild Kits
- Does a VE B-pipe fit on aVG
- Indiglo Gauges
- Stupid Power Antenna
- suspension questions: guru's needed.
- Speed sensor testing?
- HELP Missing out while driving
- L.E.D. for Driver's Window Switch
- How long does it take to check the timing?
- Anyone use the dent puller "as seen on Tv" at Wal mart?
- Could code 51 be caused by something in fuel tank?
- Question about offsets
- For those who do it yourself
- question about putting on different rims
- VE30 head swap
