View Full Version : 3rd Generation Maxima (1989-1994)
  1. 3rd gens bought new
  2. Search Disabled, Quick Question
  3. suspension recommendation please...
  4. Please Help An Idiot! Thanks!
  5. suspension question
  6. Request for 194 bulb/LED pics
  7. Location of ECU
  8. planning to replace bose hu and speakers
  9. anyone know how to block the EGR
  10. Brake cables 89 maxima
  11. Manual Transmission Swap Update.......
  12. timer control unit
  13. drum to disk brakes.
  14. Diagonistic Test
  15. Regulator & Motor Questions...
  16. Optima Yellow Top
  17. Alternator Replacement
  18. Rust!
  19. Repetitive Bumping Noise
  20. 16's on a Maxima 3rd Gen
  21. DIN location?
  22. Some Updated Pics of My HID's
  23. The Max is going in for brakes tommorow...
  24. Need some help
  25. Power Locks
  26. Wings West body kit
  27. Keypad!!! I need some help
  28. when it rains my max gets smokey
  29. help me out
  30. Cracked Manifold??
  31. SE swaybar Vs NonSE swaybar
  32. Engine runs different everytime the car is started up?
  33. springs and struts
  34. Center Console - electronic climate control
  35. time to say good bye
  36. door hinges
  37. wont start
  38. My wierd problem -spontaniously gone away?
  39. Overdrive questions
  40. suspension
  41. Ground Effects Needed
  42. gas mileage and other quick Q's
  43. buying a max, 92 se 5spd.
  44. Please Help me with this electrical issue
  45. tranny swap??
  46. those with parts cars
  47. Alarm not dis-engaging
  48. 92 Se...h I D
  49. Body Kit
  50. Rebuild or not to rebuild?
  51. Cup Holders
  52. Anyone ever seen/used this oil filter?
  53. Excedy clutchs compared to OEM
  54. car covers
  55. 92 SE Exhaust Question
  56. Old looking paint...
  57. Do They Make CARGO NETS
  58. Clean throttle body?
  59. keypad operation???
  60. o2 sensor and power
  61. Taking out the Digital Climate Control
  62. Auto - 5speed swap
  63. won't shift out of second?
  64. IS it possible for the ECU to retard the timing?
  65. passenger side possessed!!
  66. fuel system
  67. Do you have Leather, Cloth, or Tweed interior?
  68. manual transversion
  69. 245 will fit an 8" wide rim?
  70. Wings West
  71. ported throttle body
  72. Eyelets
  73. best way to begin
  74. WTB driver window switch..
  75. front subframe brace
  76. weird problem with 92 se
  77. What The He//..... Help Please.........
  78. Quik question on checking distributer..
  79. Might Be Old Just Looking For An Answer
  80. 2k2 muffler
  81. Custom Panels, Tell me what you think?
  82. Catalyic Converter Gone Bad,Why?
  83. Wipers
  84. My injector tested out of spec... now what?
  85. im back with a wierd problem about counting mileage
  86. Indiglo Guages
  87. Speed Sensor
  88. Struts
  89. spark plugs and wires
  90. gas related issues
  91. To Buy A '93 W/ A Bad Tranny?
  92. Overdrive questions that goes along with my dying transmission........I think
  93. lock problem
  94. Would it be ok to changethe timing on almost stock VG?
  95. 30 mile drive and stalling...!!!
  96. Y Pipe
  97. Automatic transmission filter?
  98. My poor baby...
  99. Tires
  100. heat is an issue also..
  101. Power window help needed
  102. Alright this crap has got to stop!!!!!
  103. Center wheel caps (4) needed for '94 GXE.
  104. story
  105. Another Transmission Question!!
  106. Replace Tie Rod "94 GXE
  107. BMW E36 Headlights(Need Help)
  108. The unsolvable problem on the car...
  109. A note on the PCV valve and good engine idle
  110. my max is dead
  111. ABS lights keeps coming on and killing my battery
  112. Aaarrrrgghhh!!!!
  113. Description of VTC Function in FAQs is Lacking
  114. Rubbing compound -alright to use?
  115. removed door trim....now sticky goo, how to remove?
  116. smog check
  117. idle's high
  118. Pics?
  119. Turbo swap - HELP!!!!
  120. What do the coils look like?
  121. Anybody have In-Dash TV plans?
  122. anyone been able to find this....
  123. Question fro the experts
  124. Key broken in the door.. how to get it out? Help
  125. sirius
  126. rims and tv
  127. Pics around oil pan
  128. Idling higher than normal
  129. Speedometer
  130. Tach jumps around, then works, then doesn't
  131. Window Access from Keypad..
  132. does a 92 se have a distributor?
  133. Speedometer (odometer) went out. Help
  134. Transmission Troubel
  135. 92 SE is stalling
  136. A couple of questions
  137. Best wheels & tires?
  138. Low Speed Misfire? 94 GXE SOHC, AUTO
  139. How long would it take to...
  140. body kit parts needed....
  141. Brakes
  142. 529,755 miles and counting.....
  143. inner tie rod
  144. Wtf?
  145. 90 SE engine trouble
  146. custom trunk pics?
  147. Looking to join the 3rd gen crew!
  148. Sea Foam & PCV
  149. Bad Smell
  150. Trouble with fuel pump/turn signals
  151. For The Guys Who've Installed Dash Kits
  152. Gaskets....
  153. corner bulbs
  154. failed inspection!!
  155. speedo cable/sensor???
  156. Is this rust?
  157. Got an 89 maxima as my first car
  158. Throwout bearing
  159. Statistics Needed, Please Help
  160. Turbo question
  161. another question bout a maxima!
  162. Wanna get a maxima, tranny question!
  163. what is a tranny problem?
  164. will a 94 dohc engine work in a 91max
  165. US guys might get a kick out'a this...
  166. Tire Brands and Sizes
  167. Replacing REAR speakers?
  168. What does the EGRC solenoid do?
  169. cars going in da shop...pics in a week
  170. Rough Idle
  171. $140 for new bumper?!?!
  172. Cleaning the injector connectors I say...
  173. Clock
  174. 89 tranny problems
  175. 91 GXE Tranny problem
  176. miles going down down down
  177. H7 bmw ? will these work for headlight conversion?
  178. Beam Pattern, screwed up?
  179. buyer Q
  180. when do springs and shocks wear out?
  181. Steering, seems tighter
  182. Quick Question
  183. Key Pad code
  184. Removing the weight in the trunk
  185. Interior lighting problems?
  186. Power window question, please help
  187. big prob with 92 max se
  188. my Maxima hates me
  189. Somethings wrong with steering. Help me out?
  190. Factory spring , plastic?
  191. re: how to fix minor dent on door panel
  192. took a road trip to FL saw alot of maximas
  193. VTC replacement advice
  194. Diamond Plate....
  195. mystery leak??!!??
  196. where to get transmission parts
  197. Incorrect timing belt replacement
  198. Tranny removal - 89 auto Max
  199. spoiler
  200. any one know how to install a power antenna mast
  201. anyone know how to fix a power antenna
  202. quick question
  203. 3rd Gen Engines....Restore?
  204. Just got back from a roadtrip...
  205. Exhaust Manifold Leak
  206. Where is the ^$*@&^#% transmission fluid filler?
  207. ecu codes for a 92 se
  208. Is this VTC failure?
  209. Brake light comes on after hard braking
  210. cant search need ahelp with getting a radiator.
  211. My clutch is clicking ??!!
  212. Newbie Getting Started
  213. A Different Tranny Problem
  214. tranny swap questions
  215. Bored out the TB (pics)
  216. Tranny problem unlike others in this forum...
  217. Heater head unit --- it's not the bulbs -
  218. more on the knock sensor...
  219. Add on CD player please help....!!!
  220. Lowering question
  221. About to start Axle replacement... I seem to remember something aboutnot pulling?
  222. My Dad needs some help with his '89 GXE
  223. Anyone change their knock sensor on VE
  224. new spoiler
  225. HELP! My Maxima is always burning fuses!! Has this happen to anyone else??
  226. farewell 3rd gen...
  227. Strange ignition problem
  228. How much?
  229. Removing side moldings....HELP?!?!?!
  230. NEW INTERIOR vs OLD INTERIOR
  231. security system
  232. "free" checkup from nissan, should I go?
  233. Engine Miss
  234. How much is my car worth at the dealer?
  235. New Pics
  236. Few mods.
  237. Rap-Mobile questions
  238. Update IS300 wheel fitment.
  239. led in automatic shifter gauge?
  240. wrecked
  241. Running Poorly
  242. Good shop in Western Mass to do exhaust stud?
  243. turn signal
  244. update on my car
  245. Loosing Power
  246. Would this air filter and adapter fit my VG motor
  247. How to reduce weight
  248. Is this all that bad?
  249. speaker ports
  250. again with the rebuild...
