View Full Version : 3rd Generation Maxima (1989-1994)
  1. VG30DE vs VG30D (E) are they interchangable?
  2. How many O2 Sensor on 92 GXE
  3. corner lens bulge
  4. lighting up the maxima sign in the middle of the trunk
  5. 3rd Gen PWNZ0Rs
  6. almost a ticket
  7. EPROM Question
  8. Tel me how
  9. Transmission
  10. Climate Control & Key code Questions I might be able to answer them!!!
  11. seatbelt chime
  12. Really Tallll Attenna
  13. Its so nice to add new mods - ASP UDP and ST sways
  14. How do I fix my antenna?
  15. cat back sources
  16. Question about tires and springs (Craig)
  17. NEED HELP???? All with smoked or UK corners
  18. What Will Help my Low end???
  19. Just got pictures up.
  20. Any one near Woodbury, Long Isand, NewYork
  21. Why car stalls
  22. variable intake question
  23. 3rd gen crew of nyc pics lots of them also HIDs
  24. 92 se ignition coils
  25. intake mod help
  26. MaximaLess is no longer MaximaLess
  27. buying a max
  28. 1991 Cam Profile
  29. 3rd gens in magazines
  30. Possible dead maxima! Any ideas...? Everything appreciated
  31. Just browsing the Stillen catalog...
  32. Anyone put a volt meter in their car??
  33. Fuel Filter Location
  34. Fog lite replacements
  35. tokico suspension installation???
  36. advice on buying another MAXIMA --!!!
  37. Easy/Cheap Mods
  38. Will a leak in the exhaust affect gas mileage?
  39. Car polishing
  40. maxima handling
  41. Question - Neon Lights
  42. A/C rentention valve------HELP-----------
  43. cheap stillen lilp on ebay
  44. Test drove a VE 5 speed...
  45. magazine appearances?
  46. technical question.....
  47. $20 million dollar question (to be paid on Tuesday)
  48. VQ30DE swap for VE30DE
  49. HARDCORE DIY'ers, quick question
  50. WANTED: Grille
  51. Performance, comfort switch
  52. well mother nature got mad at my maximas last night
  53. Power Steering Squeak
  54. Question regarding HID and BMW lights
  55. vb mod
  56. cold air intake silicon hose?
  57. Maxima GXE 93 info ???
  58. cam shafts from cattman
  59. stillen rear cross drilled rotors
  60. whats that black regulator
  61. 2 max's and same seatbelt prob.
  62. want better handling?
  63. bose
  64. where to buy front struts
  65. question about my speed limiter
  66. want opinon on new rotors and pads
  67. Tok/Sprint Suspension setup
  68. Bushings, alighnment or what??
  69. NE1 ever used engine treatment llike zMax
  70. valve body question?
  71. tire size for 18x8?
  72. Well Somebody Broke Into My Car
  73. '91 Maxima - Possible Torque Converter Problem
  74. 92 SE differential question
  75. Ignition Upgrade Questions
  76. BMW headlight Question
  77. 1/4 mile
  78. For those who have done or planning to do a 5spd conversion is it worth it???
  79. To those who have Eibach's... please read.
  80. busted sun shade
  81. Where is the Idle Speed Control Valve?
  82. Strange clutch action
  83. How much to replace Vacuum lines?
  84. What are our wattage on our headlights
  85. quick question
  86. Hey all you EE majors....which resistor do I need?
  87. VI voltage question
  88. someone please help
  89. Paint
  90. foglight question
  91. What do you use for cleaning the seats?
  92. Diagnostics and coil question... HELP!!
  93. Transaxle Stuck
  94. Need Info On CV Joint Replacement
  95. Where can I get good cheap reasonable price for 225-35-18
  96. 92 SE Tranny Swap
  97. spark plugs
  98. whats our wheel offset??
  99. Clear Out Rear Blinkers?
  100. gas
  101. maf adaptor
  102. gas leak
  103. headliner removal
  104. ??'s about putting VG together
  105. Strut length question....
  106. nrw pics
  107. Suspensionmax.com shocks n struts???
  108. embarassing question
  109. Pics of blue leds in gauge cluster!!!!
  110. New rims
  111. Upper strut tower
  112. 1st max
  113. lug nut sizes
  114. 93 SE Clutch hydraulic fluid leak?
  115. Has anyone replaced a camshaft oil seal?
  116. Where is tranny speed sensor specifically located???
  117. Looking for photos on strut replacement
  118. Turbo VG guyz
  119. Axle Hub Socket Size for `91?
  120. finally both door handles are roughed in (pics)
  121. Door stuck locked, electrical
  122. Does a new engine always need a new tranny
  123. Is it bad to...
  124. will 2003 bose hu work on 93 max w/ bose?
  125. Is my 92 GXE auto equipped with transmission filter?
  126. What affects the gas mileage?
  127. Had a scary problem last night
  128. Interior Question
  129. What is PVC valve and why should I change it
  130. automatic seatbelt problem
  131. Is there such a thing as over done rice? (pics)
  132. another tranny problem
  133. Sway bar bushings
  134. A few new pics...
  135. new vg engine for 250
  136. 5spd tranny question
  137. Smoke from exhaust and stalling
  138. What are the cables under the seat?
  139. valve cover
  140. VG30E vs, VG30DE short block differences
  141. check out these pics
  142. It worked
  143. Question About Muffler Mounting...
  144. Alternator fix question..........
  145. for all you auto guys
  146. New Pics of Crazy4maxima's interior swap
  147. Help on Speakers
  148. Does anyone know cheap repair of engine pipe?
  149. Cooling Fan Qs please help..........!!!
  150. Taillights bulb conect's are terrible HELP!
  151. Strange effect/problem when I start car
  152. Air Conditioner Compressor clutch
  153. Rev. Indiglo Gauges - Where 2 Buy?
  154. How much of a drop are ST Lowering springs?
  155. lookin to buy front bumper bodykit
  156. 91 SOHC engine fire in Resistor/Condenser
  157. HELP!!! Need New Spoiler SOON!!!
  158. Air conditioner compressor problem
  159. 93 GXE recall information
  160. 93 octane to 89 octane
  161. New fuel filter & gas mileage.
  162. suspension noise?
  163. VG timing marks.
  164. Got My FSTB in....2000+ generic one.
  165. Is the 3rd Gen. Max.....
  166. Streeo sound (not power) turns randomly off and on w/clicking
  167. Where to put GT-R Emblem
  168. How much for a tranny rebuild?
  169. Transmission Problems with the 1992 SE??
  170. So sad - I'm missing my maxima more than ever :(
  171. **Gauging interest for a possible GD on 3rd Gen CF stuff** (kinda long...)
  172. Anyone know...
  173. Lurching, but maybe not engine
  174. anybody interested in "test pipes?"
  175. Technical Questions Refer To Here!!!!!!! Geez!
  176. engine noises
  177. Fuel Pump flow
  178. Paint Job Suggestions
  179. Power steering fluid Nissan vs. normal PSF
  180. Need New Suspension...ASAP!!!
  181. Air Flow Meter - HELP PLEASE!
  182. Mesh Wiring Grille
  183. Where to buy KYB cheap?? (search down)
  184. grey 3rd gen with STILLEN kit
  185. UDP's for a VE 5spd
  186. How Do I Take The Gas Pedal Off ??????
  187. Free Maxima!!!!!
  188. once you go black you never go back:naughty:
  189. Where to buy????
  190. Best website to buy Clear Corners??
  191. newbie Question
  192. HELP!Is ther anyone that can run a vin for me that has carfax access.Thanks Guys/Gals
  193. Bose radio problem
  194. alarm led but how?
  195. Would the radio/climate trim piece from a 92 fit in a 91..
  196. Polished Wheels
  197. ???'s
  198. Bushings
  199. ECU location
  200. Maxima Street Run - Video inside
  201. door lock timer or actuator
  202. headlights gone crazy
  203. Transmission slip question
  204. transmission
  205. Installing a new stereo
  206. Advice about buying a 1992 SE? HELP!
  207. autometer gauge pod
  208. Front axle replacement. $100 Reasonable??
  209. Help..Dual personality 92 VE 5sp ?? (long)
  210. intrax settling
  211. BMW E36 headlight conversion question
  212. Tranny slipping problem please help
  213. Question regarding extra parts required for upgraded suspension
  214. 91' Intermittant Check Engine & runnig rough
  215. Place Racing Cold Air Intake Question...Help
  216. HELP - My maxima is dead
  217. 93 GLE number of pad shims
  218. Just put on new 18" rims
  219. Touch up paint question.
  220. 3rd gen. looooong gear shifter.....
  221. 90 VG Hesitation
  222. How do you remove the driver's side steering wheel w/ airbag?
  223. Need Help with BAD gas mileage
  224. 92 GXE tune-up advice
  225. i need ve engine help
  226. really rough ride
  227. Excedy group buy??
  228. How much do I gain from a mandrel bent catback?
  229. what year did they switch AC refrigerant?
  230. 3rd gen Cattman-Progress Coilovers, we need 15 people
  231. AC not working
  232. VIN check please.
  233. quick question fan relay check???
  234. solved/rough idle/vibration
  235. Lower Control Arm Bushings
  236. My tranny work..
  237. Where to buy coils?
  238. front axle install.
  239. mixing injectors
  240. Popping sound when hitting the brakes....
  241. cat converter which one...
  242. bad MPG
  243. oh no.. it happens again....
  244. i have ended my maxima search
  245. intersting discovery with coil packs
  246. dissapointed in track times, please help
  247. Ignition coils for a 92se
  248. About 1/4 Mile Times
  249. Knock and O2 sensors compatability question
  250. How do you fix your stock Se wing when it rusts out?
