View Full Version : 3rd Generation Maxima (1989-1994)
  1. Cross eyed max
  2. Distributer Question?
  3. vg drive and susp parts
  4. Windows down tunnel video v.GReddy
  5. Hey Look What i Did!!
  6. Parasitic Draw
  7. any success with R12- R134 AC kits?
  8. Rust
  9. Stock Anti-Theft System... A question.
  10. Window
  11. two random questions. optima battery, and engine sludge...
  12. Engine Out - Help.
  13. unique ebay item
  14. Steering rack question
  15. Smoke and no temperature reading
  16. high pitch noise coming from water pump area...
  17. Missing hoses
  18. not good, wont start :(
  19. Max is back on the road after sitting for 6 months
  20. vtc grounding issue
  21. rear window spoiler?
  22. Transmission Control Unit
  23. Any Washington, Oregon People Seen This?
  24. was converted to leather/power seat but...
  25. Getting distributor off
  26. MAF Plug?
  27. Is it bad that.......
  28. Sunroof leak
  29. rough idle, my plans.. anything else i should do?
  30. TPS corroded harness...rewire and solder?
  31. Still Love My '91
  32. Dash lights are non-opperational...
  33. Pathfinder Clutch kit/flywheel?
  34. Problem with Heater
  35. vg compatible
  36. hey..uh...
  37. releasing fuel pressure, car stays running....HELP
  38. Do I need a magnetic socket to remove spark plugs?
  39. missing or chuging at low RPMs
  40. Replacing rocker cover gaskets. what else should I do?
  41. in search of a bad o-ring
  42. 91 Maxima SE in the shop
  43. Rear window defroster
  44. 91 SE Rear parking brake cable
  45. Throw out bearing installation
  46. 94 VG30E Tranny??
  47. some bad news...
  48. radiator plastic tank cracked. Where do I get a new one?
  49. Any ideas about wheel noise on freeway?
  50. Suspension Suggestions?
  51. Door locks stopped working
  52. KYB + lower springs = FTL
  53. Car shaking like not getting enough feul
  54. Video of a car jumping, looks like a 3rd gen?
  55. brake system help!
  56. ventilation fuel hose leaking
  57. Passenger CV Axle Carrier Bracket Removal
  58. Need to find starter relay.
  59. Front wheels coming of the ground?
  60. Clunk noise when I hit the brakes...
  61. Replacing my injectors
  62. Injector question
  63. Time to move on...
  64. Max won't start
  65. Dang, it is messed up
  66. CAI Question
  67. Injector Swap
  68. Choppy Idle
  69. Inspired by 2000 I30 commercial, add your B&W's!
  70. Z31 Rear Brake Conversion/Upgrade Write up
  71. Big Brake Question
  72. Intake plenum gasket
  73. How Is The Rear Spoiler Held On?
  74. no A/C!
  75. missfire ve issure found so....
  76. Has anyone un-automated their seatbelts?
  77. Automatic seat belt clip + wheel problems
  78. Towing Capacity
  79. mold (or mould) on leather seats
  80. Stockpile parts?
  81. i belive my alternator going.....
  82. WOOOHHOOO! Gots My New Injectors Today.
  83. Pintle cap
  84. replace rear window?
  85. I suck at the brake bleeding
  86. Epoxy/Adhesive for V6 3000 Logo?
  87. Whats your max weigh?
  88. corroded injector terminals.
  89. Broken Screw!?
  90. where can i find foglights?
  91. Winter Sound Mod
  92. Heated Mirrors
  93. Interchange parts?
  94. Electronic climate control lights?
  95. The Engine/Tranny swap Finished!
  96. power mirror failure
  97. Radio Harness Mess
  98. Disconnecting injector/spark plug
  99. Need help buying VE injectors..
  100. rough idle injectors????
  101. Some WIP Pics
  102. Going Forward - ONLY
  103. Just thought i say good bye
  104. Is this worn springs?
  105. Quick pics during winter storm
  106. Capedcadavers tranny swap blog..;-)
  107. So what is the best spark plug?
  108. WIRE HARNESS PROBLEM
  109. Will an auto ecu work in 5spd
  110. Intake plenum and cooling fluid
  111. Wiring Issues
  112. 94 SE CHECK ENGINE LIGHT ON/OFF
  113. Need a favor; need a pic in the engine bay
  114. Rear bearings
  115. What the heck does this gotto?
  116. Rust pics?
  117. VE SSSIM
  118. Intake manifold/injectors questions
  119. 3rd Gen. Favorite Mods Thread.
  120. After a long hibernation and the max has awaken
  121. wrong VTC wire
  122. DOHC/SOHC injector difference
  123. E-brake cables
  124. No global warming here...
  125. iTrader feedback
  126. Umm...Foamy Gear Oil?
  127. Brake Master Cyinder Question
  128. The official VE love thread.:007:
  129. Not having this belt (see thread)
  130. Battery light comes on - Alternator?
  131. 93 94 trans bolt patterns
  132. car problem
  133. Need help with seats!
  134. 94 SE VE30DE 5-SPEED
  135. MAXIMA NOT IN GEAR
  136. Anti-Theift no start
  137. Spoiler repairs
  138. rims?
  139. Factory Head Unit
  140. Alternative to SE center tail...
  141. Engine models that may fit the SE
  142. anyone need some PARTS??? its finally here
  143. Door locks quit!
  144. Maxima (J30)1989-1994 Parts list with #s
  145. True 3rd Gen Clear Corner - write up w/pics
  146. Inner/Outer Tierod Replacement (Writeup)
  147. Alternate Fuel
  148. 5th Gauge Cluster Light?
  149. koyo radiator
  150. Tokico blues + Eibach springs
  151. I updated my cardomain
  152. bleeding the coolant sys instructions
  153. 3rd gen ve 5spd for $200 worth it
  154. Correct Part?
  155. Getting alarm/remote start but first!!!.......
  156. rs50a tranny wont stuck in 1st or 2nd but shifter is in neutral???
  157. melted plug... wtf
  158. Digital Dash and HU on a VE?
  159. Motostorm Products
  160. Different throttle body on stock intake?
  161. Fuel injector resistance reading
  162. VE Valvetrain: Diagnosis help please
  163. big brake kit (un) install one problem
  164. Need advise on new struts for my 94 GXE
  165. 3rd Gen Driving Pics (lots of 'em)
  166. whats this max worth?
  167. Digital Dash Problems
  168. dohc Steering Rack
  169. deatschwerks phase 2 injectors
  170. SE owners, thoughts on window trim?
  171. Show your heritage
  172. New dilemma
  173. location of the wind shield wiper relay on 94 maxima gxe
  174. Car won't start (Clicking!!)
  175. Both Rear struts and springs are maybe done...
  176. The swap is complete but I need some ideas....
  177. New Fuel injectors ... Car will not start. Please Help.
  178. non airbag wiring to airbag wiring
  179. Lowered: intrax/tockico
  180. If you love your VG POST A PIC HERE!
  181. mmm...STATS!!!
  182. Wierd starter/battery problems.
  183. Axle picture request
  184. Update on cardomain. Pics of turbo build.
  185. Alarm System Issues...
  186. What do you think about this Big Job
  187. I passed!
  188. What is the Best Method For Polishing and maintaining Aluminum?
  189. Buy complete strut spring pkg?
  190. Crunching sound when slowing down with transmission
  191. '93 gxe sohc used injector availability
  192. Distributor not staying in time?
  193. Your most replaced part/s v. long time 3rd gen owners..:o
  194. PCM Interchangability
  195. Original Bulb???
  196. Hinge goo
  197. New Suspension
  198. CLUTCH
  199. Need your help identifying some engine bay parts
  200. Fuel problem / Fuse problem
  201. Rpm signal wire on Ecu?
  202. Who Here Has Taken A Front Seat Apart?
  203. Replacing Window Regulators
  204. OEM GXE Fog Light Wiring (who the heck has 56K these days?)
  205. Koni Strut Adjustment
  206. Rear strut replacement - 93 GXE
  207. Trunk leaking
  208. Well That didnt work!
  209. 92 VG Injectors: Difference between black body and blue
  210. VG30 Knock Sensor: Who is the OEM?
  211. Automatic maxima won't shift from park
  212. Yes! The VG Auto to VE5 swap is DONE.
  213. 3rd Gen Maxima Chase Scene
  214. Need high resolution VE engine bay pics and/or wiring and hosing diagram
  215. Strange symptoms, engine light on?
  216. LSD for VG?
  217. Coolant system will not stay bled!
  218. Is there a step by step to getting the heater working?
  219. third gen carbon fiber hoods
  220. Anyone put HID's in these headlights
  221. car wont start
  222. Happy New Year 3rd genners!!!
  223. Ebay SS clutch line, Legit?
  224. pcv valve?
  225. motor mount from hell
  226. Automatic trans preventative maintinance.
  227. Putting together a Maxima Calender!
  228. Remanufactured SE 5spd trannies
  229. for anyone with lethargic steering response...
  230. Nissan quality, still strong
  231. tail light fuse blows?? help
  232. Bump shifter
  233. Because 1280x1040px Isn't enough sometimes
  234. What really happened to dmontzsta's max
  235. Interior Swap
  236. loose strut nut
  237. Locked up 5 speed tranny
  238. need new springs for shifter
  239. Stillen Ground Effects Attachment to Bumper
  240. Question about a nut.
  241. fan blows, but no heat
  242. I crashed my car; sell or part out?
  243. engine barely start after new injectors replaced
  244. In Dash GPS where clock went
  245. Happy Merry Holimasikahs?
  246. metal top radiator, with holes from the factory?
  247. High performa exhuast sys.
  248. trans. oil change 94 SE
  249. new fuel injectors
  250. Bumper cover, OEM or cheapo?
