View Full Version : 3rd Generation Maxima (1989-1994)
  1. Fuel Pressure
  2. 1992 Maxima SE Stalling
  3. Problems with A/C and heater turning off after a couple of minutes of being on
  4. ECU Maybe?
  5. Q: about timing
  6. 92 SE Parting out
  7. What Is This For
  8. noise with acceleration after suspension change
  9. muffler question ...needed info..
  10. saw a white max, 5th gen. rims in manassas area....
  11. Brake pad questions
  12. JDM engine or rebuilt engine?
  13. 3rd Gens in Lexington Area?
  14. Knock Sensor $135.00 Shipped US
  15. Something loose?
  16. foglights on a gxe
  17. Air/Fuel Gauge
  18. BMW headlights?? flush
  19. My Max is pushing its luck
  20. Vacuum Hose Locations
  21. speedometer doesnt work
  22. How do you change wheel studs?
  23. Picture of Door Lock Timer
  24. What's Up With This 3rd Gen???
  25. 4 questions - please help
  26. http://members.cardomain.com/va1adez
  27. factory or bull
  28. mobiltek vb reclabiration any feed back autos
  29. Wont Start
  30. Spring Compressor
  31. Clamping force (in kg.) of OEM pressure plate?
  32. new muffler question
  33. Rear brake problems
  34. Tranny Swap
  35. whining noise
  36. Fender clips for the oem mudflaps. Where to get?
  37. control arms
  38. Trunk insert
  39. Good place for leather online?
  40. 18x8 ?
  41. PCV valve
  42. New goodies for my car
  43. maxima gxe 1/4 mile
  44. Help Tie rods wont come off
  45. 1994 not starting
  46. Lubrication...
  47. Maxima 89-99 High Flow Racing Intake Kit??????
  48. How do you remove the auto shift knob?
  49. How to remove rear speakers???
  50. Blower motor running all the time
  51. repairing exhaust studs
  52. Keypad and power lock problems....
  53. 92 SE Clutch
  54. ABS Hydraulic Unit
  55. How much is changing the Knock Sensor(Labor+part)?
  56. Front Plates
  57. Limited Slip Diff
  58. cleaning leather
  59. power door locks?
  60. Sprint spring install complete... come see
  61. hello fellow maxiamteers...
  62. Wing West question!!!
  63. quick yes or no
  64. Climate control??
  65. Updated pic
  66. Blacked out lights
  67. Dam Server
  68. Back seat windows
  69. buying a 90SE maxi
  70. Trip to cape may gone bad need help
  71. How do I remove the adhesive strips under the door moldings?
  72. Catalytic Converter question
  73. temp of the sylvania xtravisions
  74. Help: the cassette player can't pull the tape into the player
  75. something wierd when i post
  76. shocks
  77. finally finished the right side door handles (pics)
  78. excessive tranny fluid change?
  79. timing belt and water pump
  80. <sniff> I miss my baby already...
  81. Keyless entry...
  82. why cant i search?
  83. Steering rack bushing?
  84. winow regulator question
  85. A disappoining VTC story
  86. Brake light malfunctioning
  87. engine clatter (horrible)
  88. 300zx wheels
  89. auto tranny cold start stuff
  90. aftermarket muffler with stock y pipe
  91. first chop of an acura rsx
  92. Moda R6 pics
  93. Strut mount bolts
  94. Trans fluid change advice. . .
  95. Timing Belt History
  96. Problem starting the car and putting on neutral only works.
  97. What I've Got Coming... :-)
  98. rear suspension..simple questions
  99. any one know?
  100. Strut question
  101. SE tailights
  102. Got my R6's yesterday!
  103. 5 spd trans problems
  104. My 92 GXE problems
  105. Please Help, exhaust question
  106. What belt size for Unorthordox pulley?
  107. What kind of Engine do I have !
  108. Another Engine Swap Question
  109. which spark plugs
  110. gutting out the catalytic converter...
  111. how to remove, question
  112. 1991 Tranny Question
  113. 300zx caliper
  114. Wheels
  115. Add on CD Changers
  116. gtechpro
  117. ve engine swap
  118. Need some insight!
  119. whats the size (2,2.25,or 3)
  120. Need help... HELP!!!
  121. Camshaft oil seal
  122. 4th and 5th gen wheels fit?
  123. updated site
  124. PopCharger...Remove Box?
  125. Exhaust note
  126. what does spark knock sound like?
  127. Need some expert advise
  128. Finally posted some pics.
  129. Just got a '89 GXE, Some Issues Though...
  130. intermittent bogging....again
  131. Rim Upgrade
  132. running wire
  133. where be the fuse box?
  134. Odd Problem continued
  135. need advice on new maxima
  136. Peel a dashboard?
  137. What struts do I get?
  138. hard braking
  139. K&N Oil Filter ?
  140. Got Pics Up
  141. Odd tranny problem, please advise!
  142. Sprint Springs
  143. Throttle body cleaning
  144. Need advice on upgrading suspension
  145. sorry for dumb thread...
  146. Help with alarm
  147. KYB Strut Install Question
  148. Anyone have a blueprint of the 3rd gen?
  149. How hard would it be to seperate my auto tranny from the motor? I think it's TC time!
  150. Brake light and 1 Touch window
  151. Odometers Quit working, SpeedO and Tach fine..??
  152. Transmission Clunk
  153. Engine oil leaking. Need some suggestions.
  154. Clicking noise
  155. Need Opinions Please!!!
  156. Cannot remove spark plugs
  157. Rear Bushings.... Where to buy them?
  158. Maxima gulping clutch fluid. What to do?
  159. sunroof weatherstripping replacement?
  160. Clunking sound in r/rear suspension?
  161. seat belt chime
  162. Struts and Shocks for 91 GXE
  163. can somone look up thread title "platinum tint"
  164. magnaflow or flowmaster
  165. bad struts
  166. kinda off topic
  167. No Search: Friend needs new tranny for 1992 Auto Max
  168. Repairing Stock 94 GXE Blose System
  169. tail lights
  170. Need advice about Broken Exhaust studs
  171. 89se electrical problems
  172. need help fast!! will a 5th grn FTSB fit on a 3rd gen??
  173. CAI install question
  174. exhaust system for turbo
  175. power door locks
  176. exhaust
  177. Bose Stereo (sorry, search doesn't work)
  178. Aftermarket pulleys
  179. bmw headlights installed today pics soon
  180. Oil change
  181. 3rd Gen Front Floormats - Where to find????
  182. Tire questions
  183. New muffler and painted calipers
  184. Dude! Clear Out Your Front Blinkers!
  185. Help! Clutch Problems (long)
  186. Will VG y-pipe WSP fit into VE ?
  187. 100k miles, oh no!!
  188. just ordered a magnaflow muffler
  189. quick question...
  190. Checking out a 92 Maxima, few questions, reliability?
  191. HELP! 92 SE Power door locks
  192. 93SE Headlight
  193. A noise , ticking.
  194. what is this zzzzzzzzz
  195. Maxima R.i.p
  196. Making MAX fast!
  197. can't win for losing
  198. Having problems with our 91 Max....
  199. Grounding the VTC's
  200. Brake, Battery & Check Engine Lights ALL ON
  201. hood struts
  202. Work is slowly progressing, parts not here until Tuesday. (pic)
  203. Silver or Black?
  204. auto trans /gear lever
  205. testing
  206. Chiltons vs. Haynes
  207. Just took off 17"s and put on 16"s...
  208. Carpet
  209. Where can I get the Stillen Type 2 Spoiler?
  210. speaker/amp removal ?????
  211. Max R.I.P crashed
  212. brake dust covers ??????
  213. automatic seatbelt GRRRR
  214. Timing Marks
  215. Airbag removal
  216. my current project
  217. Just got done swapping airbagged steering wheels
  218. search
  219. Whose 3rd gen is this?
  220. Trying to get pics up.....
  221. Exhaust manifold Flange
  222. Time to change the exhaust manifold studs
  223. 5th gen and other mufflers...
  224. will this HU fit??
  225. Anyone On Here?
  226. oxygen senser
  227. How do i know if i Got L.....
  228. Help Bulb Sizes Please ...........Question For People With Silverstars
  229. Adcco RSB install
  230. trying to understand exhaust system mods for vg
  231. We love to watch her strut...
  232. Help on cracked Y-Pipe..PLZ!!!
  233. Pics needed
  234. 92 se power
  235. FSTB question
  236. DIY FSTB Install - ?
  237. Ordered my rims today
  238. My car is haunted and HATES me
  239. tires/intake
  240. Exhaust Setup Opinions
  241. I Need Help Really Bad! Off Topic Question,
  242. Just received my ASP pulley from RPM outlet
  243. VE JWT owners
  244. A/C dont work
  245. Automatic window
  246. my babies dead......for now!
  247. Car bra question
  248. Best place to buy? And brand difference?
  249. Tap and Die Set(Wheel Studs)
  250. Need advice on the type of spark plugs to put in my 92 SE
