- weird noise
- Need Help under hood!
- BMW Headlight Question
- Bought a 92SE 5-speed with 76k!!
- BMW Headlights
- Tranny (long post)
- suspension like a boat
- need some info just got my 93 max
- RPM's
- I Cant Get This Fukin Factory Air Box Out
- how long sprints settle
- Need Help With Shock Sensor Installation
- Correct tire pressure?
- Paintless Dent Removal
- dual gauge question
- 1989 Intermittently looses power, then comes back
- Best Spring to Use with KONIS?
- Here's a Question From The Archives!
- Next car after 91 GXE- 97 max or 02-03 altima?
- Search Engine
- projector headlights??
- tire rubbing issues w/97-99 5-spokes
- ABS Sensor Question
- Will OBD-II Scanner Work?
- Octance
- Worn control arm bushings...
- Is the Hood Open, or has this been in a wreck?
- Window Regulator questions
- VE vs VG Gauges
- Fuel economy
- My car had a good weekend...
- injector voltage
- Glove box bulb size anyone know?
- some thing smells
- Tranny: aamco rebuild or junkyard jewel
- 9004 & 9007 Headlight Bulbs
- freon
- Euro Gauges
- fuel pressure regulator
- what is dying on my car?
- Speedometer
- any good forums for a '94 sentra????
- Quick important question: 214K miles, how long will it last?
- help!
- Alarm,Keyless Entry, Maybe even Remote Start
- Installed Tokicos today
- Did I make a mistake?
- Spoiler light
- Ahhhhhhh!!!
- Why me?
- e36?
- VE into a VQ
- Breaks
- Rear window going down without hitting the button
- cleaning out throttle plate
- O-rings for A/C system
- Replacing Studs
- pics of VG turbos
- car theft
- dual exhaust
- Looking for answers
- warpspeed y-pipe
- Attn: People with 92 SE and 2000-2003 FSTB
- did anyone ever drop that 300 hp engine for the vg
- tire size
- Bose CD Player
- Can I pull the three bolts off to install a tower brace?
- Quarter panel?
- Anyone with pix of 35% Tint..........Search Down
- cleaning injectors and coils
- Its been a year since my accident.
- vtc strangeness (a brand new kind of it!)
- control panel light out
- May be buying a VE 5-speed, need a little advice
- Changed my belts and...
- Won't start after VTC grounding
- Is my transmission on the way out?
- 94 Check Engine Light
- Max Sighting In Old Saybrook CT
- 90se 5speed ,sounds like a old Volkswagon
- maf sensor
- Leatherseats.com seats are in...
- what happens if you mix injector types?
- ””HELP!! Stalling = trans...
- anyone with y-pipe + cat-back please help
- Headers
- Axles.. Changing them.. after a year
- Backfire
- VE Powered Radio Flyer!!! Pics Inside
- 91 A/T Problem
- Ambient temperature sensor questions
- cleaning cloth interior...
- AAAAAAHHHHGGGGGG Alternator
- noisy lifters
- cutting out...fuel pump???
- Anti freeze oil mix and wont accelerate
- almost had a dyno
- Fuel Injection Problems! Help anyone?!?
- I Have It!!!
- JDM sidemarkers
- whats the percent rating for our brakes
- Trans / TC whine
- max not reving above 4 grand in gear
- i need your 2 cents
- Another damn Knock Sensor question
- Wiring new guages - Help please...
- Control arm bushing replacement
- Map Lights
- Replacing Cassette player with CD/Cassette combo
- Cutting shifter
- 2 questions(radio & speakers) cant use search right now
- Pictures of finished suspension.
- Anyway to give my Max a deeer/louder sound???
- My new front lip pix.......let me know what you guys think........
- AC recharge
- Bmw headlights h7 wiring questions
- Chrome Molding
- I'm trying to install a newer bose amp in my 90
- Change Your Camshaft Position Sensor Today!!!!
- New Guy, Some questions
- VG to VE tranny swap in 89 SE
- Need detailed instructions on installing Tokicos shocks in San Diego
- Stolen Car Alert In Seattle
- tranny question
- st springs
- Started to repair exhaust manifold studs
- What Is The Best How To Site For Someone That Wants Do It Yourself Instructions......
- Temperature guage no longer working...
- Mother Of God!
- replacing Condenser
- Where's a good place to get Tokicos installed in San Diego?
- Getting a maxima Need as much help as possible!!!
- aquiring reflective tape like on the 240SX
- door lock timer question
- how to tcu?
- sunroof glass removal
- AC compressor
- Power antenna replacement
- Heater control lever...
- maxima ve got clobbered, good body shop in N. Atlanta area? (pics)
- Search??!!
- Got my Stuff Yesterday
- Revs hunting all over the show
- G35 Sedan muffler on 89-94 Max!!??
- Ring Light around ignition
- Levoc Automatic Shift Knob
- Ultra S Underdrive Pulley
- Squeak at low speeds
- Exhaust smell on high speed
- final mileage pic (finally)
- VG Gas?
- 93 Maxima overheating
- sentra grill
- cutting springs
- sound clip and choice of muffler, need deep and throaty sound
- what is the cheapest place to order Tokicos and sway bar?
- 92 SE Clutch
- Um, VG popped PS Line?
- how much to get car repainted same color?
- 120,000-mile service rec's?
- 89se ?
- Looking for a good place in the Seattle WA, area for a auto rebuild...............
- R-134a retrofit
- yet another intrax question
- Wheel bearings noise and stereo tape question
- Vb Mod
- JWT equipped VE dyno request
- IMPORTANT suspension question for lowering
- new engine
- Quick question
- intake
- New control arms today......
- 3rd gen cup holder
- Need help on my gauges
- Bose Audio Replace Dilehma
- Suspension Options
- V-IZZY Pics of Crazy4maxima's new VE 5spd
- Pix of my headlights w/ fogs and tinted tails....
- Basic upgrades
- Steering Wheel replacement?
- Air flow in the trunk???
- Replacing suspension.
- Working at a nissan dealership to learn more?
- dash & a/c ? gas tank too.
- Ya guys might want to check it out
- bolt ons?!?! Are you scared?
- spark plugs
- Quick Question
- Best price for Koni struts?
- Are all 3rd Gen Struts interchangeable?
- Sprint Lowering Coils
- Adjusting Idle
- What to do about weather stripping.
- Failed Vtc Make You Stall Hesitate!!
- Antenna issues
- Water Pump Install
- Anyone know of a good Maxima mechanic in the Seattle, WA area that can help me fix
- Engine removal.. is top removal possible
- '94 Maxima RPM jumping and stalling
- Finally my Door Locks Work!!!!!!
- 4th one
- power steering
- custom trunk kit
- some car trouble
- Tranny Update and New Question
- o2 sensor
- Need HELP. Bad vacuum leak.
- to chris91se
- Noises ????
- Axle keeps slipping out when I drive.
- Emergency, Anyone With Alot Of Tranny Knowledge?!
- fixed something! but I don't know what!
- can you ruin one gear?
- i need a new motor !
- Engine stalls only in the rain...
- VE/VG question:
- sometimes Idle Speed remains at 1500 and doesn't drop to normal, what can I do?
- Smelling gas in the morning.... Help!
- 92 max SE with an intermittent stalling problem
- Paintscratch.com Is Awsome !!!!!!
- Wheels, wheels, wheels
- Rb20???
- lubricating window regulators
- Stereo rattling something in the roof
- supercharger kit
- Maxima 91 audio active speakers system (New head unit installation)
- carpet coming loose
- Which OIL filter to use?
- cb radios
- rate my car http://www.cardomain.com/id/va1adez
- i thought the day would never come......
- Something else ive noticed that is different on my auto vs my 5sp parts car..
- WSP y-pipe fitment
- Some pics of one of the many current projects i'm working on...
- bad switch: easiest way to get window up?
- newer factory mufflers?
- to leather or not to leather?
- service manual cd?
- Gauge Pillar Update!!! --->
- Can't search . . . must post boring thread . . .
- TPS question
- I just changed my bearing and now I hear a grinding.
- Cold Air Intake...where Oh Where?
- Where to buy the Knock Sensor Sub-Harness Connector?
- Question regarding rough ride w/ my GXE
- where is the coolant drain plug indicated on the owner's manual ?
- rpms fluctuate
- the temp gauge
- Help a 3rd gen fellow out
- steering wheel
