- Noise from Engine cooling fan
- Invest more money into 91 GXe, or get 97 SE?
- Distributor Cap ?s
- "general maxima discussion" is biased
- Pwr Window
- warpspeed y-pipes
- 91 Max Recall
- Q: Shaved antennas
- condensation in my trunk
- GXE Battery Post Position?
- :( Need More Help....
- power dies ??
- Ahh now thats a clean engine..
- Homebrew CAI / MAF Relocation
- Any way to test a MAFS?
- Hood Lift Supports-a less expensive solution
- need help please!!
- What's wrong with my mom's stereo?
- ecu
- Lopy idle, running rich/lean, misfiring. Read if you have these problems!!!
- Can I replace 1992 bose HU with a 95+ HU?
- Whats wrong with my car
- anyone know the DB for a flowmaster muffler compared to stock muffler?
- Speedometer woes-- speed sensor?
- MAF Sensor Help
- creaking door
- rough start!!!
- Anyone had their MAF go bad?...
- Quick Question
- new window regulator
- (REAR) Brembo Cross Drilled/Straight Slotted Rotors
- what is the difference between a straight through muffler and reg. muffler?
- ST Shocks
- ******You wanted a triple gauge pod pillar now you will have ne******
- spark plugs
- spark knock
- Pink injectors?
- Problem with steering
- Y Pipe Removal
- need advice on broken bolt
- Rear Brake Pads
- Interesting na 300z radiator vs maxima unit
- 1994 Keyless entry maxima se
- need help with turn signals
- Noise - Wheel Bearings?
- Dull finish
- Foglights for 3rd gen gxe
- I NEED HELP!!! ALL 3rd Gen peeps who have side marker lights installed
- MAF Sensor Transfer Table & Wiring
- Thanks.....
- turbo VG30E
- ac fan problem
- Gauge Pod on the Pillar
- Quick question
- Ignition Coil Question
- I got gas
- 2002 SE wheels on a 92 SE?
- G/F's Maxima in a wreck. Please look here!
- How to add tranny fluid in a 89 SE 5-spd?
- 1990 Max SE engine to sentra?
- i want more power!!!!!!
- Fuel injector type?
- A/C does not turn on right away. Help, any ideas????
- Sway bar
- metal brake line rusted and leaking
- Fixit man wants $1500...should I spend?
- You Know You're a VG Driver When...
- Fold rear seatback...
- High Perfornace CV Shafts
- Changing the manual tranny fluid on my 92 SE
- First Mod!!
- O/D problem, please help!
- swap!!!!
- valve cover polishing
- anti hijack feature...
- Painting car need to take off spoiler
- will I need an Alignment since....
- 95+Motor fit in 3rd gen?
- Headlight help
- which high flow cat?
- how hard is it to replace auto tranny?
- quick question!!
- Spark Plug Gap?
- Removing Stock Corner Lights
- How do you shave the middle part of the trunk
- how many hours of labor for an engine change
- Fuel Pump Went! Need Help
- Redline Mt-90
- my car running a little rich
- Will you recomemd changing Timing belt together with
- Question about KS TSB Sub-Harness
- Just curious on horsepower now......
- Compression and Leak down test on VG30E
- question on blinkers
- Help with 91 SE Upgrades
- got back on the road with a max again
- wierd question, help needed
- Im up to my 3rd alternator... soon to see a 4th >:o
- Street Racing
- door keypad help
- coolant drain on block???
- questions about speed mods(jwt ecu/UR udp)
- e36
- Disappearing antifreeze
- What is this ??
- Auto Shifter Wires
- I just bought a 90 gxe give me ideas please!
- How could a 19 y/o go about getting a 3rd gen max
- need help fixing climate control display
- No fuse for keyless entry?
- turbo for 93 se
- AntonTheGrey's Gauge Swap and Intake Mod ***Pics***
- help
- What's Next?
- How Much R-134a ?
- cigarette lighter fuse
- Such a nice day to wash the car.......
- question on buying a maxima
- A/C Problems
- OK to powerwash engine?
- problems with just aquired 92 maxima
- Changed My Gauge Cluster Now I Need Help
- beamer headlights
- Gxe Stock Air Intake Warning
- Will 85/80 watt bulbs melt the harness?
- Gas guage faulty??
- Preview of Gone's garage work ***Pics***
- will injectors of a different year work
- Temp. Control Digital Display
- Which intake for an '89
- Cefiro Projector Headlights?!
- VG30E Maxima headers available
- tranny question
- buying 1994 Maxima SE questions/advice
- Somewhat of a newbie and wondering if somebody has these headlights installed.....
- how much freon and tranny fluid?
- Look at this Max
- problem with my sisters 3rd gen, please help*
- problem with my sisters car--please help
- transmission problem please help
- Don't whine
- VG Intake Modifications, WOW!!!!
- Climate Control removal
- Brake noise when almost stopped?
- warpspeed....
- anyone have valve train problems with their VE?
- oiling the antenna?
- how to check AC compressor is switching on?
- u-haul sucks
- will these rims fit?
- New or refurbished injectors?
- AC Repair Estimate
- Triple pod gauge pillar pod pics--->
- Couple questions on 93
- possibly buying a 92 SE 5-speed... need some info
- keyless entry with the 93 Passive alarm
- One of my headlights is out...
- off topic -- car whistles/Bubb Rubb
- please read....
- Somebody Broke My Window Again
- shifter bushing
- i need shifter position piece
- cleaing injector wiring/terminals
- how to remove climate control
- where to get an injector harness
- Ebay VE's
- Raybestos Quiet Stop
- Bose Double Din CD fit in my Max?
- Stillen Body Kit
- First thing I should do to my max? Quick Questions too...
- finally...
- where did the oil sticky go concerning filters
- Big hello to the Max crew...
- 7" LCD and PS2 installed...pics...
- window auto down not working
- What's Next For More Power?
- What could THIS be?
- WOW.... just found out my car needs over $1000 in JUST suspension parts!
- Condenser leak
- Loud Knocks on Front Passenger
- Motor Mounts??
- My specific hesitation problem
- My 5 spd and this freakin heat
- chanign cruise control swithc yes its a rice mod
- Headers?!
- Back of Max
- how much tranny fluid?
- Summer cleaning
- strange sound at high RPM
- if one injector is bad, should all be replaced, then?
- Timing marks on a vg30e
- 240 rims
- how much milage
- Leather Seats
- FSTB Torque Specs
- Installing Side Marker Lights
- Brembo disc
- 93 VE 5 spd w/ 106k Y o N?
- Many Questions
- reverse lights
- Shifter bushing question
- just got my maxima, 2 annoying problems.. please read
- Hurrryyy!!!!!!!!!!!!!!!!!!!!!!!!
- Location of door lock timer
- lifters i think....
- Will these headlights really fit?
- Got new cat installed
- Window help?
- 3rd gen coilovers? weapon r
- How Quick Do You Refill Your Brake Fluid?
- 3rd gen automatic tranny problem
- Gredy system developed leaks-Yikes
- exhaust HELP
- adding door key pads
- Flywheel Upgrade
- Flush your brake fluid...
- Painting my maxima...!!???
- Could someone please help. I have a quick qestion.
- GXE... ticking noise. for a couple miles and every time I start it up
- Door Locks (rewiring question)
- Anyone bought a ypipe from ebay yet any feed back
- What is that strange black cylinder in the trunk?
- AAARRRGGG! Sunroof bolts will be the death of me!
- introduction/keyless entry question
- Shift knob won't shift
- nismo floor mats
- About Automatic Shift Knobs
- Headlight harness
- how many people would be interested in JDM engines?
- buy rebuilt vtc's ??
- Digital Dash Repair 1990 Maxima
- Any nice wings??
- Any positive experiences with tranny rebuilds???
- Using Ebay questions.
- Cross drilled or slotted? Brembo? powerSlot? etc.?
- New Front Brake Problems
- Engine ran rough, gave it a tuneup, seems worse
- any help appreciated
- My Max won't stay started
- Clicking SOUND inside Maxima
- step one of my color change is complete (pics)
- Help, i need help.
- Pulsing sound, Not CV's clicking
- Help Radio Not Working No Sound
- How do I check/test Fuel Injectors: ECM code 51
- ANY offere in nyc 91 gxe whole maxima, EVEN DELIVER FOR FREE. mods plz dontlock/move
- just wiring switch for leds. any suggestion where to mount
- I need to check out your opinion about my car n price
