- how do you keep the door moldings from aging or fading?!?
- Stock 60' for VE auto
- autozone sells 3A Racing Mufflers
- NH Meet (just 3 days away!) July 26th in Manchester - sign up!
- DTES on a SE
- For those Auto-Manual converted owners
- muffler patch
- Hella Supertones installed today
- alternator warning light
- What kind of front lip should I get? Which one is best
- Car died (sort of) please help a dumb kid
- Need major audio advice.
- Autozone Question
- Intermittent misfire at idle
- front door panel removal
- E36 installed... watcha think?
- speaker size for 3rd gen maxs
- Seatbelts
- Fuel Injector out - any ideas for replacement
- What could this be???
- 300zx rear brake fitment
- oem pws hose vs. aftermarket?
- Help!!! No Radio, No Sound, Makes Me Crazy
- CAI for se's
- 5spd tranny question
- Addco RSB Installed, well almost
- nismo1989 again
- stereo install
- fuel pump
- Fan Blows out weird stuff
- why does thid happen
- how to replace axles link please
- Spring suggestions
- what is normal compression for a vg30e?
- grey lock control box removal
- how-to adjust idle?
- Bose Stereo Question?
- what model max?
- Cheapest source for oem manifold?
- GXE tranny stuck in second
- over heated??????
- VG to VE swap...(no, I didn't do it, just got ?s)
- Column stock switch
- Help, cat bolt cracked in half. look at pictures
- 94 Ve Stalls At 140mph..like Whoa?
- transmission flush with amsoil
- Cleaning Intake Manifold on car - Bad Idea?
- Pictures of Wings West Bodykit
- 300 ZX master cylinder
- how to Get the CD out...??
- how much can I haul with my 92 GXE?
- HELP!!!! Parking lights not working!!!!
- Engine Bay Cleaned by Joe (Maximan190) Thanks!!!!!
- 3rd gen owners that have drove a 4th gen..
- Question for the Moderators
- nismo1989
- How can this be
- Question About Window Tint and Proximity Sensor
- Identify this electronic box
- HorsePower?
- Quick Wire Color Check (power antenna)
- timing of timing belt
- Rust!!! Noooooo!!!
- car not starting
- I think my alarm locked me out!! Help!!!
- Interior Swap
- Skipping
- Rear disc brake conversion complete...
- Just got the 411 on my suspension...
- I finally modded my 92GXE's lights to match my 2nd pair of UK corners
- Window switch repair
- High flow Air filter---strange noise now
- climate control light dim
- Not a good start.....
- disabling ABS
- Auto tranny on its last leg.. 2 flush or not?
- Speakers in the rear doors
- clicky/grindy noise
- new info on my troubles
- Radar Detector
- idle messed up after injector change
- ADDCO Rear Sway Bar
- Help with Redmax's Tv
- slave cylinder
- Gauges in your max
- next mod ???
- I got a little carried away, i know i can use one, i need help.!
- my latest "mod"
- Really Quick Tire Size Question.
- cluster question
- Timing Belt Replacement Experience
- electrical problems!!! HELP!!!
- Installing 10 gauge wire through firewall
- wipers don't return to bottom of windshield
- Stay Awake!
- rotor bug
- Proper LED for above radio?
- Please Read. Any help, thank you
- Interior cleaning
- 300zx Parts
- Drum Brake Replacement, Please Help
- Neighbor backed into my max
- Looking for rims for my 90 max!
- headers
- Frankencar intake
- window regulator ?
- Squeaking noise
- Car Starting Question
- KS vs. MPG
- need some help
- One quick question.
- How about the FSM for a 3rd gen?
- Transmission problem
- Man I love a clean car!!!!
- what is the % vlt of the factory tint?
- modified shift knob and e-brake handle...
- Check Engine Light Rough Idle
- Homebrew CAI / MAF Relocation w/Photos
- Is there anybody here that has actually set the timing after a rebuild?
- anyone seen these angel eye foglights?
- power/comfort switch not working?
- Black Cylinder in the Trunk of a 92
- Fuel injector cleaner
- How much for Freeon??
- Engine shakes
- unorthodox pulley
- where can you buy a wraparound headlight cover?
- Dashboard Electrical Problems
- Problem with Gauges
- Road Trip, need help on mileage
- Nos
- Aftermarket body panels?
- 3rd Gen Gets the Beaterz Make Over
- VE 5spd Squealing!!Help!!
- polished rims
- Meineke muffler vs magnaflow muffler?????
- link to kalebs 5spd swap writeup?
- I live up to my org name, look inside and see why that is, so much more to do
- polishing intake manifold and powdercoating valve covers?
- how bad do KYB and Sprint really suuck?
- MAF Relocation/MAF Wire Extension
- 24 valve DOHC engine info needed
- Question on knock sensor....
- what is wrong?
- Speed Sensor - Again.... any gurus out there?
- Progress rear sway bar??
- strange...
- front bumper
- what color injectors do i have?
- Aftermarket Headers
- Are white tail light/center panel replacements out there?
- Engine Swap Questions
- Clutch pedal plugs
- Location
- pics of ma car
- Bent Control Arm?
- Seat belt chime
- Diary of my jdm VE swap
- Battery Disconnect = Crazy Shifing
- Brake light won't go off
- Wierd power problem
- average tint price?
- 'Engine check' with misfire on starting
- Engine + tranny
- Thermostat Question??
- 89 Max BOSE HU wiring colors?
- need pix, im considering selling my 2nd gen, for a 3rd
- Headlight won't light up, but the bulb is good?
- how many people mod their car's but dont race, and vise versa
- Matt's Mod of the Week
- Fans staying on after car is off.. Summer is hot!
- 92 fuel pump replacement
- door locks
- Track times w/new ECU
- camber
- When it rains, it sputters !?
- Radiator fans not working?
- preparing the max
- Help me im in window regulator hell
- timing belt
- Ve Pcv Valve Hose!!?? Maybe ???
- Help!!!!!
- Vibration and low pitched noise when turning
- need some help!!
- " Ah Shi?
- Old Car noise!! get it out!!
- speaker questions.
- Roughness / shaking at different times...
- my window keeps falling down
- Factory Spoiler Question
- Car runs cold on the highway ?
- apexi s-afc II
- Mods
- Torn outer CV boot - please help
- Cleaning Fuel Injector
- Radio Problem in Maxima...
- quick question: liquid gasket VS. gasket+sealant
- HELP! Can't get key out of ignition
- Indigo Pedal Installation Help
- JWT ECU is finally on its way! track time!
- Changed injectors, now car has trouble starting??
- Problem after problem
- Engine Question
- steering wheel questions
- Bad Transmission?
- Make car louder.....
- Changing bulbs behind the digital clock and digital temperature control
- Revamped Cardomain page - Check it Out !!
- 300zx Z32 Cams
- Frozen Rear Brake Caliper
- Finally put my 2000 SE rims on. New kickass tires too
- In which way should I upgrade my exhaust?
- Totaled Maxima
- Power Locks???AAGhhh
- How much is a fuse box?
- R-134 Adapter Question...
- Fuel Pump / Fuel Level Sending Unit
- cruise control is over-doing it
- HORRIBLE squeaking
- installing distributor
- 1990 Max GXE Trans axles Comments Please
- removing the side moldings
- General 3rd gen questions from a 4th gen guy
- Very long need help, please someone can help me figure this out.
- stock anti theft system
- Still no luck with my heistation, back fire, missfiring VE5spd
- Great News
- Got my Max last week...
- This is the end, thank you to everybody!
- where can find this
- air filter adapter
- Intake Manifold and TB Q's
- Mustang wheels
- cant find the link
- Vibration at HYW speeds
- WarpSpeed B-Pipe
- cant find my brain
- Water or Cooloant dripping into Car's Interior
- AC r134a conversion...long term experiences?
- which alternator
- are the 2k2 max brake systems the same as ours?
- ABS and snow...
- combo intake
- Want to learn about your car or modding?
- UK Corners and UK Grille
- Are VQ30 and VG30 transmissions the same?
- Tint thread....this time it is YOUR opinion that matters.....
- how much will i get for my car?
- max sighting in an old school advertisement
- Air conditioning
