View Full Version : 3rd Generation Maxima (1989-1994)
  1. Bulbs to hot???
  2. where to get seafoam???
  3. Exhaust and Cold Air Intake
  4. I hate SUV's part 784737432
  5. full catback or just a muffler for my GXE?
  6. Intermittent odometer
  7. 93 Maxima Se Radio Won't Work
  8. window roll up/down speed
  9. Plug Wires - a/m 8mm?
  10. sigs pics are not showing up for me
  11. Auto and Manual Trans Comparison Question
  12. A Couple Questions - Kinda Important
  13. Project Maxima: Skyline Tranny?
  14. auto trans shop in Dallas?
  15. anybody know what FICD relay is??
  16. Strange no start, stuck key problem
  17. Dropped the tranny :)
  18. Matt, Jeff, any other Fidanza Owners please help!
  19. Aftermarket fuel pump won't work?????
  20. 300m or 1/5 of mile
  21. Valeo clutch_Fidanza flywheel
  22. probs with engine cooling fan???
  23. What next?
  24. How difficult to replace Power Steering Fluid Reservior Hose
  25. 1991 Nissan Maxima SE (standard) Not Starting --- FUSE BLOWN (Help?)
  26. Broken transmission fixes itself!!! What happened??
  27. tranny self-diagnostics ??
  28. When is time to replace shocks
  29. Fuel Pressure or something else?
  30. skyline tails
  31. do we have split diagonal brake systems
  32. im moving but my speed says 0
  33. should my temp stay on normal
  34. Building Turbo Max Se
  35. Rotor Question
  36. screw on the ecu
  37. levoc auto shift knob w/ e-brake
  38. So, the installation of my Addco RSB wasn't as smooth as planned
  39. vacuum question
  40. 92se Ecu Part Number
  41. tranny slipping
  42. What steering wheels will fit?
  43. trunk fabric replacement
  44. super chargers
  45. Help!!!!!!
  46. Does anyone have their max painted...
  47. noticeable drop in Gas Mileage
  48. Can These Be Installed In A 3rd Max
  49. Front Passenger Suspension Clicking Noise!!!
  50. Size of Licence Plate Bulbs
  51. Pix of new 35% tint and black stocks........
  52. 5 sp swap.
  53. Some Questions
  54. Custom front speaker brackets. New ideas?
  55. Quick Tranny question
  56. Bought a GXE, miss my SE
  57. need help asap!
  58. Gear shift will not move
  59. Can I come to the meet in Natick, MA next week?
  60. Finished Rebuilding & Improving Suspension
  61. 18's Too Big??
  62. slyvania silverstars
  63. Umm Last time I checked, gear oil should never be in with the starter right?
  64. Fuel pump
  65. High Milage Contest
  66. Maxima Stalling
  67. My New Maxima, Pics Inside!!!!!
  68. ST SHOCKS STRUTS - Any good?
  69. U-Shaped hose
  70. Quick engine stall question
  71. Orlando
  72. wiring diagram 1989
  73. Online manual?(URGENT)
  74. battery question
  75. projecter and regular headlights?
  76. Won't start after overheating
  77. BMW E36 Write up
  78. good place or site to buy parts!!!!!
  79. How does the AC compressor work?
  80. About Loweing My Car. Will It Work?
  81. Injector prob,any help
  82. Letter to Service Department
  83. I need advice with this
  84. Hard as hell to find a 5-spd VE!!
  85. My $3,500 mod challenge....
  86. turbo update
  87. Before starting on changing to the WSP y-pipe....
  88. bad misfiring and high idle RPM....need some help
  89. brake pads
  90. motorized steering wheel
  91. aaaahhhhhh
  92. i lost my fuse picker
  93. Flowmaster Muffler Question...
  94. abs pump/actuator questions
  95. Steering
  96. never let your friend drive your car
  97. updated cardomain *new pix* sign guestbook
  98. ATF ? 94 Maxima Auto Tranny. What have you used? What works well?
  99. maxima airbags!!!
  100. Cost of A/C pulley
  101. abs pump/actuator
  102. update on my max, for those who care
  103. Why 134a makes the compressor louder......
  104. any online chilton/haynes manual for our maximas?
  105. Clicking/Raddle after 35MPH?
  106. head gasket question? need help
  107. Little blast from the past pic
  108. Question about Katzkin interiors....
  109. quest for euro tails begins
  110. How to remove the dynamic weight thing...
  111. What in the world is this part?
  112. Alignment specification gxe vs. se
  113. tranny question
  114. help!!!
  115. Toyota filter
  116. k & N air filter
  117. how many tickets for aftermarket bulbs (tails,headlights.cornerlights)
  118. 3rd gen t-shirt on ebay
  119. upgrade wiring harness
  120. Another 3rd gen goes under
  121. Possible dead alternator, other things to look for??
  122. stock injectors
  123. Greddy Muffler
  124. bodykit sides
  125. Why my 93 Maxima is a piece of $hit
  126. spring install
  127. Power Loss HELP!
  128. WILL have relatively large financial backing...
  129. Speakers
  130. comfort/power/auto switch??
  131. I should have been paying attention so bare with me, Koni 101 help please
  132. Failed emissions test
  133. engine vacuum
  134. Newbie question
  135. Climate control lights question
  136. my window!!
  137. why are insurance company's so lousy
  138. remove them or paint??
  139. Swapped trannies, now hood wont close....
  140. Dumb tire question
  141. What Size Lugs
  142. compression test- bad cylinder?
  143. Ticking speedo on a '90 GXE HELP!!!
  144. i want new guages for my '92
  145. This is bad...right?
  146. Intermittent NO START _please help_
  147. z31 rear disc conversion... where is the write up?
  148. Max O/D bodywork update(pics)-->
  149. Hot ignition key???
  150. Need Linkage info/help
  151. WTF!!! listen to this.
  152. updates on project
  153. 6x9 Speakers problem
  154. Replacing Alternator?
  155. fuel gauge and low fuel light
  156. front exhaust pipe
  157. Help in my area???
  158. Which ECU Mod?
  159. Can She Take It?????
  160. Solenoid?
  161. side skirts
  162. Painted Valve Covers
  163. testing pics
  164. tps and tranny q's
  165. 2nd try: Help, tranny died?
  166. Make a 3d Model for NFS Underground
  167. tps/tvs testing
  168. place racing CAI
  169. What will my 0-60 time be???
  170. Help: Tranny died?
  171. Engine shuddering until it cuts off
  172. Clacking Noise
  173. springs
  174. My poor max's first car wreck
  175. Any VE 5spd guys using a Harlan Shift Light?
  176. BMW conversion: those who used BMW brackets
  177. death to the alternator!!!!
  178. any problems?
  179. E36's
  180. Fuses blowing
  181. Will Seats From A 99 Gle Fit A 92 Se?
  182. Defective tranny from factory?
  183. Japanese Engine for 3rd gen maxima
  184. Acura RL bolt pattern/offset the same???
  185. Japanise Engine for 3rd gen maxima ( INFO.)
  186. rusty rockers
  187. intake question
  188. does the ADDCO bar some with anything other than the bar?
  189. Body Shop in ATL - problem with convt top
  190. Front Speaker sizes
  191. lookin for control arms/cross drilled slotted rotors
  192. Sup guys
  193. 3rdGen Question from 4thGen Owner....
  194. Electrical Help Please!
  195. newbie type question: engine differances btwn se and gxe89-91
  196. Can't time my 89'gxe after valve job, etc
  197. Parking light fuse???
  198. 6 sp in a 89 SE?
  199. Speed Sensor
  200. Won't Start
  201. Once I rebuild my tranny what else should I worry about?
  202. **->Aftermarket Exhaust Question<-**
  203. Quick tranny question
  204. If we have front wheel drive why do the back tires go bald first ???
  205. Help - check engine light and misfiring with VE Engine
  206. PIc of my bmw headlights.
  207. Installed Suspension Techniques anti-sway Kit
  208. goin into shop soon need advice
  209. Popping sound!! Help
  210. Bose Cd/cs Help!!!!!
  211. Sun Roof Problem
  212. Shocks/Strut suggestion
  213. 7 Color Angel Eye Foglights
  214. plugs wire cap a nd rotor
  215. where's ECU located on 92 GXE
  216. How many gallons in a 94 gxe gas tank?
  217. Maxima problem! Not starting in mornings
  218. bulb question...kinda stupid (im still dumb)
  219. Engine Mounts
  220. Need help installing Suspension Techniques anti-sway kit
  221. ECU threw a code 13 ??!! then code 55 !!
  222. where is it the cheapest?
  223. PRND21 Light Bulbs
  224. Got a window question
  225. Help me out PLS. Ticking Noise ?
  226. Any VG guys interested in copper head gaskets?
  227. What to spend $200-300 on for performance?
  228. question about APC SUPER WHITE 1156/1157 bulbs..help
  229. Is my clutch dead??
  230. Power steering belt troubles
  231. need help asap!!
  232. sarona bodykit
  233. rims and tire sizes
  234. apexi afc 2 vs jwt reprogramed ecu
  235. Please Help Me Out
  236. 5spd conversion or Sell? need advice
  237. Back to say what's up...
  238. 3rd gen skyline body kit
  239. stock vg injector size
  240. what is it??
  241. Car won't start ... timing belt?
  242. bmw halo question
  243. Bellow Boot? Rack & Pinion? WTF?
  244. VG intake midpipe
  245. VG engine- bad hesitation and now will not start!
  246. how do you keep the door moldings from aging or fading?!?
  247. Stock 60' for VE auto
  248. autozone sells 3A Racing Mufflers
  249. NH Meet (just 3 days away!) July 26th in Manchester - sign up!
  250. DTES on a SE
