- Changed the battery, now my blinkers don't work...WTF?
- got my e36 headlights installed!!!!!
- Fuel Pump...
- brake squeal, how long til i must change the pads?
- Subwoofer install pics
- Mis-matched Struts
- Garrett M24 A/R.48 Intake
- New wheels suggestions???
- rebuilt tranny question
- odometer/speedometer question
- cams
- The box
- Check This Out!!
- plese help with engine rebuild
- engine rebuild
- Maxima Electronic Alarm System. Doorpad. HELP
- another (stupid) knock sensor question
- trunk does not open by pressing the button
- Warning ...Paeco not as good as we thought
- corner bulb question
- Ok, so i'm a newbie...
- Does $759.- sound right to replace a Knock Sensor?
- headlight problem, need help!!!
- Errors from self-diagnostics
- Japanese parts for Maxima
- TT Injectors
- 92 maxima headlight problem
- warped rotors???
- what is wrong with my Maxiam?
- power lock
- Lowering the rear only
- Brake pedal normal / low / normal
- Roof Racks
- Clear Corners, just a quick question
- Am I getting ripped off?
- knock sensor
- suspension setup question
- Yes another newbie post
- Euro tails for a 3rd gen max
- ungrounded VTC's
- Tps
- Pace Setter Headers
- Check out this A31 Cefiro R34-style front lip
- brake light problems
- bought the VE with 72k
- Caster angle off after Eibach Drop
- I ordered new tires today
- Bye bye 3rd gen =(
- I am now the proud owner of a..
- I made a 3rd gen maxima for a video game!
- Got My Strut Bar Today But I Cant Get The Damn Strut Tower Bolts Off
- Changing over the A/C
- 92 SE Power Lock, Power Trunk Release Problems
- 92 Ve 5 speed 70k
- Tranny slipping
- any 3rd gen with 18' SSR's?
- 300zx rims
- which lights fit guys
- Any good info about Maaco paint jobs??
- I Need Your Help! Plz Read!
- quick amp question
- Gas Smell in car- Even After New Fuel Lines
- car stalling/ problems linked to water?
- Search down...How to remove/replace speed sensor???
- which year 300zx breaks fit us 3rd gens
- Stillen Rear Valance
- not starting
- bypass nutral safty switch for 5spd swap
- A/C belt seems too big (UDP install problems)
- 92 SE power locks not working
- shaking at low rpms
- Speaker Pods for 3rd Gen
- 3rd gen community... i've been thinking lately about a new car...
- Black exterior and Black Leather Interior ownz all
- Commuting
- just pontificating...
- Noise from front - help - wheel bearings?
- Hesitation on 92SE
- Rear lights will not turn off, or HUD lights
- Two secrets to good gas mileage
- Window switches go up but not down?
- Any 3rd gen with Racing Hart C5s?
- 89 Digital Dashboard
- 5 Speed Transmision
- Parting with my 1990 max
- Climate control back lighting....
- Shaking at high speeds
- Engine noise
- starting seems tedious?
- Steel Wool
- Analyze This plz
- Help with exhaust questions
- Tranny rebuild issue- 3rd gear
- Replacing condenser?
- need help buying a 93
- how many miles per 1/2 tank of gas
- Exhaust
- Air conditioning compressor problem :edit by Jeff92se:
- constant battery drain
- Need help finding.........
- Running with no oil !! What damage??
- Newbie Questions...
- High beams--Help anybody
- Fiberglass Field of Dreams (Wordy, but please check it out)
- gauging interest for CF hoods
- warpspeed y pipe with the g-reddy cat-bak how should i install them
- post-exhaust stud replacement:gaskets smoking?
- I need BIg Help i lost my only Key
- Wrong Plugs
- fuel gauge needle dropped
- Any tips for bolting up the bottom part of the a 5spd?
- Buying a 1990 Maxima
- VG33E, in a Maxima?!
- Nissan publications
- Parting with my Max
- lookin at a different max
- would 65w/45w headlight bulbs melt the harness?
- keyless entry and alarm question
- sputtering ???
- warpspeed y pipe vs cattman y pipe
- i broke my power switch what to do now
- auto tranny...
- saw this car.... omg i wish i bought it
- NZ aerial replacement
- VG quarter mile time
- intake
- Control Arm Bushings
- door panel
- Cruise Control not working?
- Auto tran. Shifter sticking...
- thud sound when accelerating or braking at low speeds
- I need advice about a noise
- looking at 94 gxe
- limp home mode
- How Do You Change The Abs Module?
- air conditioning poping/clicking
- I miss you guys :(
- My lights got me busted!!!!
- Updated my Homepage! Check out my E-36's installed.
- stupid question maybe....
- Check it out - new wheels!
- how to reset the ecu
- out of curiousty!!!
- whack temp gauge!!!
- manifold studs costly???
- speaker bracket advice
- How do you turbo a maxima??
- Fuel Injectors???
- Poly sway bar bushings
- Rear strut cartridge replacement (KYB)... have a question
- exhaust manifold????
- Climate control display
- SHIFT_New Tranny :) :) :) :)
- fog light bulb replacement
- Guys going to NOPI but havent registered please read
- Help an old friend out guys
- I go coo-coo for doo-doo puffs!
- injectors and coil
- will the shifter from a vg fit on a ve 5spd
- Opinions on tires
- Help w/ hella supertone horn install!!!
- Do you know anything about Nissan computers?
- Bucking and lurching--fixed!
- transmission swap possible?
- goo gone (is that what its called)
- auto tranny issue
- Cars almost done, well sort of....
- Going to the track soon, which way to run?
- SE Anniversary Edition
- Need help.....!
- would a 300 zx tranny fit a maxima
- sub frame connectors
- Anybody have any experience with...
- warpspeed vs placeracing
- will the g-reddy cat-bak fit the gxe
- any sound clips of a g-reddy cat-bak
- whats the most hp we can get
- look at these eyes....angel eyes
- small LEDs for dash switches
- Squirting Time!
- Buying used car 92-96 Toyota Camry vs 3rd Gen Max
- Resetting The ECU?
- breaks
- Stalling and jerking on 1991 model
- Stock Wing
- Sound/video clip of Fidanza revving?
- bose radio system
- Tech details for DIY CAI / Intake Designers + cheaper couplings
- Busted timing belt, my options?
- under drivey pulley won't budge!
- used maxima
- tapping
- Help with my rear rotors for my 90' Maxima :bawling:
- 90 SE Injector Resistance???????
- question about the 9006 and 9005 bulbs
- projecters for a 3rd gen ? ebay item
- 93 GXE, check engine on - fuel injector signal circuit fault
- Price for a 93 max with odometer fraud???
- grinding
- OE Cold Cranking Amps
- Sounds like meatal hitting-Sprint/addco install
- new axles??
- Problem!!!! Need help A SAP Please!!!!
- Reverse light switch....?
- Anyone in NY here selling clear corner lights and also bmw head lights
- Rear bumper replacement
- Has anyone purchased and installed this aftermarket wing.
- VIN Check URGENT!!!
- Loose brake rotor
- NISMO cylinder heads
- Which Fuse? Help Please!
- ftsb/AC hose question
- Question on 1991 Bose audio
- new interior paint pics for my ongoing project
- indiglo gauges!!!!!
- How to change temperature sensor harness
- I think my problem is my IACV, what do you guys think
- Question on rear spoiler....please
- R32 Skyline wheels on 3rd gen, cardomain
- Cost to Fix VTC
- Ignition Coils????
- Tranny Service
- question about hid xenon in fog lights
- Electrical gurus "Headlight ?' Not the typical ?"
- Spark Plug Change Help
- 93 max wire colors
- what mod should come first
- greddy cat-bak
- Standing outside the car, key in hand, yet still running....
- $400 a good price for this susp. setup??
- my tranny shifts a lil too hard
- Temperature Control
- dead battery, dead alternator or what?
- rear speaker bracket question
- front door panel removal
- Seatbelt Sensor Problem
- Is there any hope for my rims?
- VG vs. 2.5 Altima...how would VGs stand?
- Front end ?
- Catbacks between VG and VE interchangeable?
- Settle this once and for all. Poll POST what clutch set up you have and recoomend
- Is there a diffrent alternator and compressor for the SOHC and DOHC engine???
- Need some help on a stalling issue
- digital climate control
- rewiring corner lights
- engine warmup
- factory manual
- engine noise & sound clip... PLEASE listen
- New Technology Injectors?? Will They Work?
- ECU Green Light Blinking
