View Full Version : 3rd Generation Maxima (1989-1994)
  1. Help Rough Idle Problems
  2. miracle stud fix?
  3. Nissan Maxima SOHC Front Strut Brace
  4. emergency!!!
  5. I may have located some poly suspension bushings and bumpstops
  6. Need a pic of oem pws hose at top?!
  7. How to swap my odometer
  8. What Do You Recommend Me.........
  9. i hear a knocking noise form the engine!!
  10. bosch platnium 4
  11. ticking sound....v.t.c.???
  12. I need help choosing, from someone who knows.
  13. Heat doens't get hot on 94 GXE
  14. shift_money hole....
  15. Priority Repairs
  16. ABS Sensor
  17. Raidator hose (what is is called)
  18. Spark Plugs
  19. What is this white buzzing box under my dash?
  20. one of my exhasut manifold studs are broke???
  21. 300zx TT injectors
  22. Power locks and keypad
  23. paint
  24. Door Inserts...
  25. What color Zone at Nopi
  26. Low idle miss
  27. Window actuators?
  28. 1990 Transaxle/CV joints
  29. Kilometres or Miles
  30. Need New Bushings! Help!
  31. Car skips or stumbles @ 65 mph
  32. What kind of Oil in 94 Max gxe? Simple Help
  33. Hawk brake pads???
  34. NGK Platinum Spark Plugs with NGK Wire Set
  35. Engine and Tranny advise
  36. Had whole exhaust installed but have sound
  37. Its gone and its never comeing back
  38. window regulator
  39. HELP! ALL New Exhaust - Magnaflow is Deafening!
  40. Timing belt on 89SE
  41. autozone power steering hose-wrong #
  42. Need New Bushings!!!
  43. Central Florida Maximas (moderators, please dont delete)
  44. Bad, or dirty fuel injector
  45. lowering springs
  46. Lost blinkers......
  47. Seat belt alarm/relay location needs disconection
  48. Downshifting in An Auto
  49. I Need Help Swapping Engine!!!!!!!!!!!!
  50. Its good to have freinds with 3rd gens
  51. Automatic transmission
  52. 92 GXE replacing fuel injectors
  53. 3rd brake light
  54. Who has a cold air intake in their car?
  55. JDM Engine for 92 SE
  56. strange noise coming from engine
  57. Help, A/C electrical problem. Who can figure this out?
  58. How to turn on signature for forum ??
  59. Why Thermostat so $$$$$$
  60. First mods for 89 SE?
  61. Is it worthwhile to replace transmission
  62. Pics of my new gunmetal wheels on car!
  63. ATTN: tranny experts(long)
  64. Conversion: Tailight 92SE -> 90SE
  65. Angel eyes
  66. Power Ant. Wire?
  67. site update with *new pics*
  68. Hmm..
  69. 92 Tranny problems
  70. vg valve springs
  71. Electronic climate control backlights..
  72. White/blue light illegal??
  73. silverstars vs. xtravisions
  74. Subwoofers and electronics
  75. cilmate Air
  76. Fianlly got done with all fluids change, one qestion tho...
  77. Tranny Fixed Itself??
  78. My rear discs use different sized pads? WTF?
  79. Anyone else out there got a Brougham?
  80. Starting problems
  81. computer reset?
  82. Bye bye '88, HELLO '92
  83. Noise coming from wheels......
  84. i need help asap!!!!!!!!
  85. Check out my custom trunk.. Pics!
  86. poping noise coming from front end when hard right turn
  87. Best 3rd gen - LOOKS ONLY
  88. How to change wheel studs??????? HEEELLLPPPPPP
  89. squealing stops when brakes are applied
  90. Thinking about filling motor mounts
  91. nissanmatic fluid...
  92. Ignition cylinder
  93. Smell gas when key is cycled
  94. Mysterious noises coming from the front suspension?
  95. Courtesy Nissan Web Site
  96. problems starting
  97. finally got my max back!!!!!!!
  98. Shave rotors
  99. Advanced Timing
  100. i'm leavin...but i'll be back!!!
  101. Turbo & intercooler
  102. Carrier Bearing on a 91GLE
  103. Hey what sup guys ...just a little opinion
  104. Tranny issues
  105. Emergency!!!! Tranny advice needed!
  106. Hey, im new here!
  107. Timing Belt Replacement VG30E SOHC
  108. Question re. Tail lights
  109. Power steering making noise?
  110. the boosted max gets stuck in 2nd again!
  111. NISSAN 15208-55Y00 Oil Filter
  112. Stupid friend broke passanger door! need help :(
  113. who's going to the NOPI nats?
  114. Rear-end repair
  115. for those wanting to take their side moldings off
  116. What should I do with my tranny
  117. Bearing Noise? NO FAQ on this.
  118. how to raise idle 92 gxe
  119. engine control module '89
  120. New member 1994 GXE Where to start
  121. lowest springs?
  122. CAI suggestions since WSP is out for who knws how long...
  123. It's been a while but...I'm back!
  124. How is the shifting on 3rd gen max
  125. How should our idle feel?
  126. radiator flush
  127. Engine mounts... question for those who have done it
  128. Max and the Circuit Mystery
  129. Can someone tell me whats wrong
  130. Odd Vibrations
  131. Door Panels
  132. Rough shifting after rebuild...
  133. can this be true
  134. ABS problems
  135. Looking for a good used trunk 92
  136. Engine installation Q - where does this bracket belong?
  137. so i broke a starter....
  138. Painting Plastic - Anyone done it before?
  139. Gains from Warpspeed Y pipe
  140. need your help gearheads....
  141. Fuel injector removal
  142. Display Caps Part Number?
  143. hawk brake pads
  144. caliper seals question
  145. Suggestions to replace Bose head unit
  146. I have a question?
  147. Good old "Lock Timer box"
  148. VTC problem and certain years
  149. Jim Wolf chip question???
  150. Attn: Those who's had Eibach and Intrax on their car, why did you switch?
  151. i did it guys warpspeed and G-Reddy
  152. Automatic Transmission
  153. stallin
  154. Seat Compatibility
  155. VERY good looking 3rd gen spotted
  156. 92 GXE rough idle and running
  157. For those with aftermarket antenas
  158. EGT placement
  159. body kits...
  160. new pics of grill and muffler and bezel
  161. Describe Your Exhaust System
  162. wheres the trany fill plug on a pre 92 5spd
  163. RWD conversion?
  164. Window regulator question
  165. throw out bearing?
  166. Anyone looking to install 13" Cobra rotors, take a looksee
  167. VG Turbo ( For all the VG peeps)
  168. Rear main Seal
  169. side moldings
  170. Thinking about buying a 94 max what color is the best???
  171. Grill Swap
  172. Just Joined
  173. Hope you guys find this interesting
  174. Doors wont lock with key...
  175. Midsection Trunk Lid...
  176. advanced VTC question
  177. Who has an oil pressure gauge on their VE?
  178. black smoke please help
  179. 300ZX engine swap to 5 speed SE?
  180. Automatic VS. 5 Speed SE
  181. is this 92se worth it???
  182. VE Turbo
  183. rear sway bar
  184. Caliper overheating?
  185. 3rd gen cruisin or racing? (GXE vs. SE)
  186. 93 Gxe First Mod
  187. question about CAI
  188. how hard to get the tach working????
  189. Sprints or Eibach the question!!!!
  190. Anyone know a good shop for my max in the Boston area?
  191. pics of my car damage in the accident and new pics of new 92 se 5spd pearl white my o
  192. Anyone used this clutch?
  193. power door locks
  194. Updated Cardomain site
  195. slave cylinder
  196. hey wsup guys..... i got a question....audio related i guess
  197. Questions on 3rd Gens
  198. 5 spd tranny question????
  199. t50h Torx screw and screw driver
  200. right signal lights are not working
  201. some of you guys might get a laugh out of this
  202. My VE dyno for those who dont check Gen. forum..
  203. I don't even no where to begin
  204. Need 89-94 Maxima pics for Cattman ad/website
  205. blah. finally got around to updating my cardomain page...
  206. Brakes and engine stall
  207. Radiator Leak
  208. steering wheel
  209. AC dying?
  210. best Haynes manual for a 92SE auto
  211. Sludge in Coolant Overflow Reservoir
  212. Strange a.b.s. noise
  213. 3rd Gen turbo kit available for YOU!
  214. can't remove center nut on strut
  215. 5spd is almost ready to go. Hope to drive tommarrow.
  216. Opinion Needed!
  217. Custom Kit?!???!?
  218. Uh oh....help!
  219. Finally Some Pics Of The Car In One Piece
  220. Need help with a few things with my 93 Max...
  221. Input on some noises I'm hearing
  222. poly urthane motor mounts
  223. New Shift Boot
  224. Bose audio...
  225. NGK G Power vs Laser Platinum Plugs
  226. Need Opinions from sprint owners.
  227. poor fuel economy
  228. Anyone know where to get hinges?
  229. window buttons not working properly
  230. check on my first max (rate please)
  231. Alarm goes off opening truck w/ key
  232. how many of us have rust spots
  233. How long for .Org stickers??
  234. .......29, 32, 35, 44 .........???
  235. rotor and brakes
  236. Broke or Not???
  237. An often overlooked emergency equipment
  238. Lift Points?
  239. abs or posy??
  240. Fair price for a rack and pinion install? Shop wants $650
  241. Alternator noise showing up on LCD, any ideas?
  242. abs brake problem
  243. polarg corner bulbs
  244. H&R coils
  245. Training wheels almost fit on my max and look sweet
  246. Changed the battery, now my blinkers don't work...WTF?
  247. got my e36 headlights installed!!!!!
  248. Fuel Pump...
  249. brake squeal, how long til i must change the pads?
  250. Subwoofer install pics
