View Full Version : 3rd Generation Maxima (1989-1994)
  1. driver door lock wont go all the way down with key
  2. Help. Maxima can't be started after replacing injectors
  3. I just HATE when you run out of room for Mods!
  4. HVAC sucked in water?
  5. VG30eT swap into my maxima??!?!
  6. Selling my Max
  7. Brake problem after new pads
  8. Electrical Gurus, your input please...
  9. What do you guys think about a 740iL early 2000?
  10. Cabin Heater Control Valve Assembly (Wiki)
  11. Crud. Right blinker. Electronics.
  12. Need to Unhook AT Oil Cooler Lines (2) - Will it drain and how long can it sit empty?
  13. Air Compressor & Wheel bearings
  14. VG30E engine replacement -- thanks Chris!!
  15. I'm breaking up with my car
  16. hp up?
  17. Painting the maxima
  18. PARTED OUT WITH MY 92 MAX.
  19. weird problem with A/C
  20. Does the 3rd Gen OEM Spoiler Decrease Fuel Efficiency?
  21. apexi afc neo
  22. Catty converter question
  23. Saying goodbye
  24. Spoiler rot.
  25. Brake Light Steady On (NO EMERGENCY BRAKE IS NOT ON)
  26. Huge 3rd Gen Photoshoot
  27. would you guys beat the **** out of these kids...
  28. Will Gasket Sealant Sieze Fasteners?
  29. Back issue arrived
  30. Windshield wipers
  31. 18inch wheels
  32. rims
  33. How to Activate the low fuel light
  34. Throttle body diagram anyone?
  35. Uberhass' trip to the nissan dealer!
  36. Weak braking power
  37. When Should The Oil Pump Be Replaced?
  38. Bose Radio Display Out
  39. External oil leak after high speed
  40. some pics i took 2nite
  41. Tax rebates a-coming, what ya buying?
  42. Replaced con rods, mains
  43. Tranny rebuild completed
  44. replacing an alternator
  45. misfiring cylinder
  46. Hose Questions: Radiator & PCV
  47. EGR Flare Tube - Lower Connection Source of Exhaust Leak?
  48. RE4F02A Filter Design - Can Someone Describe?
  49. What is the best place to drill for gauge pod auxiliary sensors?
  50. Key pad entry
  51. Carfax request, if possible
  52. antenna motor
  53. Do VEs have 4 wheel ABS or 2 wheel?
  54. replacing front seat
  55. Resornator
  56. HID Headlights
  57. Top plastic broken on injector, is it still usable?
  58. Is it Safe to Grease The Upper Manifold Hex Bolts?
  59. Front Suspension Prob
  60. gasket for IACV
  61. Question about Fuel Hose between Rails - Caps to hold on Injector O-rings
  62. having some trouble
  63. Better Brake Light Mod = melted assembly?
  64. Sugestions on Cold Air Intake
  65. Horrible Headlights
  66. What Is The Correct Torque For Fuel Injection Hose Clamps?
  67. Is it True That Injectors Rarely Need Full Replacement But Just Re-Build & Calibrated
  68. stock fog lights
  69. 160 or 190 Hp
  70. The max and I were busy today
  71. WTF? My Maxima is trippin.....
  72. Anybody have the 1993 FSM PDF?
  73. Styling the ORG stickers
  74. What Would Wait ... pin43
  75. Wet Fuel Rail - Possible Sources?
  76. Tranny Good! CEL gone! What's next?
  77. No Power to anything but starter and fuel pump.
  78. Pacesetter Catback
  79. To Sell, or Not to Sell
  80. Illumination switch
  81. Starting Problem '91
  82. How do I figure out which injector?
  83. Blinking Air Bag light
  84. help about clock
  85. misfiring vg
  86. Pink or Red Bosch Injectors - which one?
  87. Short Ram Intake Problem
  88. ABS humming
  89. Parking Brake Light
  90. where to get suspension bushing kit?
  91. How much is my '92
  92. might be selling the max next month
  93. How much to install springs?
  94. Cleaning MAF sensor (VE30DE)
  95. Muffler Questions
  96. car wont turn over at all, was fine this morning...
  97. VE- CPS o-ring??
  98. car acts like clogged fuel filter....
  99. RARE 1993 Maxima
  100. got burned with remfg injectors...best place to buy new?
  101. VG30E A/T transaxle leak?
  102. Line Pressure Drop resistor bypass with 5kOhms
  103. How Do I Replace The Windshield?
  104. Security system on maxima
  105. How Do I Replace Windshield Washer Reservoir & Pump?
  106. Headlight timer
  107. VE 5 speed and AT axle interchange .. help
  108. How to remove windows/windshield/doors...
  109. finally fixed, replaced injectors
  110. car alarm
  111. Pictures Needed, All Colors and Years of Maxima
  112. 94 maxima air vent removal??
  113. o2 sensor connector, red wire broke, ecu side...
  114. wheel spacers...do or don't
  115. Brand new transmission has arrived :)
  116. Trading my MAXIMA FOR A LEXUS
  117. Twin Cam 24 Valve V6 3000 Engine Stickers?
  118. Cool idea....side markers on when reverse is engaged
  119. Replaced timing belt today...it now whines.
  120. mildew smell when a/c is on
  121. hate to ask such a simple q...
  122. IS IT TIME TO SAY GOOD BYE?
  123. Headlight Lense
  124. Auto Dimming rearview mirror?
  125. How do I Replace The Battery Cables
  126. Radius Rod Bushings
  127. Did i order the right gasket? Fixin injectors
  128. No air coming out of the vents
  129. 1990 VG30 Headers
  130. What is this on rear suspension VE 5spd car pic attached
  131. Price Quote
  132. 94 Max in the shop - Stalling in D, R. $1k for repairs and still has the problem!
  133. Strut Problem!
  134. What is it?
  135. Diming Automatic Climate Control Unit (ACC)
  136. to the track this weekend
  137. Anyone think this is legit?
  138. help me my 3rd gen members to....
  139. Fuel Injector Wire Harness
  140. rattling noise (video)
  141. Source for "soft" screws that hold in injectors
  142. Insrument clusters and VTCs
  143. Some questions before I start to upgrade the fuel system
  144. car starts wierd...like low battery, but its not..
  145. Cheap Replacement Window Regulators
  146. Blue GXE gauges?
  147. Walkin' in the JY just earlier to-day, ba-by, What'd ya, what'd ya think I saw?
  148. tranny cooler
  149. Long time no see
  150. Rear Passenger Window
  151. Turn Headlights off with Ignition = Off
  152. Paint Chipping badly.
  153. Dead VGE Horses
  154. Easiest Quickest way to remove power steering pump belt
  155. Tach and Temp gauges not working
  156. Sounds like my max is missing but....
  157. Idle Pulley bent?
  158. KONI'S ANYONE.
  159. My Max on 17's...Finally!
  160. Got T-Boned today
  161. Royal Japan Imports/JDM??
  162. hissing sound
  163. Happy B-Day capedcadaver!!!
  164. Solve the mysterious sound coming from my engine (a pissed off cat?)
  165. http://forums.maxima.org/showthread.php?t=547175
  166. blindin HID
  167. Many Issues. High idling, smoke out tailpipe
  168. 3rd Gen VE Progress Pics and Timeline
  169. Maxima "SXE" apperance package, phase 2
  170. TPS Gone Bad?
  171. should i be concerned about....
  172. brake booster lines
  173. All Engine Temperature Sensors, VGE
  174. 92 VG Blue Dot Injectors
  175. Quick CV Boot Question
  176. ODOMETER NON FUNCTIONAL
  177. New noise after replacing oil pan.
  178. Im a n00b and my Max is missfiring video
  179. Clutch noise...
  180. tie rod jam nut
  181. did 3ed gens have adj suspension??
  182. Remanufactured engine
  183. Look what a shop did to my max
  184. Write-Up: squeaky clutch pedal giving you the blues?
  185. quick alternator question 92-94 se model
  186. It's Always Something...
  187. Tick Tick Noise
  188. Retractable Antenna Repairs
  189. Noises from front-passenger wheel compartment. HELP!
  190. No alignment b/c of ball joint
  191. Maxima Forums > *
  192. 93 injectors
  193. Speed Sensor Repair
  194. 1.25 or 1.5
  195. VE and VG oil pans the same?
  196. VLSD 5-Speed is Installed!
  197. GFs car rough idle loss of power rps stay stead at Idle?
  198. Lug Bolts
  199. injector/knock sensor replacement. still showing 34/51 codes. HELP PLEASE.
  200. capedcadaver's "missing" issue (split from marshall's thread)
  201. What vg30e had this?
  202. Groaning and vibrating while turning
  203. Interior dash lights and switches
  204. Extended Rear Wheel Studs
  205. About getting parts from the local dealer
  206. coolant bypass
  207. Exhaust Studs
  208. Window Tint or not?
  209. The acceleration/shifting problem
  210. Fuel Injector Cross reference?
  211. What is it about the Gen3?
  212. strange noise from speakers as I accelerate
  213. Need some parts...
  214. HVAC Controls At A Junkyard
  215. Injectors, very strange problem
  216. FI questions for the ve30de
  217. Its missing?
  218. rear disc swap done
  219. where is my PVC valve? 92 SE DOHC
  220. Guide Pin Trouble
  221. Caliper rebuild or replacement?
  222. What to do next?
  223. VE5 Swap.. Do you NEED to take out auto "pilot bushing"
  224. engine shimmy
  225. ve vq swap out
  226. Weird engine noise at speed
  227. timing belt...
  228. Odometer overspeeding
  229. Update on VE in 200sx?
  230. Wheel Bearing Replacement
  231. Proper Manual Shifting
  232. VG30E fuel injectors and distributor
  233. Windshield Washer Nozzle Adjustment
  234. Strut bolt spins with nut?
  235. Tail Light Letter Clearing/ Sanding
  236. ABS pump question
  237. Anyone have a clutch cylinder template for 5spd swap?
  238. opinions on rims
  239. Speedometer pinion question
  240. NO PPM Emmission failed 3rd time
  241. how to get to my fan switch for A/C?
  242. Mixing power steering fluids?
  243. Brake lights NOT working
  244. Interior LEDs
  245. Steering Rack Removal
  246. WOOHOOO!!!! A NEW electrical problem!!!
  247. Fail Safe Mode?
  248. Non-working Cruise control & constant honking horn
  249. What to do? (opinions please)
  250. No start
