- Glow Gauges
- High HC emission question
- Could this be the japanise motor with Turbo for VE??
- home built/rigged ram air on VG
- lil acident
- problem with A/C UNIT please help.
- bumper scratches
- left axle removal
- Spark plug gap and heat range for VE
- "Hybrid" Intake for the VE?
- Spark Plug Wiring Diagram 4 1990
- Which Spark PLugs?????????
- Pictures of some mods I did...
- messed up bumper.. need a body kit
- BMW Headlight Conversion
- maxima in video games?
- Its getting colder out, how is your car taking it?
- motor for power window
- Hell Yeah!!
- -Maximized Sentra-
- Oh my fawking god!
- leather repair...please help
- Cold start and Idle
- camaro side skirts
- stalling
- can you believe this is a max
- Cold Starting Problem
- Muffler Questions
- problem need help!!
- mis-firing
- 3rd gen VS 4th Gen
- 300zx Steering Wheel....duz it fit a 3rd gen max..? if so...got pics?
- Have to Decide on y-pipe
- Tranny flush-does it work?
- lexus GS300 wheels fit?
- SE-r pads on a 3rd gen.
- ignition relay == starter relay?
- 240sx wheels
- Wierd behavior, loss of power... help, please
- Vibrations when exelerating
- rust
- 1989 Maxima Heating Problems
- "Broken Crankshaft"
- Check Engine Light from Warpspeed Y-Pipe?
- Fuel pump dying? help. . . .
- engine temp gets cooler the faster i go
- Door inserts
- Idle Issue on 3rd Gen Max... Common, no SOLUTION??!?!?
- High Preasure hose involved question.
- 1 fog light not working, please help
- Power Steering Issue....grinding sound
- HELP: my clutch fluid is leaking
- Oops! Wasn't the water pump......
- Seatbelt Help!
- Replaced right haft shaft, car won't move
- VE30DE: NVCS ON vs OFF
- 5spd 2 Auto/ Auto 2 5spd conversion Update
- My shortened back bumper
- detailing an older car
- Factory Bose without amps
- A little smelly!
- Ebay Amplifiers
- anyone up to do me a favor? i need a pic of the fuse diogram
- o2 sensor plug, where it be?
- Brakes
- my cardomain!
- I have a few questions!!!!!!
- My Maxima Is Taking It's Shape Again!
- Manual-to-power seat swap (a little long)
- anyone who has installed new brake pads on 3rd gen. HELP
- Cai For Vg?
- Need Help Asap!! Please!!
- question about my car
- got a pimp interior?
- timming belt tension
- How did you fix your stalling problem?
- Heater
- 95 altima injectors = VE injectors?!??
- Cupholders!
- Popping sound
- If you have a funky smell in your ride this could be it
- I fixed my clock!
- Warpspeed Y-Pipe is on!!!
- Warpspeed Template help
- Original Wiring
- Gauge Problem
- Urgent Help with 3rd Gen Suspension Needed!
- air bag light
- Can I call technician out for servicing?
- update on my car and a question
- Dyno
- Installing 4 X 6 front door speakers for a 91 maxima
- what could it be?
- had my max towed again...
- Trunk Not Locking
- Intermittent Wipers
- Wipers
- ATC face problems.
- lights n sensors
- Idle Issues
- Chilton's Online Service Manual !
- Possibly gettin this 3rd Gen...
- Where would you put an aftermarket water temp sensor on a VG30E
- Cup Holder Help?
- a turbo 3rd gen on cardomain
- Fuel Injector Fault Code
- Really Weird Engine Problem!! Any Suggestions Appreciated
- Tell me what you think?
- How Much For Condensing Unit?
- pulled er out
- How do you check fuel injectors?
- ECU Disconnected?
- thermastat
- Idle/Rough Running When Cold
- I think my water pump just went?.....
- Just got my CF Hood and had some questions?
- Not a Ricer Exaust
- 89 Maxima Radiator swap to with older model rad?
- tire size question
- update on nismo1989 and court
- muffler with the stillen kit
- speedometer acting funny
- Help !!.....bmw Headlight Install.....help !!
- Breather fuel line ... ehgine wouldn't start in moist conditions ...
- Guages
- 300zx Brake Upgrade Questions
- last goodbyes to the best thread on earth!!
- putt-putt noise in exhaust.
- Automatic seatbelt - convert to manual?
- Foglight Question
- VG idle RPM?
- VG Idle RPM?
- rough idling, rough running 91 SE.
- Keypad numbers!
- Cd Player Pockey Drawer
- maxima projector headlights ???
- Help - Antilock brake problem
- Gas Tank Leak! -look in this thead-
- Looking at yet ANOTHER
- Stock RSB.... anyone ever notice this?
- Temp Gauge Hot... then Not!?!?!?
- headlight and daytime driving light going weird,help.
- Climate Control Units
- Tranny "hunting" for the right gear?
- Decisions Decisions
- Few Questions..Experts Help!
- Looking for Maxima experience
- New Pics of My Max
- Transmission Question
- Suspension Braces
- My key can't open the doors - worn key or worn locks?
- Slippery tranny: a few questions?
- Louder sound..........
- alarm suggestions?
- wierd tranny??
- Vibration when any gear engaged
- Sunroof question
- Updated my cardomain page 30 new pics
- 18' rims...will these tires fit?
- rough idle and when running also, 91 SE
- Parts Requests?
- speaker problem
- Could it be an exhaust leak?
- what spings to get for a 90 gxe with 18s
- Parts questions- need ideas...
- Stupid vtc grounding question
- My beautiful Max!
- Tranny problems.....?
- 90 maxima tell me what you think...this works
- my 90 tell me what you think
- Max on long trip
- xenons not HID
- put in vtc's not it dosent start ?????
- Awesome forum - already learned a bunch
- 92 SE alternator
- Midas Cost Me 275.00 And Didnt Fix S**t!!!!(Kinda long)
- Balance Performance for Daily-Drivabilty
- VTC Dyno?
- Made my own ground kit
- tapping sound under dash..
- Rear Suspension Technique Sway Bar
- timing advance, where?
- axle nut
- Illfated 3rd Generations lately......
- Need exhaust which one?
- seriously angry at my Max
- The trick to taking out a water pump on the VE.
- shifter moves back when accelerating in 1st gear (5-speed)
- new design
- new problem need help asap!!
- radio bracket screws stripped, please help
- Headers
- Question about CV Joint and e36 headlights
- Will these wheels fit my car?
- Noise coming from driver side
- Floor mats...
- Pacesetter Headers-Y-Pipe O2 Sensor Bung size?
- A lil pumpkin treat for everyone......
- PowerLocks why! (help)
- Bought a 3rd gen... again
- 1989 Maxima front/side indicators no blinky
- for sale or parting out 90 se bad transmission
- What if Nissan.........
- Sensors, Corrosion and easy fix
- 93 GXE -- Lumpy idle, fautly fuel gauge.
- 1989 Maxima
- Can the wrong kind of spark plug cause a stalling problem?
- KYB or BOGE Front Struts ??
- 2000 GLE rims.......can they fit a 3rd gen SE?
- need your thoughts again
- Crazy Tach?
- UK Spec grille??
- Burning up ECU's
- help my abs ligth keeps coming back
- Mine Totalled.. Lookin at another
- Anyone with Enkei RS-6's on?
- Transmission or Problems????
- new headunit + speakers
- How the heck do you...
- radiator fan
- i saw this 3rd gen with this bodykit
- Injector/Coil prices?
- Rear Door Swap - 2 Questions
- '89 VG which Filter type/brand? I searched the stickies and FAQ
- Quick Question...will add more later...
- i need your thoughts about wheels...
- Yet another E36 install
- Thrid gen paradise
- another Bose Issue
- Loud "whirring" that matches RPMs
- 17x7... What size tire with Sprint 1.8?
- 91 SE headlight problems
- anyone like the stock gauges?
- will the interior of a 02 max fix on a 93 max
- just got a Gtech
- turbo ve????????
- Can't get alarm to disarm (I've searched)
- hypothetical engine/tranny swap se to GXE
- Cheezer, installing new suspention
- For those with 18's..
- 2000 Maxima/Infiniti I30t 17x7s on a 3rd generation?
- No Heat on 1989 Maxima
- help on installing a turbo in a 94 max (VG30E)
- Gettin ready for turbo PICS included
- good asking price
- Tranny shifts HARD
- Swapping Parts, compatible? (2 Qs)
- 90 maxima transmission swap
- installing fog lights
- Stupid BOSE
