View Full Version : 3rd Generation Maxima (1989-1994)
  1. Wish I had a real heater
  2. Nitrous...wet Setup...anyone????
  3. 145mph se gauges on a gxe?
  4. Question about some stuff I saw on CustomMaxima that I might want to ask for X-Mas
  5. Need opinion before I spend money
  6. weird electrical problem
  7. Power steering problem
  8. Dim climate control display
  9. headlight swap??
  10. opinions on headlight bulbs
  11. replacing bose head unit...
  12. wtf is with souping up old cars?
  13. Question about brakes after Nissan serviced them...
  14. Adjusting the timing
  15. fluttering tachometer
  16. Auto tranny gone
  17. Almost done with my tune-up
  18. Alarm keeps on going off for no reason..
  19. Updated CarDomain...pics of Eibach/Tokico
  20. Ecu ?
  21. so you want 3rd gen attention huh?
  22. Voting for Maxima.org's calendar is taking place now!
  23. 93 door key code?
  24. ABS craps out when its too slippery for it?
  25. Caught on fire!
  26. rag top max?????
  27. Has anyone had work done by Cottman Transmission????
  28. if you have 2 12 inch subs in a 3rd gen post here.
  29. Since when....?
  30. fuel pump relay location
  31. Magnaflow Cat-back
  32. Next Meet?
  33. I feel a knock in brake pedal.....
  34. Most likely a tranny issue...
  35. Is this hose supposed to be here?
  36. CVs
  37. Cheap cone air filter...or stock box?
  38. I seem to be loosing motor oil out of my crank...
  39. front end
  40. Pics! 3rd gen meet, NY
  41. For all of those whe have replaced BOSE
  42. cat is pooping out...
  43. Alarm Troubles
  44. cold start/death?
  45. How do you replace headlight bulbs?
  46. RPM goes high but does not speed up
  47. Where to buy fuel injectors?
  48. gauge failure-URGENT
  49. ECU Reprogramming. Need Some Insight
  50. Engine Shaking like Crazy!
  51. air bags vs. air shocks
  52. if you... you might be a ricer
  53. Rear reflector - where to find?
  54. sunroof
  55. please help w/ new knock sensor harness
  56. when changing color of car..do you have to...
  57. Rev Limiter.... hmmm?
  58. My max is cranky
  59. How To Install BMW Lights Needs Help
  60. tell me what you think about my 18s
  61. In case it hasn't been said here yet...
  62. Battery Cables
  63. Average Things Going Wrong At 215,---k
  64. Cold heater
  65. Flex-pipe replacement question
  66. Hood struts
  67. 5th Gen Anniversary wheels on a 3rd Gen
  68. aaaarrrrrgggggghhhhh
  69. Fuel Pressure Regulator
  70. 300zx parts 2 Maxima
  71. FSTB off ebay
  72. It lives!!!
  73. what 2 replace?
  74. Center Caps
  75. Need Help ASAP!
  76. Testing the 02 sensor
  77. Another one Bites the Dust
  78. PS/H2O belt broke...need replacement belt advice
  79. help w/power-comfort indicator light
  80. R.i.p.
  81. Front Strut Bar
  82. Light Bulb Sizes
  83. Different Colored Lamps.
  84. Different horn sound
  85. Window down button??
  86. Group of 10 for custom body kits...
  87. intermittent hard starting.... for you tech guys
  88. Anybody know the stock injector flow rate of the VE or VQ30DE?
  89. Wipers don't work!
  90. where are the horn located???
  91. Just installed JVC HU and 6.5" Infinity Kappas
  92. fuel smell
  93. Did a little off roading yesterday morning..somewhat lengthy
  94. internetautomar, ? for you.
  95. Exhaust system cost
  96. Oops, ran out of gas! (video).
  97. power steering leak
  98. yet another headlights dimming thread
  99. Test driving my new maxima
  100. My webpage is finally up!!
  101. Since search is down... more questions
  102. Muffler Inlet size
  103. Tokico/Sprint suspension install
  104. Real quick question...
  105. Need some Help!
  106. Is this brake dust?
  107. electronic rear suspension
  108. electronic rear suspension
  109. question for 3rd Gen owners
  110. Battery Problems
  111. Changed oil this past weekend...
  112. Window regulator motor.
  113. WSP setup is on!!
  114. Tokico Strut Insert Help
  115. Console in your Maxima?
  116. looking for parts alot of MAX"S @ bone yard in Jax
  117. which gives a better performance boost?
  118. Knock Sensor Replace, heat soak persists
  119. Anybody have JET ECU experience?
  120. Very Frustrating 2 weeks!
  121. Auto Transmission Stuck in 3rd Gear
  122. car backfiring
  123. 17" 2000 SE Rims on 3rd Gen
  124. which one do you think will look better on a 3G
  125. video game max
  126. power door locks/factory alarm
  127. Motor Mounts.
  128. '89 5 Spd Questions
  129. Place to view Car Colors?
  130. First time on the track!
  131. TPS:how to test?
  132. Need feedback on spark plugs
  133. Info on bypassing knock sensor?
  134. Engine Problems-92 SE(120k)
  135. rear suspension
  136. rust question
  137. Armrest trunk hole
  138. my car fail inspection today ; (
  139. fuel pump
  140. Any tranny people here?(tried search)
  141. Is my Auto tranny giving up the ghost?
  142. search problems
  143. Temp button
  144. 3rd gen queens meet
  145. How to put the pressure back into brake system?
  146. !@#$!@ steering ball joint thingy!!!!
  147. Bleach brake fluids?
  148. Need info for 94 maxima GXE
  149. No fire, cylinder 1 - VE
  150. Tokico/Eibach set-up
  151. Do I have a power antenna?
  152. Handling
  153. Auto to Manual Tranny Swap
  154. Dang on Door locks acting up.....
  155. http://www.geocities.com/azmalu/interior.htm
  156. finally fixin my max
  157. Pics: New Rims, finally
  158. Finally finished the Big Brake Kit!
  159. how do these look ?
  160. Brake fluids for 3rd gen ?
  161. DRRRive Pics... Finally!!
  162. car won't start
  163. Advancing my timing
  164. Do I need a new tranny?
  165. Temp control unit
  166. what size are the speakers??
  167. Need Differential!!!
  168. Quick VTC ?
  169. Strange engine behaviors, some ???s LONG
  170. 3rd Tail Light
  171. Something cool might be in the works for 3rd gens...
  172. Power antenna question.
  173. those who have done 2 tone seats or recognize...
  174. 4th gen kit and bumpers
  175. Front Lower Control Arm Bushings
  176. front strut bar
  177. New Alternator
  178. what to do, what to get
  179. its like im driving a 4 banger!! untill about 4k rpm
  180. Quick Question About Paint. I dont understand.
  181. putting front speakers in
  182. Flapping noise??
  183. well guys my point of decision is here
  184. Cattman VG30E headers anyone?
  185. Radius Arm bolt doesnt want to come out
  186. Maxima Compilation
  187. how to get correct spark plug wiring?
  188. Power and rust problem on 89SE
  189. For those of you curious about CAI filter location...
  190. Hey guys could you keep an Eye out for me?
  191. M.A.F. testing on VG?
  192. Quick Question
  193. weak front strut towers
  194. Power Steering Hose and Whinning Noise
  195. Fuel Filter
  196. Haynes, Chilton, or FSM, help needed...
  197. Lookin for a 24v head
  198. Advice needed....91 running like poop (kinda long)
  199. Maxima.org 2004 Calendar...Would you like your car to be featured in the calendar?
  200. maxima 94 se ve
  201. Front Axels
  202. need some technical info...
  203. e36 headlight question and cam question
  204. 2 Questions: 1 stupid, 1 decent
  205. Excess wax.....
  206. Horrible run at the track. Not the results i really wanted
  207. 1994 maxima se 5spds repairs
  208. 91 Maxima engine problems
  209. Noob ? on gas mileage
  210. goodbye to you guys 3rd gen is gone.
  211. 1994 maxima se 5spds
  212. MAF bad?
  213. need to pull motor to take heads off ???
  214. Finally rollin on 17's...
  215. WINGS WEST 3rd GEN. BODYKIT
  216. Still in need of help... (VG) Knock sensor
  217. Oil leak - could it be power steering fluid?
  218. diagnosed one problem with torque converter...but some other questions
  219. Power Locks not working
  220. Mesh grille on a 3rd gen anyone done it?
  221. please help i might have a bent chassis
  222. 1991 Maxima Help
  223. Just purchased 93 Maxima SE 5Spd w/91k miles, couple of ??s
  224. How much to install tranny?
  225. (VG) Knock sensor question
  226. Both keypad went dead,no sound or light
  227. New Rims, center cap pops off.
  228. All Fueled Up!
  229. installed cattman y-pipe
  230. BMW Conversion page MOVED
  231. BMW Conversion page MOVED
  232. Why so much?!?!
  233. VG Engine missing, and hesitating Proposed Solutions.
  234. Learned my lesson
  235. Stearing Problem
  236. just replaced my alternator but now my batt light is on?
  237. tranny conversion
  238. FSTB installed, but got a quick question
  239. Freakin Dealership
  240. occasional starting problem
  241. New Spark Plugs & Problem
  242. Calibration for gauges?
  243. header time
  244. moving cd player and heater controls
  245. temperature gauge troubles
  246. Transmission fluid
  247. turbo vg question
  248. Where are the Vaccum HOses?
  249. Battery
  250. Question
