View Full Version : 3rd Generation Maxima (1989-1994)
  1. sequential shifters
  2. Firewall Grommet Question - Where to run wiring through?
  3. Cold Weather Effect!??!
  4. HELP!!!! My Brakes are gone!
  5. Charging System Issues
  6. Got in an accident - the car won't start!!??
  7. Replacing Camshaft seals
  8. People with lightweight flywheels
  9. OMG Maximasechs! (PICS!)
  10. do our cars come with block heaters?
  11. I want better lights
  12. Crusing Speed II with PICS
  13. Ratteling from the rear pass. side!?!?
  14. amplifier board for 92 max
  15. Sylvania Silverstars
  16. HELP ME! I think I just broke my muffler!
  17. Blower stuck on high...
  18. Driver's Door Hinge Problem
  19. Transmission Question
  20. why reset the ecu? (exhaust)
  21. Window Help~!?
  22. VE auto tranny slipping in first gear
  23. doesnt wanna go over 3000 rpm ?
  24. Will it rub??????????????
  25. okay here goes
  26. won't go in reverse?
  27. Rear turn signals
  28. lowering the seats
  29. brake light!
  30. Buddy Club Suspension?
  31. new exaust
  32. Will the back seat from an 89 fit in a 92?
  33. VE Max is a hot commodity!
  34. tranny f*ing up only in second
  35. vg tranny swap
  36. Taking apart the fog lights....
  37. Some simple pics of the 13" Cobra bracket and caliper
  38. Tranny Problem
  39. Motor mounts
  40. Check engine light
  41. is it just me? or am i the only one with HUD??
  42. shes dead!
  43. Look at this MAX!!
  44. Is this intake for the ve?
  45. Door lock problems--also Help!!!
  46. need motor help
  47. KeyLess Entry Problem , please help stuck outside car
  48. Auto trans fluid
  49. Sunroof clip?
  50. Mechanic Needed in San Antonio
  51. 92 rear speaker installation
  52. New seat cushions for front seats?
  53. More about my starter, yeah I know calm down
  54. where can i get an UDP for VG?
  55. Throwout Bearing Differences?
  56. the right offset
  57. Seat Neons Project...Yes?YEEEEESSSSS!!
  58. Seat Neons Project...Yes?YEEEEESSSSS!!
  59. anyone have bose 6x9 brackets they wanna get rid of?
  60. what 300zx brake master cylinder to use??
  61. a31 cefiro headlights
  62. Dual Exhaust
  63. Anybody With Valve Body Mods ??
  64. Info On Changing Brakes:pads And Rotors
  65. Power Steering Pump Leak
  66. Transmission Transplant...
  67. Thermostat question
  68. Max runs rich - O2 sensor?
  69. 89 and 90 rear speaker installation
  70. IACV and EGR Questions (Turbo guys read)
  71. Need help deciding on new front brake setup...
  72. whats the model of yellow optima battery for our car?
  73. HELP!!! I need detailed instructions and pics on how to put in a CAI in a vg .......?
  74. newbie here
  75. dual exhaust..to do or not?
  76. How to replace drivers mirror?
  77. couple new pics
  78. Sprint springs for $140....Worth it?????
  79. how do you tell if you have blown your engine?
  80. Operation Parts Car (pics)
  81. Where could I hook up neons?
  82. stock suspension/ safety question, pelase help!!
  83. Say... I found some leather...
  84. air/fuel meter
  85. 1991 Nissan Maxima Starting Problem
  86. What is the normal Cruising RPMs?
  87. a couple concerns????????
  88. Help locating headlight sensor
  89. Whos CAR???
  90. How to get sunroof to open
  91. E36 Headlights
  92. Tight vs. not-so-tight steering
  93. Replacing struts on a 94
  94. Evaluating High Mileage '92
  95. Need some pics/guineapig car..
  96. New here, ECU, window regulators...
  97. What do you think
  98. Good Looking Wing?
  99. I have an idea on intermittent stalling.....
  100. i redid my cardomain site..chx it out
  101. Different Paints
  102. This sucks! starter went out and cant put a new one in for a few weeks
  103. Exhaust Manifold Specs??
  104. Car won't start!!!!!
  105. Rocker wear?
  106. Harder shifts from a rebuilt / remanu tranny?
  107. The Variable Intake is designed for torque! (PICS)
  108. In case nobody else says it....
  109. Removed Upper Intake Manifold *pics*
  110. Stage II Lower Tie Bar: The most effective suspension mod I have ever put on my car
  111. Throttle Body Coolant Bypass ??
  112. Sulfur smell from exhaust system but it's all brand new ??
  113. Ambient temperature reads -30°
  114. injectors
  115. What should be replaced at the 120K service on a VG?
  116. Is your Maxima loaded, or a striper?
  117. Brake Dilly
  118. Looking at getting a Maxima ABS light on
  119. My Speedo Dont Work!!!!
  120. I think its time for me to move on...advice?
  121. Anyone have pics of Magnaflow muffler on their car?
  122. NOOOO!!! My (2nd) transmission died! :(
  123. Front Motor Mount Question
  124. Yet Another fog light issue.
  125. Voltmeter? I have a good idea...
  126. installed Matt's RSTB on my car and Izzy's (pics +review )
  127. picture of a VE Throttle Body?
  128. cruise control issues
  129. High CO & HC emissions
  130. Any nice burgandy Maximas out there
  131. Stuttering under load
  132. Removing interior roof (1 Question)
  133. A/F Gauge where and hot to hook up?!
  134. 2 maf's + s-afc 2
  135. Do The Optima Batteries Fit Into The Factoy Location???????
  136. inevitable threads: fantasy five
  137. Side Markers.... TO MUCH RICE????
  138. 2k1 muffler fitment issue
  139. No Maximas in Jamaica!!
  140. 1992 Maxima Fuel Economy
  141. rear breaks
  142. Tranny Rebuild
  143. Had timing advanced and now car idle's rough
  144. Driver side door wont unlock
  145. 89 Max-Right High Beam Problem
  146. Help! Can't Put In Reverse!
  147. Help On Starters
  148. got a gtech and messed with it tonight
  149. cars running like crap again :(
  150. How to relocate a/c controls and fit monitor with PS2
  151. Where to purchase smoke corners?
  152. Which Suspension??????
  153. BMW Headlights and Heater Question
  154. Gauge Bezel
  155. water pump
  156. what else besides poor grounding could fry the alternator?
  157. is re4f04v an LSD tranny?
  158. rear sway bar
  159. Has anyone seen this car?
  160. Flushing the Radiator
  161. For Those with Automatics!!!
  162. just side skirts
  163. Fuel injector removal from fuel rail.
  164. Check Engine
  165. Loss power and extremely low engine temp on highways
  166. Creating a Custom Angel Eye
  167. Aftermarket seats
  168. they broke my rim!
  169. Oil in Intake manifold and Plenum
  170. Sunroof Visor Brackets
  171. widest wheel/tire combo i can run?
  172. ProCarParts glow gauges - review...
  173. How much to replace front rotors.
  174. Shining up that Intake Manifold!
  175. Car wont start
  176. Lowering Springs
  177. Cold Air Intake
  178. dumb thieves..
  179. Where do i wire my gauges?
  180. Any aftermarket distributor caps?
  181. 3rd gen cleared tail lights/centerpeice
  182. any nice looking gold 3rd gens
  183. Wiring Gauge Faces, help appreciated
  184. which muffler?
  185. sputtering engine
  186. Looking for a aftermarket maxima website! Help Please
  187. How to get trouble codes on a 92 Maxima
  188. HELP, automatic shifter problem
  189. nissan cefiro for sale on 240 board.
  190. speedo question
  191. I'm looking for a guesstamation....
  192. AUTOZONE Powder Coated Calipers
  193. couple of b pipe questions
  194. no power
  195. Dash lights and tail lights out, any ideas?
  196. Dash lights and tail lights out, any ideas?
  197. BlehmCo. RSTB Install/Review
  198. Got bored in Photoshop...
  199. Steering noise and intermitant loss of power
  200. any ideas?
  201. $200 right here!
  202. Im Back!!
  203. TV install
  204. Where, oh where, is my alarm?
  205. Alternator
  206. ummmm where's my ...
  207. headlight problem
  208. It just couldn't last to the end of the year...
  209. Windshield Tint Bar
  210. motor fitment questions
  211. '94 Diecast Maxima
  212. turbo ?
  213. Transmission Problems
  214. Digital Dash??
  215. Front End Work: To do or not
  216. Creaking from front right
  217. transmission q's
  218. Alignment question...
  219. resistor mod question.......
  220. transmission issues
  221. Hid System Question
  222. amplifier to run front,rears,and sub?
  223. Odometer
  224. Carbon Fiber trunk lids
  225. Coolant Leak....Only when it's cold??? (long)
  226. BlehmCo. Stage II lower tie bar installed and partially reviewed
  227. need help "89 GXE won't start
  228. Stillen Short Throw Shifter installed and reviewed
  229. Shift Lock!!1
  230. Removing speaker grille(Rear)
  231. Help!!!!!
  232. custom LED front bumper lights
  233. 300zx swap
  234. Converting Questions
  235. Speedo Problem
  236. Accident today :/ (Pics)
  237. advice plz
  238. Odometer sticking!!!
  239. Frenched Antenna Pictures
  240. GXE vs. SE ABS Sensor, Any Difference?
  241. Audio System Advice For GXE
  242. help
  243. Looking for information on fixing intermittent odometer
  244. Just picked up my 89 max, its sweeeet!
  245. 300 Zx
  246. need some help
  247. HMMMM noise coming from the rear
  248. decided on new auxillary battery..
  249. Window regulator problem??
  250. lights behind gauge cluster
