View Full Version : 3rd Generation Maxima (1989-1994)
  1. 4th GEN LEather Seats....can they fit in a 3rd gen?
  2. 300zx rims
  3. TRANNY acting weird when braking hard??
  4. Car hickups sometimes when cold!! What??
  5. new tstat but...
  6. Does neone have write ups on the US SPEC BMW Headlights that have the H1or H7 bulbs
  7. Crashed my Maxima.....almost.
  8. Wheel Bearing Question
  9. rstb or sway bar
  10. Low oil pressure light - clean oil pan/replace oil pump?
  11. hey guys
  12. misfire in a vg
  13. has anyone else seen this recall?
  14. Motor Flush
  15. Heater control valve..
  16. dde conversion on e36 conversion
  17. Need to Replace Non-Bose CD Player
  18. strange automatic tranny
  19. Full coverage or liablity?
  20. need some help with installing an alarm
  21. Funky noise coming from heater,fan
  22. Y-pipe?
  23. I'm sofa king we todd did
  24. MaXtuned's dyno explaination?????
  25. Help need with PS pump and pulley issue....ASAP thanks
  26. Ve Dyno Sheet Request
  27. road trip.. need advice.
  28. Idle jumps when stopped....
  29. 92 GXE needs injector Should I get it?
  30. GXE's with spoilers
  31. car running like crap
  32. Headlight Conversion Possible?
  33. What do you guys recommend for brakes?
  34. Replacing Aftermarket Headlights
  35. Electronic Superchargers
  36. aftermarket parts
  37. Noisy when cold
  38. Bought 94 GXE,136K Miles Need Suggestions
  39. Panel lights
  40. Can you put 19's on our maxs
  41. Got some Pics
  42. what aftermarket fuel pump have you used on your VE
  43. Low fuel light..
  44. What does normal operation of A/F ratio Gauge look like.
  45. spark plug fireing order?
  46. Steel wheels...offset OK?
  47. inspection next month, what can i do?
  48. Tail lights and dash problem
  49. Otto FSTB Installed.... WOW!!!!!
  50. taking apart spoiler light
  51. interior paint?
  52. Apc Aluminum Grand Touring Wing
  53. G-Tech users (VE):
  54. -----New Pics---------
  55. Interior REVAMPED SEE PICS Nubianpupe Its done!!!
  56. front drop only....
  57. proformance on ve 1994
  58. Cranking but won't start
  59. Electrical problem! need help ASAP!
  60. Gas door/lever, help!
  61. Thinking of installing a TV.
  62. The ECU Tuning/Fuel Thread
  63. help! Fuel rail fuel line replacement w/o removing in/manifold?
  64. Vid of Swowlinc's car
  65. power steering pulley fell off.
  66. How do I wire up a horn...
  67. the manual to auto climate control swap has been done
  68. Places To Hook Up Neon Lights
  69. possible blown head
  70. Small wonder host
  71. An unusual light problem.
  72. `headlight problems
  73. Upgrade air cleaner
  74. Good News! I feel like a pioneer now :) 97 - 92 Visor Conversion--->
  75. Electrical problem! need help asap please!
  76. ********This Thread is Worthless Without Pics!******
  77. Angel/Demon Eyes
  78. Info on Turbo kit from millennium autosports
  79. master cylinder leak
  80. new pics
  81. Drivers Side Door Grommet
  82. Digital Dash Smoked
  83. Clock. Climate control and digital dash
  84. Horrible gas milage....
  85. just installed tranny, think i got a problem, help please
  86. Help! Air/fuel ratio gauge hook up.What color is the wire?
  87. help on instalation of power antana
  88. Igition coil question and more and more
  89. Fsm
  90. Wheel fitament problem...
  91. Tire Size!!!
  92. Videos at e town
  93. Buy a nj 02 se graphite looks like hids popped anyone. Anyone know this car?
  94. What did you pay for work or mod installation?
  95. one MORE road trip with my maxima, Iowa to Texas
  96. does aftermarket y-pipe cause hissing at higher RPMs?
  97. piezo question
  98. What now!!!!
  99. Round fogs
  100. Tires Flexing :(
  101. Failed emissions
  102. My 90 VG Idle's @ low rpm when engine is cold
  103. vacuum hose diagram....or pic
  104. I Hate Saturns
  105. since nobody else posted pics of the gauge pod here they are...
  106. Chilton site down! need code procedure..pretty please
  107. Pics of a crappy Maxima: Good for a few laughs if not a few tears..
  108. Oh GNOES!!!
  109. y-pipe fitment
  110. I am going to replace the fuel hose to the rail
  111. codes?
  112. Paint/body shop in S. Cali?
  113. The VE crank is cast right?
  114. problem with hose
  115. Need to locate the Modulator Valve!!!
  116. Check air bag system after 10 years??
  117. My Pics are up, Come on in!
  118. ran with gtech over 300hp@8psi!
  119. suspension upgrades
  120. Thermostat Changed heat still sucks! Help Plz
  121. Interior Lights (OLD)
  122. driverside window problem
  123. audio recordings of my car
  124. Best place to mount tweeter?
  125. bleeding coolant system
  126. muffler on a ve
  127. question to all that have done the E36 conversion
  128. Moans & Groans
  129. Headlight covers
  130. Phillips Vision Plus
  131. "new" grey tweed seat covers
  132. custom ve turbo..**pics**
  133. E36 conversion done in 2 hours
  134. Cat-back Exhaust
  135. turbo
  136. weird problem?!?
  137. aftermarket oil pressure guage
  138. need some info plz (people who did headlight conversion)
  139. clear corners
  140. Crazy instrument lights
  141. aero turbine muffler???
  142. Just got it from the tranny shop,
  143. Just got e36's
  144. Any one who got a JDM VG
  145. fluctauting idle when cold??
  146. VG30E- Are they all the same long block?
  147. in need of a 92 transmission!
  148. Matt's Product of the Week- reinforced RSB Links!!!
  149. Gauge Lighting Problem!!!
  150. ticking under acceleration?? valves? vtc's? HELP?
  151. Misunderstood
  152. Wheel Spacers
  153. new alternator?
  154. Heater Core is gone.........You're kiddin me!!!......
  155. Clock has a mind of its own.
  156. Heating probelm H E L P!
  157. VG30E supercharger
  158. Power window problem...not regulator
  159. any good car shipping company?
  160. 1990 Turbocharged
  161. Factory remote starter, trunk opener stop working
  162. Aftermarket gauge install
  163. Strut and Spring install.
  164. need clutch & tranny advice!!!
  165. Would these work for big brake setup?
  166. for those who don't have a muffler
  167. Need short stack intake
  168. Diagnosis: “Low compression on cylinder 1”
  169. strange water flowing sound
  170. Thinking of selling Max. how much should i ask?
  171. NGK wires dont fight tight enough :(
  172. High flow Cat and Muffler question, HELP
  173. need edvice please!!
  174. Keypad Problem
  175. Gas Leak from Top Front of Engine
  176. Manifold Studs: Question
  177. fuel rail/injector o ring leak- how much $
  178. Yeah
  179. H.I.D. compatability
  180. i found something cool, need advice
  181. Another e36 question...................Yeah I know.........
  182. Springs and Shocks
  183. JWT cams for VG30E
  184. Noise under the hood
  185. power steering hose and radiator
  186. Whats the best bang for my buck?
  187. missing antenna
  188. Stock Muffler
  189. intake problem
  190. This really ****es me off!!!
  191. Pwr Antenna Replacement Problems...
  192. Power steering pump filter?
  193. motor and trannie longevity and where to find rebuilds of both?
  194. Replacing CV Joint - Any Gotchas?
  195. time to replace my tranny?
  196. Man, this really sucks!!!
  197. Very Very Cold -7 F
  198. Addco RSB owners
  199. Rear Speaker brackets.. Need 6.5 have 6x9
  200. Does Nissan Service Center Carry Screws?
  201. Where to get a SS tube for intake
  202. How much to replace the wing on a 91SE?
  203. manual tranny ?
  204. Disabling VTC's
  205. How much should I estimate?
  206. Highest wattage for e36 lights
  207. meeting for the LA autoshow 1/10 sat....
  208. I'm gonna go nuts
  209. some help here pleeze
  210. updated cardomain w/ pics
  211. Who has an Alpine head unit on their 93 max? problem with fitting.
  212. engine/exhaust mods
  213. I hate it when this happens
  214. Looking for a tranny
  215. Odometer not resetting
  216. *****Gauge Pod Pillar Update*****
  217. Ve + Cai + 18º = :)
  218. Used front bumper cover?
  219. how is your max in the snow ??
  220. How is the view at night with e36's?
  221. What grill is this?
  222. 92 SE injectors
  223. Rattling from engine when key turned to ON only
  224. fault injector (again). need to replace gaskets?
  225. How to remove digi climate control
  226. I saw 20"'s on a 91 MAXIMA
  227. Will this fit our car?
  228. BMW E36 conversion headlights
  229. matt's rstb reviewed once again
  230. exhaust system setup?
  231. Tach quit working
  232. fuel rail
  233. Another Grommet Question
  234. Throttle body cleaning (extended)
  235. Fuel smell inside car
  236. leather seats
  237. big problem
  238. Model car for you 3rd GENers...
  239. power/comfort switch question
  240. Starter motor & extreme cold..
  241. Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  242. Appropriate tire pressure
  243. Help with car problem
  244. Ok its the 7th
  245. 1992 Maxima hesitation and lurching problems
  246. need pic of underside of car
  247. Defroster question.....
  248. JDM vs. JDM
  249. Thermostat Replacement
  250. Clutch problems
