View Full Version : 3rd Generation Maxima (1989-1994)
  1. Tire Question
  2. ve30de boring
  3. About to drive long distance...OH to AZ. What should I do?
  4. Leak!!
  5. PepBoys Tools
  6. car not starting
  7. Just installed Blehmco's Parallel link kit.
  8. sport shift in an automatic
  9. 90 Max won't start
  10. '89 Maxima GXE tranny bad
  11. New Arizona Maxima webpage
  12. hydraulic control unit
  13. Speedometer not functioning properly
  14. Less gas mileage with Y-pipe?
  15. Buying a Different Max...
  16. Quick help!
  17. j30 vs 3rd gen suspension
  18. Check This Out Folks
  19. Built a Consult-Laptop interface! (Pics and info)
  20. Swap Engine...
  21. Any Maxima friendly shops in NJ
  22. coil spring cutting.
  23. i need some help...starting problems
  24. Going from Auto tranny to Manual on 93GXE,,,,Can it be done??
  25. Rear Sway Bar and Cat
  26. Ignition switch problem
  27. Where Can I Run A Wire Through The Firewall ?
  28. question
  29. auto-up drivers window how-to
  30. I have a question about gas?
  31. Bought a new k&n cone air filter...but a install question
  32. glazed pads?
  33. Suspension???
  34. fuel lines?
  35. 93 with delayed shifting problem
  36. Spark Plug Gap
  37. Block Heater?
  38. Intake question about a 1993 maxima
  39. group boobies
  40. simple offset question
  41. fenders
  42. group buys
  43. Misfire in my VG
  44. Help with 91 max
  45. Part number on side marker bulb???
  46. keyless entry not working thanks for help
  47. Steering Resistance
  48. back brakes,transmission,and painted doors
  49. Leave it to me!
  50. Pioneer DEH-P8400MP $500 or best offer shipped.
  51. engine ticks even when warm
  52. Rear defroster
  53. The Age Old Power Door Lock Nightmare
  54. One Bright HeadLight not working
  55. Power loss below 3500, not throwing knock code
  56. Ve30de
  57. Batt. Light Comes on at stop
  58. A cheap way to fix the dimming clock
  59. my 93 maxima rpm going up and down suddenly
  60. vg to ve
  61. drive belt change
  62. Mr. Goner
  63. Is this normal???
  64. Clunking
  65. transmission (auto)
  66. The VE is back in action as of 5pm est !!
  67. If I were to paint my wheels.......
  68. will these wheels fit?
  69. HELP - Pass Side CV axle
  70. 1989 se to 1994 GXE
  71. Car Broke Down!!!!fuel Pump????
  72. free horsepower?
  73. Speed determined shaking
  74. painted wheels
  75. Updated With New Pics Cardomain.com Page Plz!!!! Cheq Out
  76. 93 Maxima GXE Rough Idle
  77. uneven drop... sprint springs and KYB
  78. VE30DE and VG30DE
  79. How dedicated are you?
  80. Battery dead, car now whacked out!
  81. OMG This is just plain SICK!!!!!
  82. Small 'mod' I did :)
  83. Radiator fans stopped working???
  84. grounding VTC
  85. Post pics of 3rd gens with 19s
  86. power loss in 91 maxima
  87. Eibach & KYB Install complete!!!
  88. new alternator, upgrade?
  89. LEDs in tail lights of 3rd gen
  90. synthetic oil and knocking during startup
  91. Weird Tranny problem
  92. '92 Won't Read Codes (CEL on) - WTF...
  93. removing abs
  94. failed attempt at vtc rewire
  95. Will this Visor with TV fit in my Maxima?
  96. CBK Kevlar brake pads will these fit.......
  97. Air Ride Suspension
  98. How to Change the Rear Sidemarker?
  99. Removing shift knob
  100. Window not going down all the way
  101. Oil pressure sensor thread size
  102. Transmission problem?
  103. Grounded out with a Lowered Maxima
  104. Voltmeter Gauge Installation
  105. Ignition Wires - Question
  106. Cruise control ?
  107. Headlights Not Bright
  108. Front Corner lights cracked
  109. Rear Power Windows Busted
  110. wheel stud broke!!!
  111. Driving impressions after replacing the Knock sensor and a few other things
  112. the org. is awesome
  113. Could someone please tell me the fpr pressure settings
  114. Changed valve cover gasket today...pics
  115. Any Eastren Ohio Max
  116. Rear speakers quit?
  117. Rich
  118. Vg30dett?
  119. A/T fluid used as P/S fluid?
  120. E-Brake Tightening
  121. ecu for the 89-91
  122. Where to mount my amp?
  123. Motor Mounts
  124. Oily residue in intake manifold normal?
  125. Oily residue in intake manifold normal?
  126. NEW 90'SE(car/driver)
  127. New engine or 4th gen max
  128. Blew my timing belt... ARRGH!!
  129. wierd idle...
  130. new steering wheel too...
  131. tune up
  132. EGR Valve
  133. High Idle at cold start then stabilizes
  134. What Kind of Mileage Does Everyone Have?
  135. VTC Ticking????
  136. Spring Break
  137. is the ECCS control until a ecu
  138. ticking
  139. lookin for good street/strip cams
  140. 5th Cylinder.. Not working??
  141. Brake rotors
  142. What r ur opinions????
  143. digital touch entry problems
  144. 1 hour to go!!Y-pipe,stageII clutch, fidanza, 18" rims
  145. Mark who bought my maxima in TN
  146. Removing the rear deck?
  147. Tranny Question?
  148. Auto trans problem?
  149. Trouble?
  150. wheel offset
  151. Newbie question
  152. Missing When Wet/Cold
  153. Water pump
  154. Anyone in STL that can help me replace my window regulator
  155. 3rd gen supercharger: Will it ever happen?
  156. stock fuel injectors flow rating??
  157. 3rd gen MAFS vs. 4th gen MAFS
  158. Dont want a rice sound, what muffler should i get....
  159. maxima guague pod
  160. finding spark plugs and wire
  161. Mileage
  162. do i need a new tranny?
  163. Sprint Springs & ST Shocks???????
  164. will an fstb that fit on a VE work on a VG
  165. Top Speeds
  166. Has anyone tried a 35 offset on a 18" rim?
  167. new sway bars
  168. brake cost
  169. 300zx ecu
  170. 92 Maxima cold weather stalling
  171. Spacers needed for back rims....
  172. tail lights swap
  173. guess who's b-day is today????
  174. fine at dark and weird at day
  175. Quick aftermarket alarm question
  176. BlehmCo ground wire kit
  177. Air Intake
  178. I did a simple little aftermarket alarm LED mod today and did a writeup
  179. Help. Idle fluctuates,car misfires,but runs good??
  180. Any Cefiro experts ?
  181. VG30 engine problem
  182. New Steering Wheel (pic)
  183. Vids and Pics of my High Stall Torque Converter!!!
  184. Remote start/Alarm with trunk release question??????????
  185. Eibach & KYB writeup
  186. Gas Door/Lever
  187. performance auto trans
  188. Monroe Sensa-Track struts..
  189. short shifter question
  190. BlehmCo RSTB installed! (pics)
  191. car runnin like a piece of f-in sht
  192. Removing Door Moldings
  193. Updated Cardomain....
  194. Adjusting Headlights
  195. sway bar and bushings
  196. 92 Max Downshift Problem
  197. Door Lock Actuator?
  198. Power Steering ...
  199. e36 headlights
  200. Car engine
  201. sunroofs, shades, and steering racks
  202. Should I replace all the injectors or just the bad one.
  203. If I were to make...
  204. The starter replacement instruction?
  205. Firewall?
  206. regular E36 vs. projector E36
  207. Rubber roses that go in and out of the firewall
  208. VIN check anyone??
  209. Lighted trunk Plate
  210. 91 Bose Swapout, Which years?
  211. 91 Bose Swapout, Which years?
  212. Rear Windows won't go up or down
  213. removal of upper intake manifold require coolant drain for 89?
  214. Custom grill with a headlights conv. - your opinion?
  215. How can i tell if my max is misfire?
  216. transmission
  217. Dash light Change?
  218. Clicking noise draining battery?
  219. EGT guage freaking out
  220. My 4 cylinder VE20DE engine..
  221. any one have a good 5 speed tranny?
  222. Shifter Vibrates and Makes Noise
  223. Removing shift-knob
  224. What size JSP Touring Wing is Recomended?
  225. Funny Noises from the engine.
  226. Starter for manual VE
  227. VG30E Engine Diagnosis
  228. Window Regulators/Motors
  229. constant 12v power in dash
  230. Indication of a bad Rear Main Seal? Pics.
  231. exhaust stud symptoms
  232. One more headlights conv. done (with AE)
  233. Consult info
  234. WTB: Bose amps
  235. Frame Damage?
  236. lack of power until 3000rpms on my VG
  237. starter squeel/honk...lube it?
  238. Ignition control module
  239. 93 GXE -- Lumpy Idle/Faulty fuel gauge
  240. Ve to Ve Swap Concerns
  241. I think I found my proplem
  242. VE30 Engine Diagnosis
  243. bad O2 sensor symptoms?
  244. VG30DE turbo
  245. Ball Joints...
  246. Where Is The Coolant Temperature Sensor?
  247. keyless entry on maxima used cars
  248. RSTB in, thanks BlehmCo!
  249. A bunch of stuff
  250. Ignition Coils Resistance
