- where can I get this suspension part?
- family or sports sedan?
- Approx 35 miles w/ gas light on????
- Removing rear brake assembly 94 GXE
- Need Help
- couple ?'s
- Electrical Woes HELP!!!!!!!
- Bosal 099-549 Catalytic Converter - Need your help guys
- Yay! VE power is back!
- engine or transmission issue
- Need Bushings
- Car won't start
- Heater core replacement
- Write Up For Digital Climate Control Self Diagnose.
- Just claybared my Max.
- Right rear brake
- Pleased to announce.
- How brakes fails?
- Suspicious wire...
- Got The 1993 SE, Now To Fix Things
- I was driving and...
- Engine Lifespan
- 94 maxima fuel injector
- How much brake fluid do I need?
- EGR Question
- Windows will not roll up??
- Aftermath of running Prestone Super Cleaner...
- E36 Headlight Write-Up
- another headlight upgrade option?♦♠
- Bose question, weird problem, diagnosis?
- 6 cly to 4 cly
- Write Up?
- ohNoes! Sunroof Problem.
- No start (Weird...)
- Axle Problem
- RIMS
- Colder A/C ...Maybe?
- Car And Driver August 1992 - Tripple Showdown - Four Door Throwdown
- spoiler options and suggestions please
- Intake Plenum leak.
- Electrical: where do all the power windows send their signal to?
- 3rd gen in movies?
- Erratic Idle & smoke = electrical problem?
- RE-SOLDERING A NEW OXYGEN SENSOR
- Time to say goodbye to the 93 maxima?
- What cures a hard shift from 1st to 2nd
- who the hell are all you people?
- 91 Max at 55mph and beyond
- SELL MY 92 GXE AND GET A 93 SE??????
- Moving The Rear Stabilizer Bar Out of Way To Install Muffler & Safety Issue
- MAF
- Electrical woes
- VE Water pump replacement questions
- motor swap???
- OBD1?
- Shorted system..forgot to disconnect battery while changing alternator..
- Crankshaft Position Sensor and TPS
- suspension and brake work HOPEFULLY this weekend
- VG30e head mods
- dead temp gauge?
- 3g's GXE
- Water **** Solenoid
- Can an Adjustable Catalytic Converter Be Finished Into Place With a Propane Torch?
- 4th Gen Antenna Mast in 3rd Gen?
- Car running roughly + another question
- Full Kaminari Kit, $1.00?
- Injectors 1,3,5 have no power
- Is There Anything I Can Coat My New Exhaust System In To Prevent Rusting?
- buying window regulator from ebay need help
- What Motor Oil Do you guys use ??
- O2 Sensor Ended Up Dragging On Street
- car randomly dies, any suggestions?
- The Time has Come!! VTC rebuild!
- So I got a reminder today of why I like VEs
- To those who’ve replaced strut mounts
- BULB'S NAME?
- Wider tire?
- headlight adjuster stripped
- What rims fit?
- Can't Get Past WA State Emissions Testing
- Radiator Fan Won't Start
- Possible vg5 donor..should I jump on it?
- its me again....something else this time :(
- Ahhhhhhhhhhhhhhhhhhhhhhh..........
- How Do I Remove Stripped Rear Caliper Bleeder Valves?
- e36 Hi and Low beam on at the same time
- rear anti sway bar
- Burning oil??? Inquiring minds want to know...errr umm at least mine does
- Ahhh yes, coolant bleeding revisited
- max's progress halted for a while.
- Keep VE Parts car? on Not?
- TRACTION CONTROL?
- wheel question.
- Grill Mods
- CV Axles
- Turbo
- a/c function
- clear corners
- Should I Get HID's or E36 Projectors
- e36 Headlight And Grll Problem
- Has Anyone Replaced All Their Brake Lines?
- VE vs VG
- Pilot Bushing - VG AT -> MT swap
- how to check 94 maxima ATF
- Bump stops
- June 1989 Motor Trend Magazine - Maxima vs. Cressida
- ECU diagnose
- 5th gen pillow ball mounts ??
- oil pan issue
- Thirdgen turbo setup Rebuild thread..
- Help me Front Grille removal
- 1st Gear...it's alright! Second gear...
- High output alternater?
- need an axle seal NOW, where can I find it??
- Repainting need to know where to get paint...AH2
- 92 tranny swap ?
- Where to find a VLSD?
- TRANNY PROBLEM??????
- Engine rebuild and transmission replacement
- removing leather on bottom part of bucket seat?
- Where to buy a steering part
- Is it possible to get OIL into transfer case??
- Swapped wiring harness, now won't crank..
- Question on ECU #s....
- Any1 know who this is?
- Suspected problem, looking for confirmation
- Magnesium 9lb rims are promising 2-3hp gains!?
- SLR motorsports.
- Camber Kit
- Intermittent Wiper speeds
- Hesitation in the power band while accelerating
- What is this?
- Grooves worn in Underdrive pulley
- New VTCs vs. Rebuilding VTCs
- Pesky Seat warning belt light and chime
- Transmission problems
- 3rd gen repair > 4th gen
- this sucks....window regulator just blown out
- What Happened
- Metric Socket Set List For 3rd Gen
- I'm about to take the Plunge!
- fuel pump problem
- VG MT Internals vs. VE MT Internals (gears and such)
- FSTB for VE: Recommendation??
- i need help with the throttle body
- Stock Amp?
- our 'cotton' anniversary
- CARBON CANISTER HOSE CONNECTION BROKEN - Still Safe To Drive?
- Darned O' unreliable VE's...;-)
- Starter Help!!
- Reading a wiring diagram for the door latch switch...
- VE Rear Fuel Rail Removal
- 5 spd jumps out of first gear.
- odd butt-dyno readings...
- LEAKING GEAR OIL FROM (pic inside)
- balljoint greasing
- Spark plug type
- ksport gt springs
- Eluding tiny miss
- Bose swap and Auto climate control swap question
- Just Saying Goodbye
- Fuel pump relay
- I Need Some Info
- VE 5 Won't start unless pushed
- Digital instrumentation swap
- '90 Automatic Transmission
- Torque Specs for Fuel Injector Rail
- Steering column alignment / higher gears
- need new ECM
- cat back exhaust
- How Many 3rd Genners At Maxus?
- speedometer reading
- VG to VE swap. Gear ratio differences.
- Removing sunroof shade.
- Rewire to get rid of Bose?
- Exhaust Manifold (Rear)
- Rubbing sort of sound
- Trunk remote open keeps firing
- Windshield and rear window trim removal
- Huge issues....please help! : )
- PS boot? or is it?
- having a hard time
- replacing LCA, balljoint
- Looking for Fusable link right after battery?
- Max cutting off
- CAI question
- Strange A/T issues
- would u buy this max?
- Broken intake gasket
- Collateral, sell or hold?
- Would you buy this 1994 GXE for $2200?
- Engine detonation
- Nissan Maxima Timing Belt Change Tutorial
- Temporary Ride
- Headlight problem
- Tech Help! ECU dead, need assist in tracking problem down!
- Which wire on MAF is signal and which is hot?
- gas needle jumping
- Why must people suck at driving?
- Poor A/C in extremely hot weather
- Car won't pass smog!!!!
- Maxima dropped 3rd Gear
- Why you don't reuse O-Rings...
- 3rd Gen Wheel/Tire Setup Questions
- Cars RPM Drops and stalls my car HELP PLEASE!!!!!
- main relay location
- How to remove tie-rod...on an 02 altima....
- Bumper Removal
- $ave gas = run leaner than 14.7
- thanks to the org
- power steering hose replacement question
- New problem..help!
- NW Engineering Phenolic thermal spacer kit interest??
- VE gaskets
- Aftermarket Fuel Flow Meter ???
- Different Exhaust Valves
- Loud Squeaky noise
- Intermittent Shake in 3rd Gear Under Load
- IM adapter to put an 00VI on a VE?
- Underhodd Pics of Nice VG30E's
- sunroof fix for good?
- Gauge cluster question
- Best place to purchase timing belt/water pump kit?
- Warpspeed pipe installed at last
- Out With Old, In With the New.....'er
- Free vice grips with every service!!
- E36 gremlin...help?
- Reverse rpm limiter - is there?
- Brake Master Cylinder
- Power Seat Swap
- why 17 year olds are immature and cant appreciate a 3rd gen
- Does anyone here run a smaller battery?
- Will N/A VGE A/T go under 6s 0-60mph ?
- Changing auto to standard
- Crankshaft pulley Belt Sizes
- max giving problems... maybe jealous of new car???
- Did some routine maintenence and replaced injectors... now car misfires while cold
- Gas is Expensive...
- cruise control
- Identify This Electrical Component (Part Two)
- OEM GXE Fog Lights Installed
- SE and GXE interchangable parts
- Cold Air Intake Pics
- Bad mileage and Engine surging problem
- Maxima GXE vs SE fuel pump? Walbro 255lh pump?
- clutch pedal return/assist spring
- What can be used for Brake Booster Hose?
- Maxima Headers And/Or Exhaust Manifold
- VE30DE Factory Intake Picture
- Identify This Electrical Component (Pic)
