- Need pic of where IAC is located please
- Fuel injectors/rails question
- O2 Sensor question......
- Help 90 Maxima folding rear seats
- Automatic acting wierd
- Fender Removal...
- cooler themostat performance
- Water Pump Questions
- Master Cyl leak
- Had my Pacesetter STS and BlehmCo RSB Links installed today (long)
- Speedometer and Odometer question
- power windows problem
- Tire Question
- much of a difference??
- trans rebuild question
- porting questions
- Good Nissan Specialist
- Bodykits
- I did a little LED install write-up
- need help
- clutch slipping... NOT! question
- Hole in firewall? (Amp installation)
- Like my polished VG throttle body?
- testing rear injectors
- Power Steering Fluid Change/flush
- Timing Belt
- PM the guy!
- Pacesetter Headers
- Interchangable 5 speed?
- Good Y-pipe Deal $160
- new owner of 93 GXE
- throtle body's help
- Help, Door lock not working
- help.....anybody?
- please help ASAP
- Help - idle and accelerationg
- Engine Flush -To do or not to do-
- Climate control. Can this be done?
- Quick Question
- Great prices at Jerry Rome Nissan
- any questions for a vet?
- Bad Gas Mileage
- Good deal on 18" rims
- Adios my friends, its been real!
- Polishing intake manifold?
- Timing belt change question
- ATT gearheads!! Engine swap!
- Brakes!
- free mods?
- Good deal on Ebay for a MAX
- Nissan Maxima GXE 90
- Friend needs new KS in 89se but.....
- Which EXHAUST???
- Help: the dealer said my 91 Maxima is over
- self diagnostic
- help me indentify this part...LOOK...
- Fenders
- New here, had some questions
- Bose Stereo
- For Sale!!!
- Manual Tranny Fluid
- Chrome door handles
- Surging and Stalling...93 Maxima...
- HVAC Question
- Will They Fit?? Please Help!!
- Is it knocking or something else?
- Newbie
- Engine Scraping Noises
- my 93 maxima dying down
- Polyurethane FSB Bushing Question
- New Owner Pics
- Nitrous anyone?
- fixed up, and painted maxima
- Fuel Pump/Gas Tank... Gasket?
- sticks in reverse
- Trans Line pressure increase
- Painting chrome
- 300zx parts???
- Engine rebuild kits
- VG Hybrid Intake Pics + Writeup
- ECU and Tranny control
- code 22: fuel pump circuit
- muffler - help
- Oil puddling around spark plug on cylinder 3
- sirius modual
- Question-Can you put dual exhaust on a 3rd gen max?
- Newbie Question
- removing shifter
- The skinny on brake rotors??
- Strut install. The final solution
- 92 Maxima Se Flashing Abs Light - Help
- Vacuum Tubes/Idle air control
- I found the cause of my stumbling problem below 3000
- Gravity Brake Flushing
- running lean
- tranny leak after CV replacement
- New paint
- Headrest TV's: What's the biggest size that fits??
- 93 infinity J30 fuel injectors in VEmotor
- Noisy Engine
- How do they match up?
- Bulletproof Tranny Question
- Touch up paint for a pearl white max
- elecrical snafu
- Window Tinting
- End of the Line for my 3rd Gen
- what do i solder in the door lock timer ?
- Ebay MAF
- maximaless is now bodykitless
- Finally working on my Max again
- Buying Car Back From the Insurance Company
- finally got a decent digicam to borrow - may not be 56k friendly
- ecu piggy back
- Had to get the BlemCo RSB Links welded
- Hood hinged at the front...
- New 3rd gen owner
- Throttle Position Sensor Bad ?
- This Pic Blew Me Away
- 93 GXE Automatic problems.......
- alarm system
- vacuum hoses
- Does not run
- KS still ****ing me off, why????
- Noisy Lifter Problem
- Please help me - water is getting in my car somehow!
- My twins (Max & M3)
- removing rear window trim
- Exhaust stud
- Engine Swap
- What next? Vacuum hose?
- Trannsmission problems.......
- Foglight bulbs....
- I found my problem
- Doing a brotha a good ole favor (accident)
- Should I Fix The Studs Myself....
- Intake
- Changing o2 sensor
- Rising Gas Prices...
- 94 max in trouble
- Any place to get touchup paint for these old cars?
- Maf
- 1990 recall and shifter not unlocking
- can't get my max to stay running
- Will this oil filter fit -15208-9E000?
- Just came in
- Stripped Nut
- 93 GXE Headers
- Lighting for the shifter lettering went out !!
- 94 MT tranny fit in 92 SE???
- VE problems (again) any help? kind of long
- Sprint springs ST shocks Struts
- Have any of you heard of this catback exhaust?
- Intake manifold gasket question
- Possibly both problems????
- Fuel injector colours?
- Drive Belts
- anyone swapped in a VG from a Quest or Villager?
- Brake light comes on occasionally
- 2000 se stock 17 inch 6 spokes on a 3rd generation
- special edition for the 90
- Wierd ticking and hesitation
- me vs tree and dog
- Torque Converter
- rear wheel bearings?
- Audi flip key
- hinged liecene plate
- I don't know what to do...................
- Timing Belt & Water pump, 93 GXE
- y- pipe
- Rear Hubadge
- Vacuum hose on 90 SE Auto Trans?
- Bose problems, HELP!!!
- Someone hit my car!
- 300ZX Wheels
- Making power with a VG
- Eh, PCV valve?
- high km's???
- Painting the car?
- "Misting" the intake
- Power Door Locks actin' up...
- Please read, need your help
- help help help
- Gabriel struts...crap or what!
- Very Strong Odor
- bose question
- Need information...
- Hey all.
- Axle tranny seal leak...help :(
- spring rates?
- 4th gen cat converter?
- New pics from downunder! 520k
- i need some help??
- Replaced my Fuel Filter, something wierd happened though...
- seat belt
- Auto to Manual swap
- Spoiler Removal on 89 Maxima
- SPEC Stage 3 clutch and Fidanza flywheel...
- E36 conversion
- Need some advice...............
- Ground kit and fstb
- AMB Indicator in Auto A/C 93 GXE
- levoc installation
- knock sensor connector
- upper chain tensioner replacement?? ..arghh
- VE won't start
- Do we have a locking differential?
- Chrome Gauge Rings?
- Anyone pull a VE with the tranny in place?
- Where to find ECU upgrades
- E36 conversion
- R.i.p. Ecu....
- Removing my Doors and Handles
- Noise
- VG Front Strut brace doesn't fit ???
- Need some advice on value of parts.
- Axel Removal, Tie rod ends
- Bad MAF or O2 sensor?
- Magnaflow Installed (Pics & Review)
- courtesy ligts not working
- Clean Engine Bay...
- 91 Tranny question
- Parts fitment
- How long to replace an injector?
- oxygen sensor?
- Help!!!! Plz
- A/C on a 91 GXE Max... problems...
- Keep the original air filter or replace with a funnel-shaped filter
- weak or clog injector
- Factory Bose Stereo Removal help needed
- Warpspeed Performance exhaust questions
- So I had the BlemCo RSB and Addco RSB installed
- Transmission Noise
- Rear Disc Brake Conversion
- headlights
- new pics........max and z
- Does anyone have a Megan Racing Muffler...
- Thing's I've gotta do to my car :/
- Alternator Whine
- Knock Sensor
- Missfire (put....put...) in VG, possible things to look at..
- Balljoints, alternator, P/S pump, Exhaust Flex Pipe
- Plus sized rims...
- Can't find the pcv valve..........
- Just flushed the brake system
- found a new site preaty good site...
- Suspension...Need an opinion
- did anyone blow there car up when installing rsb links?
- will 93 GXE sohc engine fit 91 GXE?
- Transmission
- 3rd or 4th generation, that is the question
