- Big Problem?????
- Power Setting on Auto Trans blinking
- Foglights and Fuses
- Rev Limiter?
- Spark plug gap
- does a vg30de fit?
- Window Auto Down Switch?
- SuperMax does 0mph at 8500rpm!
- gasoline smell through vents
- Help Quick!
- Transmission Rebuild Question
- Need Help Removing Lower Timing Cover
- airbag light flashing after wheel swap. How to reset?
- PPL w/ Interior Knowledge
- Wheel bearings
- Ignitor specs
- O2 sensor
- Ghetto-Fabulous Molding Glue Removal
- How to use your keyless entry...
- Intake removal
- Y-pipe Heat shields?
- Drivers window not working
- Sun Roof
- Is it just me?
- Matt's Mod of the Week
- Drivers window auto-roll up feature :D
- new project for racing vids
- Just put in some LEDs to light the gauges, BUT...
- Dropzone Lowering Springs...
- Hood louvers
- Custom trim for shifter PIC
- 92 MAxima noisy
- So Mr. Gone. How does you new style CAI work?
- Pop Charger vs. Cold Air Intake noise levels
- new maxima bumper
- GXE badging on a 3rd gen???
- What does it mean....
- Finally, Another VE CAI!
- Anybody With Torque Converter Info?
- Newbie needs advice
- faulty MAF and O2 sensor
- O2 sensor wire length/performance
- I'm Super Gay
- Z32 VG30DETT in a Maxima !?!?!?!?!
- 4th gen = 3rd gen STS
- Help: a grinding noise from front when backwards
- AutoZone Vs Dealership
- What stops us!
- Blower
- HELP! car won't go into gear...........
- Se gauges in a gxe
- ABS actuator leak..???
- A Few Quick ECU Questions
- pics lots of pics oh yeah and an egr problem
- 4 wheel disk brakes on GXE?
- Operation Ultimate VE 5spd...Budget: +/- $10K
- Power antenna wiring!
- polyurethane bushings
- Does lack of tailpipe/muffler affect sensors?
- How much can I get for my 1990 Max?
- About to buy parts...Need Answers!!!!!
- How many pints of tranny fluid does a Manual VE hold?
- strange noise
- putting in a youger ve any suggestions
- Lower spring
- A few questions
- 3rd gen Maxima chat
- AC Accumulator
- E-brake light
- Buying a VE
- hard shifting into 4th
- stuff to look for when buyin used maxima?
- abs light and clicking noise
- Woodgrain kit
- What type of rotors?
- sold my max
- How much to pay for '90 maxima?
- Mustang MAF on our maximas?
- Sensors!!!!!!!!!
- Loosening crankshaft pulley bolt
- Abnormal vibration from my car
- photoshop
- What's my problem? Afm?
- eibach springs
- correct size belts for UDP
- anyone in new york need an airbag
- otto bar for a 4th gen
- Where does this hose go?
- Help, flat tires (sorta long)
- T-belt and Water Pump question-????
- 04 maxima rims
- Between a Rock and a Maxima
- how does the max ride when you drive fast?
- Will these wheels fit?
- Odometer and brakes question VG
- # of times getting stopped
- Speedometer stopped working
- Head Light Swap?
- 3rd gen Cup holders.
- 92 maxima gxe performance specs?
- Stock Stereo Questions
- Hel with accesories for my 92 Maxima
- Pathfinder upper Intake and 240 Throttle body???
- Man , I m getting frustrating with the engine.
- Air flow sensor?
- Meter Fuse blowing. Ideas?
- Z Calipers
- some help pliz!!
- NGK Iridiums?
- EBC Greenstuff brake pads
- Results of Advancing timing
- axle question
- Parts Car????
- w00t! Then and Now pics :)
- shifter bushings
- Maf
- Anyone know how to brighten the corner lights?
- rear axle make it faster
- k&n cone filter
- headers
- Projector Headlights
- Suspension Tech Front Sway Bar
- where is the computer located
- VTC rebuilt, now i think i have a problem!!
- Brakes
- 91 a/t maxima questions...
- 19x8.5 rims on 3rd gen?
- Alpine head unit installed in 93SE. One problem.
- Best Y pipe for 93 SE?
- Painting 93 SE wheels?
- Matt's Project of the Day
- My Tach quit working!
- what can i do?
- need help with engine
- What first?
- skyline
- ECU blues.......has anyone else had these symptoms?
- Power Windows on the 1994
- antena mast $$
- VTC on/off switch question
- head light
- Blue Filter Black Housing/Tube Twin-turbo Filter System
- AC Air conditioning fluid 94
- hp wanted
- Anyone near columbus ohio?
- Input Bearing
- excessive play in steering
- Accelerator pedal sticking !
- collar for the power antenna mast
- Tinted Corners
- How to replace MAF?
- Do I have OEM floor mats??
- Starter Problems?!
- Rough Idle/Engine Mssing
- cowl hoods
- Seafoam(Again)
- EGR removal?
- 1993 Maxima seats
- Need to know the size of my front & rear speakers......
- Shaved door handles/poppers
- Diagonstics for most of you guys :)
- Problems Problems Problems
- B-Pipe question (and y-pipe and cat)
- cd reciever and power antenna
- So I just got my Magnaflow muffler now...
- pacesetter cat-back
- Bulbs for Digital climate Control Buttons
- Knock sensor question
- Intake manifold removal
- Y-Pipe question
- Feels like I got a problem with my air flow...
- CV Boot how to replace it
- Maxima's odometer dead. Any advice?
- Ground Wire Kits...
- i need help....anything is appreciated!
- help!!!
- Any differences in JDM Trannies??
- mod for possible 45hp
- warpspeed performance group deal
- Wish me good luck , I'm bringing me another Maxima home.
- Control Arm Bushings
- need help with timeing belt before 6pm central
- Nada for sale
- Turboing a VG
- shocks
- VG Intake Manifold Porting...Any Gains From This ?
- VG30ET Swap FAQ
- Another one bites the dust <long>
- Couple of Questions..
- maxima whinning
- maxima leather color
- Door hinges
- a/c problem
- upgrade will give you an extra 15+ horsepower
- any pics of custom cai vg
- Aftermarket seat replacement
- new to me
- Need Stiffer Rear Springs 4 Towing
- window problems
- Pacesetter headers installed
- BMW Sidemarker lights installed
- I love Little Debbie
- Nitrous Joke??
- H3 ==> H7
- Vacum hose
- VG Engine Removal
- VE Valve cover vent tube polished
- front strut replacement.....how hard if doable(word??)?
- What's up with my Maxima? Starter issues...
- C/V joint?
- vq in a 3rd
- oil question
- Tranny Questions
- Clutch just went out
- Power Transistor......hesitation and idle racing problm
- Check this out from e-bay
- Fluttering/Ticking Sound
- some good news and some not so good news
- I love my transmition
- how to check fuel injectors?
- VG Questions
- Shifter getting stuck
- Pic Request: Performance Muffler On Max
- headlights dim at high rpm's
- Gas Mileage
- balljoint stud
- Will an S2000 antenna fit on the 3rd gens?
- Hubcaps and BMW Lights
- Electrical Problem or What!?
- gauges for the gauge pod??
- It's Done!
- Power doors and keyless entry
- Towing
- HELP! Can I swap a SOHC vg for a DOHC ve? 92 into a 90?
- Oxygen sensor.....
- new stearing wheel
- rear reflector
- Plug under seat?
- pin # 7 tach wire?
- factory alarm
- tach wire.. hooking up alarm
- digital guage display and hud
- Dash Board!
- Which corners?
- Auto-dim mirror with comp/temp (pics)
- vg30et
- Question Regarding the lights
- fuel problems in an 89?!?!?!
- 1990 Max Intermittent Start Problem Help Fast
