View Full Version : 3rd Generation Maxima (1989-1994)
  1. Factory Service Manuals
  2. VG slow when warmed up
  3. Intake:88-91
  4. WSP Y problems
  5. Newbie question
  6. Interior lights won't come on
  7. Thank you Craig Brace.
  8. Time for new MAF?
  9. Piston slap :(
  10. NOS/Pulley
  11. SE Strut bar
  12. I took it out today...
  13. Door/Driver's Window/Sunroof Problem
  14. Anyone Done This?
  15. MAF Adapter, Jeff?
  16. Hub-centric rings for Cobra rotor BBK
  17. is this a worthwhile exhaust?
  18. Updated my cardomain...
  19. Help Need Answers
  20. Error code 51 anybody
  21. ECU on wrong side?!
  22. Where can I find this little dohicky?
  23. Car will not start after accident. Computer problems, airbag problems?
  24. I found an interesting website with some good info.
  25. Paint Codes.
  26. P/S- Idler Bracket
  27. 92 GXE A/C Cleaning(not coolant flush/recharge)
  28. Brake pad dusting: menace to society
  29. Did I gain or loose hp
  30. Anyone feel like posting the link to making the fan switch mod?
  31. Locking or Non-Locking Differential?
  32. Alternator help
  33. Code # 34.
  34. Sudden Exhaust leak????
  35. Relay question
  36. fill er up (i think)
  37. Antenna
  38. lights
  39. One Cylinder Out Intermittently
  40. Broken rear sway link/hole
  41. COSMO racing CAI, anyone have this??
  42. howdy everyone!
  43. Squeaky startup after stuck in mud
  44. white face gauges not so bright
  45. MIRC ROOM - new server
  46. connecting exhaust 2.5 to 3inch
  47. Widest wheel
  48. Rear back lights!!!
  49. Does anyone know if E-ram really works?
  50. Probs with Sun roof sliding shade!!!!
  51. Driver's side cv axle seal keeps leaking what is the deal?
  52. nitrous ?
  53. Lowering 92 SE?
  54. Bushings for rear suspension
  55. Newbie question, does anyone know what type of e36 lights will convert to my 1990 max
  56. Antenna won't raise without unplugging/plugging!
  57. Installed Magnaflow muffler today!
  58. plz post maxima videos....
  59. Spark plugs.
  60. Temp gauge Problem
  61. need coils
  62. what can make my car go faster car
  63. Freeze plug removal
  64. Is it hard to replace the speedometer coil and the rear brakes?
  65. Finally found some Seafoam!!WOW
  66. what a max looks like when a blazer t-bones it doing 70+mph
  67. James92se or others looking to mount the VE block to a stand--->
  68. Should the ECU record a code when a relay is bad?
  69. Fuel Filter changed....but now the engine "sputters"
  70. 5 spd and hot weather
  71. Looking for tranny swap suggestions
  72. I need the inevitable Bose Help...
  73. radiator recomendation
  74. Should I sell my Maxima or fix it?
  75. Rebuilding rear calipers?
  76. radiator support
  77. valve cover gasket replacement on 89 se
  78. Australian Members???
  79. Diversity Adapter
  80. can someone tell some info on e36 headlights please!!!
  81. about f-ing time!
  82. Rock It Till The Wheels Fall Off
  83. how qts of oil do i put when changing the v6 maxima?
  84. ve under drive pully
  85. Best way to bleed the brake lines
  86. headlight question(sorry)
  87. anyone sell their max lately?
  88. piston rings
  89. First Major Repair->VTC Replacement Brilliance or Insanity (long)
  90. It never ends, one thing after another need help about belts(kinda long)..
  91. Ignition Upgrade
  92. Alarm going off for no reason, HELP!!!
  93. Fuel Pressure Regulator
  94. How do you decipher the trans-axle code?
  95. Camber Kit for Intrax Springs
  96. handling trouble
  97. Crankshaft Bolt
  98. Front Passenger Wheel making noise?
  99. R 134
  100. The rear tailight
  101. Car does not move correctly
  102. I need some help , What is it left for me to check ?
  103. My Car Stopped Firing Help... Help!
  104. bad gearshift lever or tranny?
  105. 91 Maxima Update
  106. Optimizing vs Modifying
  107. buttons
  108. part list for ve 5spd swap
  109. Which tranny cooler ??
  110. rear shocks???
  111. Painting a plastic grill?
  112. 91 or 92 Max not runnin good in rain
  113. OK, so I am seriously considering quitting with Maxima's forever...
  114. Suspension Suggestions
  115. rear tail light fuse blowing
  116. 5spd question
  117. 6 hours C/V joint project
  118. Loose Sunroof
  119. Maf?
  120. Why does the fuse keep blowing out?
  121. what kind of e36 headlights do i need
  122. cleaning pop charger
  123. Seafoam equivelant
  124. Changed the starter
  125. VG auto to 5-speed swap, JWT ECU any good?
  126. Took Some Pics Today...
  127. Help
  128. rear factory speaker hole size
  129. muffler suggestions?
  130. Sunroof Glass Replacement
  131. im new to the forum
  132. Failed Emissions HELP!!
  133. Ebay 5th gen ftsb??
  134. Automatic seatbelt issue
  135. Does the Power Steering Hose come off?
  136. The Best Aluminum Flywheel?
  137. car won't start!!
  138. will ve 5spd axels fit on my vg hubs?
  139. Triple Gauge Pod Question
  140. Got car back, help?
  141. Connected wrong battery terminals.....
  142. coolant leaking
  143. What's The Whole Cu Ft Of Our Car?
  144. Need new POwer steering pump
  145. My day at the junkyard (pics)
  146. Car shakes when breaks are applied ... ?
  147. Had Warpspeed Y pipe finally installed.
  148. speedo not working
  149. worn Wheel Stud ????
  150. VG transmission...
  151. Help with my Bose system!!!
  152. engine burning oil
  153. fuel injector gone bad
  154. anyone ever install a Warpspeed CAI?
  155. Oil Pump??? or Worse
  156. Oil Pump??? or Worse
  157. got worked by a ve today
  158. diffence between 84-88 JDM 300zx and american 300zx engine?
  159. help!!!
  160. just bought a 1992 Maxima SE 5 speed
  161. e36 head light help
  162. Sensor questions
  163. Who has done their timing,,,themselves !
  164. Freeze plugs
  165. Today I made a new headlight wiring harness
  166. Chris92se. Your midpipe is done : )
  167. Track speed troubles....
  168. Who has installed KYB2 GSR's???
  169. Control arm/balljoint play...leaving on 1600mi road trip....GURUS ADVISE PLS!
  170. Parking brake light on/off
  171. Quick Lowering Spring Advice...
  172. DNAS420 has returned!
  173. What next?
  174. what to do with maxima.
  175. need a new radiator...
  176. Torque converter
  177. Cut open a 15208 55Y00 filter...
  178. GXE vs. SE vs. LE
  179. rear brake pad how?
  180. Has anyone done true daul exhaust yet?
  181. audio relays
  182. broken brake line....
  183. Fog Lights
  184. replace or not Bonjo Bolt (brakes)
  185. Pillar/Headliner...Removal and refinish?
  186. Cruise Control
  187. Say.. if anyone wants ported/polished VG heads...
  188. BMW Headlights on a Maxima
  189. VG30E Timing belt...
  190. Tint Pics if ya got em
  191. trunk switch not pop help while theres light =D
  192. Ok to share vacuum line with EGR and power valve?
  193. Dash Removal
  194. VE '92 totalled
  195. Engaging clutch problems
  196. hydraulics
  197. how long should the oem struts last?
  198. How many people here are using the Toyota filter........
  199. POLL wing
  200. POLL wing
  201. Friend just got a VE
  202. Help with new intake filter setup
  203. An invitation to the Cattman MaximaWest04 Meet in Tucson on 15 May
  204. Denso Iridium Spark Plugs
  205. mucho's money into max!!!
  206. newbie questions
  207. Make your own Angel Eyes!!
  208. Regulator went...any way to get window back up?
  209. Fluid leaking in floor board, loss of pressure in clutch?
  210. what u think of my new angel eyes????
  211. What kind of performance clutch do you guys recommend?
  212. axle differances and compatability
  213. another max
  214. Ignition wire options for 92 VE
  215. Antilock Brake Bleeding
  216. Plz help in a hurry!
  217. Where is the starter located?
  218. Bogged down @ <2k rpm
  219. Headlight Problem... Help
  220. I vow to ask about for sale items in the for sale section
  221. Quick q about auto tranny drain plug removing
  222. How much is it to replace my tranny fluid? its for a 5spd
  223. Need your help! Can you vote for my car? It will only take 5 seconds
  224. Poor maxima...
  225. How do I PROPERLY take care of my tranny??
  226. Brake fluid Leaking!
  227. Clutch slipping or tranny problems? ...long
  228. Side Door Moldings.... On or Off?
  229. Found out wats wrong
  230. My new SE!!!
  231. Car not starting, need some help
  232. VE Transmission Q's
  233. Digital AC control conversion??
  234. ground wires
  235. Intrax spring
  236. Cold air Intake
  237. Cams question
  238. Question regarding the 3rd gen drum to disc conversion
  239. pesky bling bling
  240. Odd Hesitation/running rough. Help please.
  241. 18's FO SHO!!!!
  242. GXE custom logo
  243. Car won't start in the rain- help
  244. Odometer problem (update!)
  245. electrical problems...
  246. Check engine light on
  247. O2 sensor LOCATION/pop charger
  248. Trouble with strut install
  249. 91se Dohc
  250. how do I adjust 92 SE DOHC idle speed?
