View Full Version : 3rd Generation Maxima (1989-1994)
  1. 91 SE Valve ?
  2. Eibach camber kits
  3. quarter panel fitment
  4. new struts and springs
  5. WTB: interior pieces
  6. Auto Climate control Display and TRans??
  7. Anti-Theft light not turning off
  8. How to turn off these lights...?
  9. Yet Another Bose Problem
  10. Maxima with 19s...
  11. a/c display also dim & dash lights gone
  12. So I took some pics.... (56k = links, so no biggy)
  13. Speedometer Problems
  14. What color should I paint my max?
  15. a/c display is very dim
  16. cattman question
  17. How do you pull the engine codes ?
  18. Locked Out
  19. Check Out The Hood!!!!
  20. ported throttle body
  21. Speaker Grille Project
  22. help replacing rear struts
  23. steering wheel
  24. Are VE's supposed to have an IACV gasket?
  25. car over heating
  26. for a prospective buyer, how reliable are these cars?
  27. 91 Maxima clutch change
  28. tranny diagrams
  29. steering knuckle and hub
  30. new parts
  31. Seatbelt warning chime
  32. Keyless Entry
  33. Water pump pulley removal. Help,pls!
  34. MAF adaptor for 93 SE maxima?
  35. VTC / exhaust cam gear swap
  36. PPL W/ Alpine HU
  37. Fuel Pump Problems
  38. Detonation sensor
  39. Engines
  40. Cedar Falls Mini-Meet
  41. Car Problems...Again
  42. Fuel Filter
  43. quick question how to tell tranny with lsd
  44. VG30E with VE pistons Question...
  45. MaxTuning's VB Mod ....NICE !!
  46. suspension question
  47. Broken Speedometer. speeding ticket. how do i fix?
  48. Carbon Fiber door pillars ready to go!
  49. Battery Relocation
  50. Bodykit
  51. Those with BMW lights. Have you been able to take out the lense?
  52. I want my keyless entry! HELP!
  53. 92-94se 145mph gauges in 89se?
  54. KYB strut install problem
  55. Need critques on 3d 3rd gen WIP! !56k!
  56. interior door lights
  57. NEED HELP! Major trunk issues.
  58. Car sputtering when started
  59. Feedback on A Mod to the Rear Trunk Plastic
  60. Window Off the Path
  61. broken shifter???
  62. transmisson fluid
  63. Engine Mount replacement?
  64. coolant leak!!!!
  65. reprograming ECU
  66. HELP! --mainfold problems on a 91SE
  67. cornet light installation problem
  68. Electric superchargers on a ve
  69. Cooling system question
  70. Something slippin...Bogs?
  71. Possible Brake Mod
  72. Will A 760W Amp Kill My Alternator
  73. Clutch Tranny Quandries
  74. speed sensor
  75. Where to get reliable rebuilt injectors?
  76. 91 Maxima Strange Front End Noise
  77. Best feeling in the World
  78. Valve Adjustment???
  79. recommend Brake pads..
  80. Introduction/question!
  81. Fixing TurnSignal,Low/High Beam Light Switch
  82. rear bumper cover
  83. help me n my ride!!!
  84. Car acting really wierd(TPS problem?)
  85. newbie
  86. Advance Auto Parts-$2.50 Purolator oil filters
  87. Which Sway Bar
  88. uder driveing pulling
  89. I asked a big hairy guy for a hot date
  90. Fuel Filter
  91. Smelling Gas
  92. 1993 Maxima without A/C
  93. replacing the altenator
  94. Camber Settings?
  95. New member in need of advise
  96. Engine Mods
  97. VE CAI 0n Ebay
  98. ABS - Short? Where? How?
  99. removing front fender
  100. ? CAI filter in fenderwell
  101. timing belt
  102. VE Coil Pack Part Numbers?
  103. Speaker problem
  104. Brushed aluminum center caps
  105. I am having a quandary! Plz read.
  106. Ball joint going... gone ??
  107. need some pieces ASAP
  108. Safe Mode
  109. need to know high,low, ground wires for headlight harness
  110. anyone interested in a shaved door handle kit?
  111. Pics of my first ever complete car paint job (not my 93)
  112. clutch fork or slave cylinder
  113. interesting problem
  114. Manifold Stud Woes
  115. Opinions / Suggestions
  116. IAC chip
  117. Timing belt
  118. Driver Side Window Sticks...
  119. My new Cardomain page is up, w/pics of ebay CAI and my idea of cup holder
  120. New user!
  121. Link to removing door bumpers
  122. Rite Exhaust Kit?
  123. How nice are we? HMMM?
  124. Air Box Hiss
  125. I just installed my Fidanza and Y-pipe, first impressions....
  126. carbon fiber hood
  127. ignition coil
  128. sprint lowering springs
  129. Will a similar bose fit?
  130. i bent a rim
  131. wheel emblms, or center cap stick on emblems
  132. 89 Maxima GXE Audio question
  133. For your reading pleasure
  134. Made my own CAI today.
  135. coilovers on a 89-94 question
  136. Sts?
  137. Best place to Purchase window regulators?
  138. altenator belt problems
  139. sr20det in maxima
  140. 5sp swap help
  141. ANOTHER PROBLEM, losing transmission?
  142. Idling at 1000 on a hot day?
  143. Has anyone added a Fan on their Tranny Cooler?
  144. Suspension
  145. 89 max wont start
  146. Fuel Injectors resistance?
  147. Powerlocks on hot days
  148. varibale Tming control solonoid
  149. Some New Pics
  150. will getting a 2.25 outlet pipe reduce noise?
  151. Adjusting Headlights
  152. grill
  153. Carbon Fiber Door Pillar Prototype has been done! (pics)
  154. Partial Newbie:needs advice
  155. TB cleaning question
  156. digital dash problem
  157. Haxima is gone. All done. Mods etc FS
  158. 89 GXE Tranny problem - Drive and Reverse don't work
  159. Gen 3 digital dash. Pics anyone?
  160. Remove 90 max axels
  161. Notings Turns on in Car and Cluster
  162. Pwr win/locks/seats/seatbelt/trunk circuit
  163. 300zx Brake Caliper Question
  164. proportion valve on rear brakes
  165. 92 GXE broken speedometer
  166. belt or the altenator?
  167. Koni Adjustement???
  168. !!Horrific Maxima Axident Pics !!
  169. Picking up a new tranny
  170. NAPA Paint
  171. request for e-town video's
  172. starter problems
  173. considering parting out my max
  174. New springs and struts
  175. Exaust Manifold replacement
  176. bolt pattern
  177. indiglo gauges
  178. How can I tell if my water pump needs replacing?
  179. Exaust Heat Wrap?
  180. Suspension parts...please HELP!!!
  181. Maxima power windows act possessed
  182. gauging interest: Carbon Fiber Door Pillars for 3rd gens!
  183. swap out rear drum brakes to disks
  184. Stock spring dimentions
  185. avalonracing products
  186. jdm vg30 question
  187. Yet Another Transmission Question...
  188. Yet Another Transmission Question...
  189. cold air intake for 3rd gen maxima
  190. transmission meltdown. Cause?
  191. Thought this looked kinda cool....
  192. transmission help please
  193. Buying Cruise Control parts...help me list them?
  194. To sell or not to sell....
  195. possible tranny problem
  196. Finally repainted the lower front valance (pics)
  197. 2 things
  198. Need a show of hands, Wings west body kit!
  199. Rear Parallel Link
  200. ac
  201. Udp Does It Fit
  202. major problems
  203. to sell or not to sell
  204. regular, mid or premium?
  205. pcv &O2
  206. Eibach or Intrax
  207. rims problems
  208. Brakes? Uneven Wear. Ceramic Pads
  209. 3rd Generation questions
  210. new to the board
  211. annoying long clutch throw
  212. cosmo racing cai dilema
  213. what should i put in for my third guage?
  214. Load index
  215. 90 GXE Automatic Transmission
  216. VE bogs down when warm
  217. replace maxima interior
  218. pushed VG farther than ever before to date...
  219. replace brake lines
  220. tick tock
  221. where to buy an upgraded wire harness?
  222. My 93 Max
  223. give me some advice on this problem!!!
  224. Clutch replament. What to expect
  225. Mechanic
  226. Broken Gas Line
  227. Removing broken antenna?!?!?
  228. Nissan Maxima Commercials
  229. Camber Settings.
  230. bmw antenna conversion
  231. lug nuts
  232. Seat belt light wont go off
  233. Will the 90-93 accord body kits work???
  234. need to disable key lights
  235. electric static shock
  236. Car Wont start
  237. abs light
  238. 94 GXE Radiator Fan
  239. Stripped threads on tranny housing
  240. Seafoam
  241. Can I rebuild the VE, without VTC's
  242. Manifold Patch?
  243. Error codes and TSB information!
  244. Please Help Max Tranny
  245. Antenna stuck
  246. Best brand oil filter for ~$3?
  247. Is $695 for struts too high? Help me w/ $ ?
  248. Cold Air Intake Template?
  249. Blowen Bulbs
  250. VTC's from hell...
