View Full Version : 3rd Generation Maxima (1989-1994)
  1. Steering wheels
  2. broken exhaust manifold bolts
  3. Electronic Climate Control Circuits
  4. what is changed when the rebuild a transmission
  5. Temp gauge
  6. Damn
  7. Average Annual Maintenance Costs
  8. Help needed replacing CV joint boot / 91 SE
  9. When to Stop Love affair with Max
  10. Lights
  11. What dino ATF fluid do my fellow 3rd gen owners use?
  12. fianlly got my lights, but now i have a problem
  13. Emmisions..what are my odds??
  14. Need info on Engine parts
  15. Potential body decay???
  16. Buying a 90 SE Auto..advice please.
  17. Bluebird AWD?
  18. Question ....
  19. For the first time ever today....
  20. Finding the Right Cold Air Intake
  21. Ignition coil ?
  22. Host pics. of my car anybody?
  23. new body kit
  24. new body kit
  25. whats better, a/t or m/t
  26. Need help on new struts and coilovers
  27. rear speakers not playing
  28. I need everyone's opinion on this mod except for Matt93SE
  29. (can you link me to...)
  30. Have to jiggle my AT shifter to start...anyone know why?
  31. Door panel snaps
  32. Suspension spring replacement
  33. VE headers
  34. SE chugging problem
  35. Oh no, I think my cylinder head is cracked.
  36. Power increases
  37. Air strut suspension ~ Bell drop
  38. 94 GXE maintenance opinions
  39. Battery and Brake dash lights won't go off
  40. Replacing rear drum shoes
  41. 3rd Gen Wheel questions for 17s
  42. update about nismo1989
  43. Oem Trim Paint ( Pics)
  44. Quick cigarrette lighter wiring question
  45. etown 12-13
  46. Buying a new max
  47. Seatbelt chime!!! grrr....
  48. rear arm bushings
  49. Popular headlight bulbs
  50. New 5-speed Installed
  51. Any wood trim pictures
  52. powder coating rotors
  53. Hermm, found something interesting...
  54. Someone Tell Me The Value of my car
  55. time
  56. How Can I Get the Best Engine Performance on a '93 Maxima GXE?
  57. Tranny slip in 2nd and 4nd after overhaul
  58. car RPM moves up and down in acceleration
  59. questions before i buy
  60. gauges
  61. Car shuts down while driving
  62. Blank, slotted or cross drilled?
  63. Pics of Mustang wheels on Maxima?
  64. Will 91 GXE auto tranny fit in 94 GXE auto
  65. timing belt question
  66. Ride Quality on 17" Wheels
  67. how much for 1990 Maxima SE RED
  68. Blocking off EGR
  69. Someone help me my car went crazy
  70. exhaust manifold studs
  71. Pimpin Electic Blue Max w| Shaved Trunk
  72. egr valve cleaning
  73. windshield wiper arm making alot of noise
  74. need help bad smell
  75. spark plugs in the VE
  76. What Made My Car Stop??
  77. Why does this kit look familiar?
  78. 3 most helpful aftermarket guaes
  79. Car wont turn off, need help.
  80. Need urgent help - AC blowing HOT air :(
  81. what's this thing?
  82. wiring question
  83. Car Trouble... Need Help please
  84. VG 5-Speed Swap - Worth It?
  85. knock sensor problems
  86. Timing chain
  87. Clear corner probs.
  88. Bumping up timing
  89. Digital Gauges
  90. Tranny
  91. Steering ratio adjustment
  92. I miss the 3rd gen days!
  93. a few questions
  94. What's this rubber on the shaft for?
  95. We goofed: Urgent help needed!
  96. keyless problems
  97. Brakes, bad steering job
  98. rear seats
  99. Have you guys seen this damn thing yet?
  100. AC Relay Problem? please help
  101. Is it security system?
  102. 4th gen tranny in 3rd gen
  103. For those with ACT clutches. Does it smell like burning?
  104. suspension and other bushings
  105. ECU - Where is it???
  106. magazine ads?
  107. BMW Lights...
  108. Roof inside jumps track
  109. ACT clutch did me in...
  110. how much would it cost to...
  111. neutral safety switch? please help
  112. Alternator Removal
  113. Installed the redlinegoods leather boots
  114. putting in lowering springs
  115. Idle Air Control Valve - AAC Valve leaking coolant
  116. 90 SE makin me crazy
  117. Dash Clock
  118. Timing belt changed. Some issues now. (Sorry, kinda long)
  119. custom install help
  120. custom install help
  121. Another Turbo VE to the ranks
  122. ABS dignostics information with explainations
  123. How do I find the compression *ratio*?
  124. Found another new toy for my 89
  125. speedometer problems...on an 89
  126. VE 5spd conversion
  127. Right corner light doesnt work
  128. ABS warning light on
  129. Power surging under heavy loads
  130. Electrical Problem
  131. Will a condensor from any 3rd gen fit?
  132. here is the update with pics of my 2k2 maxima muffler installed*(warning 56k people)*
  133. Catback system help needed now!!!
  134. Newbie Transmission/Flywheel Questions
  135. A/T shifting hard.......really hard
  136. lights that were on ebay (jeff was wrong once again)
  137. Spark plug side gapping, yay or nay?
  138. viscosity oil for ticking VTC's
  139. Window Trouble
  140. Intentionally negative camber for aggressive cornering
  141. what the... crazy maxima rear calipers
  142. on and off problem!
  143. charcoal grey paint and clear coat
  144. Why Do and Would You?
  145. Power steering fluid
  146. whats's this Variable Intake manifold used on the VE30DE 5spd all about?
  147. Can't get my timing just right!
  148. new pics with stillen lip installed
  149. scared...she's goin into the shop tomorrow
  150. update on control arm swap
  151. The Max is for sale!
  152. Tranny oil in and out in one pour
  153. Re-bored Throttle Body 4 Max $190
  154. Quick Strut Bar Question
  155. is this bad?
  156. Would these headlights work in our maxima's
  157. Heat Gauge Not Working
  158. Tranny Fluid Question!
  159. Power surge when accelerating
  160. update: over a year with tokico blues_opinions:
  161. uhhh
  162. My Maxima Saved my life!!!
  163. K&N cone installed
  164. odometer/trip odometer quit
  165. trying to identify trim level
  166. gauge not working
  167. 92 SE Project Car
  168. A higher numerical gear ratio
  169. jus wondering..........
  170. Fuel Pump
  171. Subaru wheels
  172. New window reg. problem...
  173. blue maxima doors and windows
  174. 2nd Genner Detailing Advice
  175. 3rd gen with a VQ30de-k
  176. Is there such thing as a replacement wireharness?
  177. Car Problems!!
  178. Removing window motors from regulators?
  179. Fuel Injector Identification
  180. JWT Cams on a VG
  181. shifter question
  182. over revved:(
  183. i need help with my 91 maxima!!!!!!!!
  184. Two-Tone Paint Job?
  185. VTC rebuild tools? oh and studs :)
  186. Electrical Problems...
  187. 1991 maxima sound system...
  188. m3 mirrors
  189. Looking at Spring Options.
  190. Who has installed a 2k muffler on a 3rd gen?
  191. Hid
  192. Smoking....
  193. MAF sensor problem
  194. grill swap
  195. 1989-1994 maxima dual fan help for 300zx
  196. WW kit por favor
  197. Moon Roof Removal
  198. Suspension differences between GXE and SE?
  199. Location of fog light switch
  200. AC not working
  201. '93 SE Door Locks no longer function
  202. Drivers Side Lock
  203. T/B tensioner adjusment
  204. The Right MAF Adapter
  205. Fuel injector circuit open???????????
  206. new used car
  207. Rear disc or drum?
  208. engine swap
  209. one cylinder not firing
  210. Sonar Suspension Failure (SS II)
  211. Sonar Suspension Failure (SS II)
  212. Radio advice
  213. Yet another CAI thread
  214. Driver axle problem...help :(
  215. Cruise control Governer
  216. Car won't start (Changed valve cover gasket)
  217. What else could it be ?
  218. parts
  219. 3rd Gen Maxima Cartoon
  220. Would anyone be interested in a built VG?
  221. ut oh... metal shavings cant be good
  222. sprint springs on stock struts...bad or ok??
  223. NO heat
  224. security system
  225. WTF Looks Weird
  226. turbo and 300z ecu question?
  227. Ait Loacation
  228. need some insight
  229. 1990 gxe with a vq in it with its dash
  230. diagnostic question
  231. Replacing lights behind AC/Heat controls
  232. just f**ked my third engine
  233. struts
  234. Tranny is dead, now what?
  235. Auto Tranny question....
  236. Shop has had my car for over a month!!!!!
  237. How to replace distributor for 92 VG
  238. 92 max parts car
  239. heater
  240. Need Motor or Heads
  241. another bmw question
  242. Loose wires!
  243. Help, rebuild question!
  244. Engine Overhaul or Replace Gaskets???
  245. speedometer needles
  246. VG30DE in 1989 maxima
  247. Brake Bleeder pressure?
  248. Knock sensor
  249. Qwerky AC
  250. rear brakes
