- Getting new keys...
- I think I'm missing something(body related)
- Tranny cooler
- Updated site - pics of my new black Max
- Custom grill with BMW headlights - update
- Next Level Performance
- Jet performance chip vs. JWT
- Control Bushing
- Just Put on used body kit
- ve 5-speed drain plug
- lightend flywheel ?
- Supension Max Gas Struts For 89-94 Max's...?
- are the trannys that drive the VE the same found in the VG?
- Seat Belt Light and sensor
- Well...this might be goodbye...
- Stalling problem?? clogged catalytic?
- Is it possible for timing to jump in a vg?
- door molding question....
- is there a point?
- sticky accelerator
- VQ 3.5 in 3rd gen?
- annoying rattle in my engine
- Performance Upgrades
- new guy with guestions
- My Alignment Readings
- bad mileage w/ new WSP y pipe
- My VE is lucky to be running right now
- Anyone ever replace their condenser?
- Painted Y-pipe and Cat
- AT Transmission replacement
- Whitish Smoke from tail pipe
- Timing Question...
- What should I get for brake pads?
- Cefiro Lights
- Wierd Problem
- timing chain tensioner
- Brake booster difference between ABS and non-ABS cars?
- Intake Bracket for Aftermarket Filter?
- Compression Question
- Lcd Clock
- Driver door hinges
- Fixed: FlexPipe, Alignment, AirCondition
- Looking for Matts Big Brake Kit
- Transmission Weirdness
- Want to plug a 95-99 bose radio into a 3rd gen.max
- how is EGR valve SUPPOSEd to work?
- Best Cap and rotor
- New... Story on my crazy max
- Gauge face
- Matt/Jeffy/other suspension whores :)
- my car is turning into a robot
- Bose speakers with after market headunit
- Code 12 (MAFS) Need help! Matt? Jeff?
- just bought used body kit
- faulty transmissions?
- some autozone clamps
- Nice webiste, all Nissan Maxima TSB's by year and TSB number
- Guys with Gauges, Normal Operating Temp Fog VG?
- power steering pressure hose
- Kind of Muffler?
- VE / VG exhaust poll........
- HP Boosters
- new power steering rack?
- speaker pods
- 112? 115? bolt pattern on a non center cap rim question
- 2004 wheels fit a 92 SE?
- stock fuel pump ?'s
- What do i need for an upgraded fuel system?
- checking a fuel injector
- auto trans questions
- Advanced my timing today
- Swaybar Q's
- 96 cobra rims, yay or nay ??
- where is the cheapest place to get motor mount??
- Running Rough
- tranny cooler questions?
- WSP Y pipe
- JWT ECU Question
- door handle
- non lsd to lsd
- Knocking at acceleration at ~70km/h
- Y-Pipe Installed
- car won't start
- '90 Drops Cyls & Dies-Restarts Cold
- Back in the Saddle
- mix/match springs? plus bushing question
- vg30dett pistons in ve30de
- should i?
- suspension questions?
- 300zx Calipers
- wiggly axle
- trying to diagnose-what next?
- VG30E compression #'s? not ratio
- Replacing Thermostat and Tranny Problems
- Fuse Problems
- Air Bag
- oops...
- CV Joint Replacement
- HELP :help:
- How many miles can I expect from my tranny
- A leaky Trany
- What is the best way to decide if Rack and pinion needs replacing?
- How do I remove the headlights?
- Rebuilt Speedo Sensor ??
- Just swapped motors..wont start
- Vg30de - Ecu
- question about replace the BOSE HU and speakers..
- Window regulator broke...
- replacing crankshaft pulley
- bogging problem on 90 SE +1 more
- Bad Millage on a 1990
- Is there a way to increase the idle speed?
- noisy noisy
- Bose radio/speaker problems
- I'm back!!!
- coolant leak above pulleys..?
- California people- emissions?
- Valve above egr?
- Tranny Problems and Installing tranny cooler
- VE30DET Dyno Results
- VE engine pull..sorry no search
- Just installed struts and springs... awesome!
- carpet cleaning
- New Excuse For The Window To Stop Working!
- I'm moving on!
- Window problems.....
- Hooking up and Aftermarket Alarm.
- Auto Tranny Stuck in 3rd
- Is there a too big when it commes to tranny coolers?
- Electric Problems
- msd ignition
- New Virus Going Around On IE
- I finally fixed my idle. VG30
- Wanna buy the pimp my ride MaXiMa ??
- interior decorating....lol
- I wanna go faster
- cruise control problem
- paintjob
- mr. clean autodry
- Ve Vg Ve Vg Ve Vg
- Ouch!
- I Heart The Junkyard...
- Help dealer want’s my arm and my leg for this interior piece
- Jack stand placement
- need help with auto transmission
- Bad engine mounts - Y pipe vibration
- There goes the tranny...
- how to install a CAI System for a 1992-1994 Maxima
- Windsheild, Windows, & Wing Question
- Warspeed Y-Pipe
- HELP... Parking Light Issue
- Replacing Struts/Stut mounts
- Aftermarket fog lights
- Removing door molding q's
- Cruise Control Dash Switch MOD?
- Help Need QUICK: Rear suspension
- How to find out my door key pad code
- loss of power pro...any suggestions
- FSM Link?
- VG30DE Timing Belt
- What does this code mean?
- what are the best strut bars to get
- What to change for high performance tune-up
- random shifting problems
- Okay I Goofed (Craig Brace!) any other wire guru
- Exhaust Pipe and Suspension Prob
- brochure for the 1990 Nissan Maxima
- Turbo Charger
- Exhaust questions
- starter gone bad
- Manual tranny noise?
- how low can u go without bouncing?
- Simple
- Anyone Switch Their Auto Stick?
- converting AC
- stiff steering wheel
- Anyone in atlanta want to fix my timing?!
- Seatbelt chime terror
- ATTN :Jeffrey Tran
- Random Skipping Bucking 94
- Bushing Plate question for 1993 Maxima
- VIN number lookup?
- And for the record, my bad
- CC Relay
- Spark Plug Question!
- Today I have learned that....
- Wing and aerodynamics
- thinking about staying with the VG
- question about underdriving
- Tranny finally went - advice?
- The great 3rd gen picture thread
- Headlights
- swapping seats
- Fuel Injector Connectors
- Not your average window question!
- Fstb
- Ignition Coils
- fouled spark plugs?
- Anyone here ever run a "sneaky pete" on their Max?
- Rims
- fixing front end
- fiberglass bodykit
- otto 5th gen strut bar fit my GXE?
- Strut creaking really bad (Internetautomart)
- Abs Unit
- Place Racing CAI question....
- Manifolds
- cf door pillars
- Seriously considering a turbo.
- Tire Rod Question
- Touch Up (Detailed)
- Gas Tank Filler Neck
- Yet another style climate control
- anyone know this guy?
- Does anyone know transmission capacity
- VE 5spd tanny question
- Question about rear brakes on a 92 SE
- Finding vacuum leaks
- Exhaust manifold gasket... DIY?
- stud replacement
- My car idles at 1grand. Is that a bad thing?
- Code scanning
- black Max, trying to cover scrathes
- AAC Valve - Help please
- The plot thickens.....hmmmm
- pison rings
- What Part Do I Need
- What kind of paint for interior piece?
- Brushed Aluminum Dash Kits
- Mechanic Quote Check
- tornado air
- Found This Site
- Stillen K&N Cone and Engine RPM
- Tapping Sound While Turning
- how much paint?
- Replacing the Ball Joint Need Pointers
- RedLine performance shift boot
- Rough idle after warmed up....
- Catback Question
- Color code
- My Maxima Pics Finally!!!
- white plastic piece inbeteen door panel and window
- Window Switch
- My Maxima (Pics)
- preferable e36 bulbs that don't burn....
- cold air intake for 3rd gen maxima
- Getting too much gas??
- Stalling... akward acceleration
- Air Conditioning
- Air Conditioning
