View Full Version : 3rd Generation Maxima (1989-1994)
  1. Tire Speed rating for 190 hp engine
  2. 91 max, Interior lights flickering
  3. My valves tap at times!
  4. Newbie Question
  5. 92 gxe question yet agian they will keep comeing
  6. gas mileage
  7. Window won't roll up!
  8. 93 Blue SE. Saphire blue??
  9. Old Subject
  10. Does limited slip mean non-locking?
  11. does this max have posi or not?
  12. questions for those who have body kit rim expirance
  13. SPEC clutches?
  14. Door Code
  15. ha
  16. 92 maxima gxe questions....
  17. dumb MT tranny question
  18. Code 33! Is it O2 sensor?
  19. Suspension Gremlins (already replaced struts)
  20. clunky feel to 5-speed manual
  21. Question: Crank Pulley
  22. Need Power transistor
  23. How much can a SE w/ a 5-sp tow?
  24. FS: FSM for 89 Maxima
  25. power lock doors
  26. Power steering belt removal
  27. I'm new, have a couple of general questions..
  28. Transmission Trouble? in 92 SE 5-spd
  29. Converting from Auto to Manual
  30. Plug wires
  31. Check out the new england events!
  32. Shift Lock
  33. help asap stuck in reverse
  34. How much are new speaker amps?
  35. 6 speed in a 92SE ????
  36. 1986 300zx - Interchangable Parts
  37. fuel injector issues
  38. ECU Upgrade and advance timing upgrade question
  39. Fender off = More rust
  40. Need some info on changing shocks in rear
  41. bunch'a questions
  42. Total Swapout
  43. Please help! Big car trouble!
  44. window whistles
  45. 350z rims on 90 MAXIMA
  46. Tranny Problems
  47. new pics of car
  48. Need help on a JDM VG30ET swap
  49. 1986 300 zx engine in a 1990 Maxima??
  50. Do i need to lower this?
  51. Here are a couple of updated pics...nothing major...
  52. So I've had the damn thing for a year...
  53. differences between SE and GXE trim
  54. hood wont open, any ideas?
  55. WOuld anyone like to help?
  56. Turbo?
  57. gauges
  58. The Party's Over - Post Timing Belt Blues
  59. Latest Mod *pics* v.Matt93SE
  60. hi
  61. a big huge question
  62. PCV valve, IAC motor, where?
  63. 1990 gxe model sensors
  64. Dead A/C?
  65. lowering springs
  66. brakes
  67. 5spd Swap Update
  68. Looking for info - wife bought a 1994 Maxima with out me
  69. BUYING a Thermostat
  70. KYB vs. Tokico
  71. 90 GXE won't start after rain
  72. need help
  73. Fuel Injector Cleaner or Not
  74. Error code 34-Detonation sensor-where is it?
  75. finnally got my 19s on my 3rd gen
  76. Bosal Muffler & Cat follow up
  77. Maxima and 626
  78. RWD conversion?
  79. How long does Ebiach & Tokio combo last?
  80. Chris91SE Missing??
  81. Well, the UPS guys drop some rims off yesterday, now i have some tire size Qs..
  82. Rislone
  83. msd box
  84. is there a place to buy the stillen body kit cheaper than stillen.com?
  85. brake rotors ????????
  86. Those with Subs, where did you run the wire through the firewall to the amp?
  87. hi new, and many problems... help!!
  88. Knock sensor gains?
  89. 92 Project Car - Windsheild Leak Found and Fixed
  90. I got two problems, both electrical
  91. 92 Project Car - Update for 2004/07/22 (Dialup beware!)
  92. a/t harsh shifting
  93. Radiator Flush?
  94. Venom 400 Module
  95. Auto Tranny Issue - Surprise! Surprise!
  96. Distributor
  97. Wheel spin
  98. So I had an idea...
  99. Is it my window regulator?
  100. Good site - overview of perf mods for VE30DE
  101. Preserving life
  102. rough idle
  103. timing chain or belt
  104. Where can I find parts
  105. Suspention Problem/Question
  106. Help!!
  107. Brake bias percentage(proportioning valve)????
  108. quick when cold, slow when warm
  109. fuel injector confusion???
  110. Unorthodox UDP for VG
  111. had some spacers made
  112. TEMPERATURE rising on hills
  113. Crazy AC problem in 91
  114. Horrid Squeal from the front right wheel area
  115. O/d
  116. Looking for a sunshade
  117. Transmission Problems
  118. 2 noob questions
  119. Skyline Project Countdown!!!!
  120. Muffler question
  121. What the hell is wrong with my 90 GXE!!!??
  122. Auto tranny experts post here.........
  123. 92 Maxima Engine Swap
  124. problem with my 3rd gen max
  125. resetting electrical problem
  126. Need Recs for 89 intake/suspension
  127. im a noob i know
  128. free tach voyage
  129. Silverstars and XD5 pics
  130. White SE Guages
  131. Recalls Suck...
  132. I Saw A Commercial Last Night.........
  133. rear wheel bearing assembly
  134. Will a 200sx strut brace fit my ride.
  135. hesitation/stalling, those who fixed it please post!!!
  136. Splash Shields... can we run without them?
  137. e36s -- differences?
  138. Emergency break handle tightening
  139. Customizing a subwoofer box
  140. comparing vg30deTT to ve30de engines
  141. HELP please, Maxima keeps cutting out...
  142. Noise in front suspension
  143. Price I should pay for a 91 se auto with 45,000 miles all org?
  144. those who got their car painted, how much did it cost you?
  145. R-33 Tailight question
  146. CAI How To?
  147. Oil Pan Gasket
  148. Loosing power what now???
  149. need help
  150. TPS Adjustment
  151. Where is the PCV? How hard to change plugs?
  152. Head Gasket
  153. Interior Swap...
  154. Leaking oil between engine/trans...
  155. Ever annoying clicking sound
  156. Spring QUestion
  157. Finished removing the side moldings....and washed/detailed today!
  158. Thread pitch on O2 sensor
  159. Major Problems....a little long.
  160. whyyyy
  161. About BMW E36 Conversion the Projector Lights kind
  162. Which Brake Pads Do You Prefer??
  163. help wiring problem
  164. Wheels smokin!!
  165. Screeching Noise
  166. What do you put your's in?
  167. will 95-01 manual tranny fit on VE motor??
  168. Suspension Woes
  169. Painting old tails
  170. Turbo
  171. I suddenly have a Traction Control Light
  172. Grinding noise from rear brakes...
  173. Will be buying a 91 maxima sport edition sedan in 2 day with 44k miles.
  174. What is the normal idle speed in "D"?
  175. changing my brakes on my 91 GXE
  176. How fast is 4800 rpm in OD?
  177. need some power
  178. 4th Gen guy helping out 3rd gen gal
  179. Shaving Rear Emblem
  180. Help a new 89 maxima owner
  181. quick timing question
  182. Insanity it seems, Maxima-S13...
  183. Who has done there own head gasket replacement?
  184. leaving
  185. Testing Spark Plug Wires
  186. re: photo of muffler set up on a 91 maxima?
  187. help with door light and motor mounts
  188. Thermostat blown...NEED HELP ASAP!!!
  189. Noobie questions...
  190. dust guard
  191. Traded Max for Hardbody, what about engine swap?
  192. Oil pump leaking, what are my options/costs?
  193. Shaky steering wheel
  194. Lower Control Arms
  195. new maxima owner with some ????
  196. Best spark plug
  197. Need help with determining which sensor has failed (security system)
  198. Pacesetter Headers
  199. I finally got a VG turbo to mod instead of my VE!!
  200. How to check fuel pump/injectors?
  201. No Reverse
  202. 150k and wanna do maitnace to make her sound BEAUTIFUL
  203. fog lights
  204. HELP! Did I buy a bag of problems?
  205. Is this a transmission problem?
  206. HEADLIGHTS! (whistle) here boy!
  207. Brake Pad Problem
  208. need to confirm an idling problem after porting and polishing my TB........
  209. Got the new transmission in what next...
  210. Tuning up the daily driver (Nissan maxima 1990)
  211. Noob question what kind of maxima do I have?
  212. Crazy Tachometer...frog in car
  213. Question--I'm Painting My Bumper
  214. Trunk Lock Sensor?
  215. ok, heres the deal...
  216. changing the pressure p/s hose!
  217. Engine Mounts
  218. Clicking when starting
  219. I'm going soft with age
  220. What about the TRANNY!
  221. Stupid slow starting
  222. few question
  223. new o2 sensor
  224. Brake Problem?
  225. window problems
  226. In the middle of manifold stud replacement..
  227. 240sx wheels
  228. Spedometer and odometer aren't working please help!!
  229. jacking points
  230. E36 Headlight Help
  231. Swapped from AT to MT and car won't start... HELP!
  232. VG30E to VE30DE
  233. Suspension Squeak?
  234. Help my maxima just quit!!!!
  235. Testing Coil
  236. A/T hell
  237. TurboXS RFL BOV
  238. Help! Hit Curb! What Is Wrong?
  239. 2" drop on shifter
  240. NGK.COM for O2 sensor?
  241. what are better lights?
  242. 130xxx
  243. Removing the factory tape unit...
  244. Misfire problem...help!
  245. Help my car sounds like its from the jetsons!
  246. Getting new keys...
  247. I think I'm missing something(body related)
  248. Tranny cooler
  249. Updated site - pics of my new black Max
  250. Custom grill with BMW headlights - update
