View Full Version : 3rd Generation Maxima (1989-1994)
  1. My engine bay
  2. loose antenna?
  3. Oh Snap! Broke off my rear swaybar!
  4. Car broken into
  5. Newb Question: Lowering my 93 maxima
  6. motor swap
  7. resonator removal????
  8. Battery underpowered?
  9. Alternator Issues & Replacement
  10. Car won't start, please help.
  11. TI door codes
  12. intake question
  13. Painting
  14. new car
  15. continued stalling
  16. Air/Fuel Ratio
  17. VTC Rebuild Kit
  18. How about tinted Euro-Tails?
  19. ! found wire brush in breather house!!!
  20. Mugen 92-94 Maxima SE V6 DOHC Cold Air Intake
  21. hestiates, almost dies, then runs fine?
  22. intake leak/ whistle...
  23. Changing struts - first time how?
  24. Digital gas gauge problem
  25. New pics
  26. My Max got hit last sat.
  27. help with ground kit...
  28. speakers
  29. Abs.....
  30. Trunk switch......missing
  31. Coil overs or roomer?
  32. Please help me diagnose this problem
  33. How many of you have aftermarket alarms?
  34. Z32 part questions
  35. Why horrid ride after being lowered?
  36. few questions about maxima. -new owner-
  37. Projection headlights..help
  38. oil brand and additives....
  39. Stock Clarion amp inputs/outputs
  40. don't wait until it is too late
  41. Hi all, new to site , need help on extracting ECU codes,,,please
  42. Deactivating Stock Alarm
  43. 91 keyless entry gives one beep, wont program with factory code.
  44. Blew a Headgasket
  45. Fuel related starting problem?
  46. where is the pcv valve in ve
  47. Re4f02a A/t Valve Body
  48. Got my car back
  49. Clutch & Flywheel - Q's
  50. moda r6 quick ques
  51. climate console
  52. is that group deal on pillar gauge pod still on?
  53. No Tach Signal?
  54. e-brake light wont go out
  55. Installing pioneer radio in 94 maxima gxe active system
  56. Just bought a 1991 SE (couple newb questions)
  57. '89 Maxima sales brochure for free
  58. O/D Switch Relocated
  59. Pics of my max
  60. chrome e36 lights..
  61. lowing springs
  62. Suggestions on parts to keep from old Max
  63. advanced timing question
  64. rear main seal replacement
  65. front bumber w/foglight....
  66. o/d lights come on
  67. Starting my car wehn the engine is hot
  68. Car burning AC fluilds????
  69. Part number on K&N filter
  70. suspension questions?
  71. What is this noise?
  72. a few questions for a new maxima owner
  73. Alternative to CONSULT
  74. How can you tell if it's the A/C compressor or you're out of freeon?
  75. bunch of repair questions
  76. Repair manual
  77. New E36 headlights...Whatcha think?
  78. cruise control question
  79. help removing/reinstalling moonroof shade??
  80. strut bar for the ve30de....???
  81. rattling noise
  82. opinion needed
  83. to those that did the auto to manual swap
  84. Key Code
  85. A/C problem. Could it be the switch?
  86. Maxima tranny?
  87. Cams for VG? Anybody tried the Nismo ones...
  88. talking lady from a 2nd gen
  89. 3rd gen maxima spoilers
  90. how to replace sunroof motor
  91. anyone use Restore engine treatment?
  92. Turbo/Super Charger on a VG30E?
  93. power stearing pump, and hose problems please respond
  94. Front and rear BBK's FINALLY installed (really long)
  95. anyone with grounded VTC's help me out...
  96. i need more torque...help
  97. random clicking.....near comfort/power switch
  98. another auto tran problem
  99. opinions and comments..hmmm
  100. Turbo/Super Charger on a VG30E?
  101. ?springs and shocks ???
  102. ??on shocks and springs??
  103. Weird electrical ghosts
  104. pics of dash kits
  105. 91 Max, Break lights problem when headlights are on
  106. What causes transmission slippage?
  107. timing belt and water pump questions
  108. front camber kits
  109. how much do they wiegh
  110. bmw e36 conv....help
  111. ground kits?....
  112. grounding VTC's....
  113. Removing Spoiler
  114. Low/High Beam, Turn Signal Selector Switch
  115. lightened pulley
  116. 1990, won't even crank
  117. Where's the oil pump???
  118. Sluggish, with wierd revving sound on acceleration
  119. injector question
  120. Air Pressure in 205/65H15's ALL SEASONS
  121. trying to remove rear struts
  122. got my 18s!!!!! now for springs.........
  123. sunroof problems
  124. 18" with what tire size is maximum ?!
  125. I Love My Maxima
  126. 1989 Transmission Filter and Fluid
  127. leaking oil =( need help
  128. JDM ve Swap instructions
  129. Rims & Tires
  130. Faulty oil pump???
  131. HUD windshield reflector
  132. Vg engine picture
  133. Rough Idling, jerking and delayed acceleration
  134. blower problem?
  135. driveshaft
  136. low oil pressure
  137. 92-94 Nissan Maxima CARBON FIBER WOOD DASH KIT
  138. brakeing
  139. e36's???
  140. Attention Haters... ;)
  141. JDM ve Swap instructions
  142. Security codes
  143. knock sensor part # for VG
  144. Interior and Exterior lights
  145. Oil Pressure
  146. my power stearing speed hose has a hole in it
  147. Help on buying
  148. problems with antena
  149. just picked up 90 maxima
  150. bead blasting a cai
  151. ?s about screw on VE ECU...
  152. Does anyone know when Nissan......
  153. Some Info: Maxima Wheel Studs are different sizes between the front and rear wheels
  154. Newbie! Max questions. Help.
  155. What's that sound?
  156. 1991 passenger door mirror problem
  157. 94 GXE audio problem.
  158. where to buy SS brake lines
  159. muffler problem?
  160. Help..about my taillights
  161. any one got seats??????
  162. Well I guess this is goodbye....
  163. replacing front wheel bearing
  164. Safety Switch... or not HELP
  165. cold air intake for a 92 gxe
  166. 1991 Knock sensor location
  167. Bose System
  168. Reverse Light switch Adjustment
  169. My First Max!!!!!
  170. Removing side moldings
  171. over heated
  172. Anyone replaced a core support?
  173. Want to make an easy $10 from me? hehe
  174. 91 Maxima GXE (Auto) Possible tranny problem
  175. Fair price?
  176. Speedometer not moving...
  177. Tranny trouble I think.
  178. What is the right place to jack my 93 MAX up?
  179. Leather seat fit
  180. radiator fan shroud question
  181. Headlights Not Working!!!!!
  182. max power...
  183. resetting ecu
  184. Auto Transmission won't go into reverse.
  185. Best oil filter for a vg?
  186. Rough Idle\Random MPG ~Suggestions~?
  187. feul injection ?????????
  188. a-pillar pod gauges
  189. Rathcting Nosie ??
  190. how to connect indiglo gauges in 94 gxe
  191. Replaced front struts, now steering makes sound
  192. Removing passenger axle...92 5spd
  193. Is Dexron III ok to use in place of Dexron II?
  194. Limping along after an 1,800 mile road trip...what gives?
  195. Good price for front engine mount.
  196. climate controls..
  197. My reverse lights don't work.
  198. temp gauge not working
  199. Will this battery fit?? ~ Optima D31A
  200. trying to hook up oil pressure gauge
  201. Continued rough riding...
  202. witch wire to hook up air/fuel gauge to ?
  203. help please
  204. Is anyone looking for parts? I just came across a few cars at the junkyard.
  205. 1994 maxima EGR sensor
  206. decisions decisions decisions
  207. If it's not one problem, it's another :(
  208. Anybody buy one of these?
  209. blower problems
  210. emissions
  211. Removing Tranny
  212. New clutch and tranny installed today
  213. POLL: rebuilt tranny or used one?
  214. Just picked up my Max...couple unexpected things...
  215. I'm getting my first 3rd-gen tommorrow.
  216. anyone from here own a maroon max
  217. Alright here is what a "broke Crankshaft" looks like
  218. will there be a problem with my tires??
  219. keyless entry
  220. 1991 Speed Sensor
  221. dash lights out!
  222. newbie question (lights..)
  223. Performance Fuel Injectors
  224. piggie cai design
  225. Pickin up a Max...got a project ahead of me
  226. Radio Back Light for display Intermittent
  227. A/C Compressor
  228. confused SE or GXE?
  229. Maxima Exhaust
  230. Strange Smells/Odors
  231. dont b mad but i looked
  232. Some first pics..
  233. Timing belt questions
  234. No Heater Light
  235. Heat Question
  236. Kyb Rear Struts
  237. good power wire?
  238. what would cause a constant 'steering pump' noise?
  239. 1991 Maxima Wipers Broken – Help !
  240. Signature Picture Guidelines. Read before posting signature pics!
  241. Auto can't shift
  242. 2nd Generation VS 3rd Generation
  243. The Mystery of the Dying Power Locks (Did I break it?)
  244. curb
  245. header wrapping
  246. did 91 se's have keyless entry?
  247. engine ticking
  248. For those who went for the Fuel Filler Recall
  249. Upper timing belt cover
  250. transmission question
