- tranny mount
- want to rid of my ABS
- the electrics!
- Question about VG injector tips?
- 5 speed swap done but have a slight issue....
- Congrats to Jonmandude and Pearl93VE
- strut tower brace
- Clutch pedal adjustment?
- Throttle Problems?
- Doesnt go in park
- 5spd intermit no crank
- Sway bar dimensions and recommendations
- 91 Starting Difficulty
- Headlights or dash lights not working.
- 2 issues, please help
- Seat Weight?
- Time for new injector harness?
- 1990 Maxima running poorly.
- Control arms welded to frame ?
- Is There a Way to Remove the Floor Carpet Without Riping it Out?
- Seat Covers
- Was There a Separate Parts Catalog From FSM?
- Misc issues inside....come on in!
- replacing radiator, suggestions on brands?
- Can a Power Steering Pump be Re-built?
- Changed Hood Lift Supports
- Swapping radio and climate control
- Battery Dashboard Light on
- Trans go shift kit
- Maf sensor?
- NA VG power
- Are my motor mounts bad?
- Harder to slow down.
- power window go up very slow
- Changed the Plugs
- Rattling coming from A/C compressor
- Heater Core Replacement??
- Addicted to fixing cars???
- Dropped Car Won't Move. Transmission?! HELP
- Recommendations for struts/shocks
- Loud sqeeking noise....
- Wierd transmission issues
- stereo help
- Help! I need some tranny removal instructions.
- remote starter options, for manual tranny
- Front Strut Bellows Gone
- possible project car.
- Where did the Maxima lose it's height?
- striking rod yoke/seal problems
- Leaking Radiator Coolant
- HOW TO: Replace VG camshaft position sensor
- Whats the best way to drive an old A/T
- Now that im done with school................
- Engine misses when wet at idle
- Engine swap checklist
- Windshield Wiper timing
- VTC Clack/No Clack: A Video Comparison
- Oh no, not again
- BEST YEAR OF 3RD GEN MAXIMA
- damaged tierod threads: fix or replace
- My 24 Hours of Lemons debacle...
- Has Anyone Found The Weight Specs on Max Engine & Tranny?
- what this could be?
- Pictures of my max photoshopped for Konig Contest
- Axle question
- Any VG owners running Nistune?
- E85 experiences
- Dash vent replacement?
- D2 RS Series Coilovers - Info on a Groupbuy deal - checking for intrest
- How Do Mechanics Pinpoint The Exact Source of an Exhaust Leak?
- Negative pulse door locks?
- led dash light help
- Took Some Pics Today!! 93 GXE SELLING SOON !!!!
- Difference between the VE30s?
- Taillights always on, why?
- Front Door Adjustment?
- What other make has your car been mistaken for?
- Power Locks
- brake line woes
- Grounds For Engine and Chasis
- What OEM 18" wheels are direct bolt on's for my '92 GXE?
- Moving to Texas
- Wiper fluid leak
- OMG Power Steering Going Again
- Where Can You Find A 3rd Gen. Maxima...
- My 92 GXE
- Center Console Armrest Lid
- When doing 5speed swap, has anyone swapped ECU's too?
- Lowering kit with springs/shocks, best price?
- My quirky VE :007:
- backfiring through exhaust
- I'm off to see the wizard: Goon
- Cold Air Intake
- 92 5sp VE Tranny
- Clutch choices
- Smell gas fumes when starting my car please help
- Testing injector o-rings
- Is it worth putting $1000+ into a $1500 car?
- VTC TEMPORARY FIX, PLUS QUICK QUESTIONS....
- Need help replacing Power Steering rack
- my dad just sold his 3rd gen
- Tokico Struts
- clear timing belt cover
- anyone ever removed the valve body?
- heater valve by firewall???
- Stillen aero kit
- Engine swap problems
- Conversion project? Open minded only
- Clutch Trouble
- Throttle Position Sensor ( TPS )
- Can someone decipher a part #?
- CMPS trouble
- New Bumpers Finally Painted and Installed
- Any tranny options for the VG Auto?
- Another 3rd gen bites the bullet
- Woodpecker behind glovebox
- Thinking about an Ebay intake??
- fall tune up !!
- accident= Sporting 17"s now
- Going out of my mind
- would i get pulled for these bulbs?
- Draining fuel
- WHAT DO U GUYS THINK OF THIS ???
- Jerking at 2000 RPM
- E36 headlight conversion bracket
- Quick ? about foglights
- Replacing hydraulic lifter on a VE
- Cleaning MAF sensor with CRC
- Hub is loose..
- Are the CAT-->Muffler Flanges Supposed to Bend When Torquing Them?
- MaximaLess Will remain Maximaless
- Any led tail'ed 3rd gens?
- what did you pay for 2.5"/3" exhaust?
- Fans are Keep Running..
- Tirerack
- I want an S2K antenna....
- increase your gas mileage
- the 89SE Superwhite lives
- Same Coolant Temp Sensor?
- High NOx Reading Fails Emissions Test - Max Running Lean?
- Goodies For Sale!
- Sonar Suspension replacment?
- new pics!
- Coolant Leak?
- Cruise control doesn't work?!?
- keyless entry question
- Swap 92 standard audio with Bose from 93
- Easy Bulb Finder
- Saw these, thought someone might want them
- VG30E Almost Complete!!!
- 4th gen front seats??
- Lowering Maxima
- nissan maxima intake adapter question!
- I miss my 3rd gen
- 89 to 94?
- trunk question
- Clutch problem help
- Seller's remorse
- Greddy Evo II exhaust
- Digital Speedo Meter Problems
- Starting/idle/sputtering problem
- Window visors
- q about blue relay on strut tower
- The 12 sec VE Auto dies
- Oil question
- Jittery Ignition Timing, already replaced many parts
- your suspension set ups
- JDM Engine Depot
- Parts source recommendation
- Thinking about looking at this
- 1991 - 5 MOD system GXE
- VG 3rd gen owners - get more power!
- Strange Drivetrain Sounds
- steering wheel click
- Ignition question
- Fuel pump and ECU Fans issues tied all together....
- HELP! Pop quiz: What gets wet on the passenger side causing a miss?
- Flex pipe
- Questions about 92 SE
- Aftermarket E-Brake Handle?
- What's the easiest way to rotate the ring gear (flywheel) by hand?
- Power Issues
- 3rd gen laptop tune/consult fabrication complete (video teaser)
- Reset digital touch entry ( GXE ONLY )
- Gas door doesnt open
- VG30E to VE30DE injector swap
- Max Goes Up in Smoke - Very Scary
- Ignition amplifiers
- She's back to life Thanks to the org & brakes question
- Fuel Injector replacement
- Which is more difficult? Rear seal or timingbelt.
- ECCS Relay question?
- Looking to rebuild my VE.
- brake pad springs
- Heres my maxima
- how...Tail Light
- Cam Position Sensor
- strange popping
- Project MaximaZ
- this is weird
- High Octane Fuel?
- Finally Selling the Max
- instrument panel removal
- VE restoration thread
- Bose speaker problem
- Has Anyone Been Able to Source the LH (Front) Exhaust Manifold New?
- k sport coilovers
- Transmission not engaging...
- Can someone measure the front springs 4 me?
- time is getting near for my 3rd gen.
- rebuilding transmission
- Nissan Sport magazine!
- Missing Splash Shield by Crank? (Pictures!)
- Clutch Pedal Wont Rise After Pressing Down
- Loud humming after turn off
- spring questions
- Installed my 300ZX 88NA Wheels
- Public notice, goon9's parts for sale.(Temporary Sticky)
- Sounds of Water
- Wheel Alignment
- Torque Value Adjustments for Anti-Seize Lubricated Fasteners
- ash tray light
- Black 18" Kobe find
- Resistance of the Heated Mirrors?
- Cai spacer
- Fuel pump don't kick on. ECU Ground bad?
- Tommorow Need to Tow The Max But Remove Rear Stabilizer Bar - Safe to Tow?
- Fuel Injector - Buy from Nissan or Aftermarket?
- Critique my noise reduction idea
- Nissan Maxima Fuel Injector Change Tutorial
- Transmission not shifting!!!
- Do you still floor your 14-19yr old car?
- Check Engine Light
- Fuel Injectors Purchasing
- Leather Seats?
- What Should I Replace Next Guys? SEE LIST
- Worth $500?
- catalytic converter
- Rewiring AUDIO system
- HELP fuel Injectors
- ve exhaust sprockets on the intake side?
- Wheel opinions?
- sputtering
- For those familiar with 3rd gen 3.5 swaps....
- 3rd gen headlights from Ebay
- Strut time, again
- 91 GXE won't start
- Rear Calipers - When Do You Replace?
- Can i have Digital Speedo meter swap?
- Swowlinc is back!
