View Full Version : 3rd Generation Maxima (1989-1994)
  1. seafoam
  2. Wheel Bearings?
  3. VG30E max RPM
  4. resistance injectors, coil pack...
  5. just outta curiosity...
  6. Automatic Heat Conversion
  7. power window regulator
  8. Noise inside the car
  9. fuel pressure at idle
  10. Coolant Temp. Sensor???
  11. Epicenter lighting kit for 1994 Maxima
  12. car won't star
  13. PS fluid problem
  14. driveshaft boot tear?
  15. Trans shifting in and out of overdrive
  16. Foglights+curb=pain in my ***!
  17. '94 Maxima Fuel Injector Questions
  18. GXE to SE auto heat controls
  19. What are symptoms of a Bad Water Pump?
  20. yet another bose question
  21. help, ecu code 1,2,3,4,5
  22. spark plugs
  23. Steering Wheel SWAP!
  24. oem fog lamp help
  25. new maxima owner in da house
  26. White spark plugs?
  27. Vacum diagram
  28. Need a Tranny for a 93 SE automatic
  29. coil packs JDM
  30. Please help new guy out with motor swap!
  31. where to find cai
  32. Tech Help Please !
  33. One step closer
  34. Checking Tranny Fluid
  35. engine swap question
  36. Fix or say g'bye - what major problems to look for in a 10 yr old car?
  37. why dont wheels fit?
  38. blown cat
  39. stickys
  40. Sputtering
  41. Brembo cross drilled rotors
  42. Door MudRunners? Door sills??? ???
  43. OFF SCHEDUAL... as always! SKYLINE UPDATE!
  44. BlehmCo Rear Parallel Links - Review
  45. Bike rack from Avalon on 3d gen Maxima?
  46. Maxima <-> Infiniti
  47. knock sensor harness question
  48. How hard to replace an alternator?
  49. Door Locks
  50. Is this guy serious?
  51. tranny swap or 4th gen?
  52. K&N intakes
  53. Throttle position sensor?
  54. videos?
  55. summer time oil
  56. Tire size change - gas mileage
  57. Inside tire thread wear
  58. body kits
  59. Difference in Short Shifter?
  60. Steering Rack Question
  61. Help? Car dies after 8 miles, cools, restarts.
  62. Steering wheel tilt question
  63. Struts!!!!!!
  64. Calipers
  65. Another Fng
  66. Anyone got a good lead on 92-94 SE rear caliper rebuild kits?
  67. Trunk Lever
  68. Gas smell
  69. 300zx Barke Upgrade
  70. Ground kits
  71. The ARC-X
  72. Cya Guys
  73. sprint spring colors
  74. Bucking / Stalling
  75. Gathering interest in a VE UDP group deal....
  76. Cai arrived today!
  77. Rear Defroster
  78. Squealing Noise when turning on AC/ Underdrive PULLEY
  79. Main Steepdo Dimmer
  80. Motors
  81. Transmission Diagnostic Codes
  82. player cant find cd?
  83. antenna question
  84. Staying in the family!
  85. got my max running finally
  86. tires squeel on turns
  87. wire in trunk
  88. click clack vrooooooooooom
  89. Carpet Help
  90. Buying new shocks/struts
  91. vg turbo
  92. 90915-yzza2
  93. Do I need to replace Ball Joints in pairs?
  94. random maxima questions.....
  95. knock sensor resistor by-pass
  96. Rims for 3rd gen for sale, LQQK
  97. Engine Type
  98. what kind of paint
  99. Wheres the tube by the egr?
  100. Window Motor?
  101. Question with Rims?
  102. Where is the Feul Filter?
  103. Best Gear Oil for 92 SE?
  104. Addco Sway Bars
  105. i cant post pics!
  106. help out please thanks!
  107. Knock Sensor Location - 94 SE DOHC
  108. interchangable parts?
  109. Brake time
  110. Reset ECU
  111. moon roof inner panel off track
  112. caliper emergency
  113. Transmission Again
  114. My Max is a Dog!
  115. Transmission Pressure seal
  116. colder a/c
  117. Max new with questions
  118. So I finally got them!!! (pics)
  119. 90 max engine rebuild
  120. ECU placement in Australian Max
  121. Power Window Problems
  122. Craig/others... stock alarm crap inside
  123. Overheating, then fine?
  124. bleeding brakes
  125. Suspension Product search
  126. My Car Has The Shakes.
  127. Goo gone...
  128. Car wont start
  129. How to bleed an ABS system??
  130. need info:intermittent fuel pump prob 92 SE
  131. Bose Experts, need help!
  132. grinding sound on light acceleration
  133. Problem when accellerating
  134. Coil pack question
  135. UK Corners
  136. timing degrees?
  137. Clacking/Popping sound with Steering?
  138. Help!!! I have donar car for tranny swap(auto to manual)
  139. Engine Stalling
  140. Getting rid of motorized seatbelts?
  141. Matt93SE-I need your help...pls!!!
  142. click click
  143. Front anti roll bar
  144. Rough Idle and Hesitation
  145. Overdrive goes in and out! HELP!!
  146. venom vs. jim wolf tech
  147. How do I find out if my 1992 Maxima SE has ABS?
  148. Advise on rear strut oil???
  149. Window Switch Wiring Diagram
  150. Massive Car Problems
  151. question on throw out bearing (release bearing).
  152. disable security system in 1990 maxima?
  153. ebay fstb
  154. Grounds????
  155. E36 light question
  156. powder coating
  157. LCD for Climate Controls is out during the day and only works some at night HELP?
  158. goodbye
  159. 4th and 5th Gen Wheels
  160. Looking at a 1991 Maxima
  161. Turn Signal Flasher
  162. Easy Question: Center Cap Differences
  163. Suspension Creaking
  164. Speedometer Problems... continued
  165. a small write up on air fuel gauge
  166. door lock relay
  167. Remote Starter?
  168. Vibration at low rpm
  169. master cylinder
  170. Blowing fuses?
  171. wheres the ECU on a 90 GXE????
  172. changing ATF fluid
  173. Bad Ground?
  174. 91 maxima loud engine noise
  175. corroded VTC solenoid
  176. strut bar...stuck bolt!
  177. post
  178. I'm ****ed as hell. F'd up JDM engine
  179. Where to buy Sway Bars at?
  180. overdrive and comfort shift
  181. Sunroof Visor
  182. repairing cracks in paint
  183. need information on ve timing
  184. wheel/suspension question
  185. air ride install on 94 gxe
  186. How interchangable are 5 spd trannys?
  187. Brake pad fitting problem
  188. Insight on '93 RX-7 rims
  189. fuel guage
  190. creatin bimmer headlight wire harness w/relay
  191. what size are door speakers?
  192. pcv valve question?
  193. 89-94 camber kit
  194. Light Switch
  195. Exhaust Manifold Replacment
  196. loud exhaust
  197. VE TURBO POWER! pic
  198. Stalling, no power --- RESOLVED!!!
  199. Got Y-Pipe on GXE.. Now what...
  200. anybody know what this is?
  201. Interlock Relay on M/T models only???
  202. need help finding a fin
  203. a/c recharge
  204. spark plugs the culprit?
  205. keypad code
  206. How long should the rad fans stay on?
  207. for all that have a chip
  208. Key Cut Codes
  209. Replaced Thermostat...Temp running low
  210. 5sps swap write up
  211. My driverside outside door lock...
  212. tire size
  213. does the 93 max have a factory alarm? if so, how to disable it?
  214. continuing starter problems
  215. Cant find door codes
  216. Lifters
  217. upgraded wire harness for e36 lights...
  218. hood
  219. Water Pump Removal
  220. a small question...
  221. Door Lock Timer
  222. Help on Keyless entry!
  223. Alternator charging amps are low?
  224. Light Probelms..?
  225. how many watts e36 headlight?
  226. Are performance struts recomended with lowering springs?
  227. Wrecked My Car!
  228. 91 SE - VG30E: Recommended Spark Plugs??
  229. High Intensity Discharge lights
  230. Non-Noob Problem - Electrical
  231. y-pipe and acceleration
  232. Ball joint replacement
  233. Weird Clunk Noise when shift is released
  234. Need help with headlight install...
  235. 1994 Headliner - Bad Shape
  236. o2 wire at ecu
  237. eratic idling\ running rich
  238. Help!! automatic locks...
  239. marginal alternator cause stalling??
  240. maf location with turbo
  241. New Project Car
  242. Losing Freon
  243. Emission Problems
  244. Need Expert Advice
  245. Auto Trans will not shift 2-3
  246. STICKY Subject
  247. Look what I "borrowed" from a parts car..
  248. bad shocks?
  249. clunk clunk from front passenger side..
  250. My engine bay
