View Full Version : 3rd Generation Maxima (1989-1994)
  1. Gauge question
  2. Making your own hid in E36?
  3. Gound kit again
  4. tran cooler lines
  5. Brake system is driving me crazy......
  6. Different rims Yay or Nay?
  7. Need to find a front engine mount
  8. Smoked headlight cover
  9. what is a Tranny cooler someone please tell me
  10. hid kit
  11. Manual trany not going into gear.
  12. GReddy SP2 catback exhaust...interest?
  13. Who on here has Sensa-trac struts on a lowered maxi?
  14. will this fit on my 90 max
  15. Just got my hands on a black 93 SE but....
  16. speedometer problem
  17. Car Pics!!! (Finally Up)
  18. Lame Discovery:(
  19. Windows stuck...all of them
  20. search doesn't work, so here goes..
  21. help
  22. rear window visor
  23. Rubber window trim
  24. seat cushion/foam replacement...
  25. pacesetter headers
  26. RPM problem
  27. 93 SE brake pad suggestions
  28. Attention fellow Maxima and other Nissan owners......
  29. Finally got pics of all of my mods
  30. No more MIA
  31. VTC Clacking Crew Sign In
  32. Not just your ordinary Power/Comfort Switch question.
  33. New wheels finely fit, lookin fly!
  34. 1990 a couple of cheap parts
  35. 92 SE Guages working intermittently- Help please..
  36. a fuel injector problem?(kinda long)
  37. Automatic tranny- weird sound arount 2k under light load
  38. A/T or performance issue?
  39. y-pipe question
  40. 97 bose head unit in 92 SE??
  41. Is It worth buying an ATX maxima?
  42. Is this car worth salvaging?
  43. heater not working
  44. Bad Slave Cylinder or Clutch/Flywheel/Pressure Plate
  45. my rear seal done gone bad
  46. Trans Cooler..
  47. Which alarm system to get?
  48. Loud clicking noise on 91se auto
  49. Horray! my first mod just came
  50. antenna mast question (real quick)
  51. Even another Bose Question....
  52. Stillen body kit question
  53. bose stereo question....rerouting wires from amp
  54. anyone change the axle seal on their max?
  55. How many of my VE fellows are running N20?
  56. Jerk Problem! And some Questions
  57. Replace these? Steering rack bushings and inner/outer tie rods
  58. Coolant dilemma
  59. advice on locks
  60. Stainless Steel Brake Lines
  61. Necessay to replace control arms w/.......
  62. Car broken into! PISD OFF I WANT TO VENT
  63. AE Shiftknob Crew Sign In
  64. fastest 0-60 for vg auto
  65. Service manuals
  66. SE,GLE, or GLX?
  67. Umm haha. I just could not resist this ebay/ot post
  68. Speed Sensor Question
  69. 9004 to 9007 conversion write ups
  70. Shifter Bushings
  71. A Maxima Newb
  72. Window regulator going?
  73. Transmission problems
  74. back to the org! Wanted to say hi NEW PICS
  75. Headlights HELP PLEASE
  76. easy to remove rotor on a vg 90 max
  77. bad smoking after injector change??
  78. Messed up the Max's suspension...
  79. Check it out! TRUE or falSE?
  80. How to tint or smoke clear corners
  81. cold air intake adaptor
  82. 5 speed swap and neutral saftey switch rewire
  83. power steering removal question
  84. A few rebuild questions.
  85. 93se Tranny Problem
  86. I have the catalytic converter off -is it bad?
  87. Urgent help needed please
  88. Converted to VE power
  89. Fack!! I Hate My Car It Should Die!!!
  90. Power Window Switch / Wiring Chart?
  91. Pulling Engine on a 1990 Maxima
  92. Where they put the dipstick!
  93. cold air intake
  94. 300zx brakes in 16x6.5 wheels
  95. cooling system problem
  96. seat belt
  97. Some crazy Summer projects done
  98. Bose CD player compatibility
  99. sunroof in 89 maxima se
  100. Just makin sure, these rims will fit
  101. Location of dome light and parking light wires (alarm install)
  102. 3rd Gen Cartoon
  103. Factory Sunroof Problem in 3rd Gen SE
  104. Parking brake cover
  105. help look 4 a carbon fiber dask kit
  106. high expenses for Maxima
  107. disc brakes
  108. Need a knock sensor...
  109. 5-speed lubrication help
  110. What auto tranny mode do you use all the time?
  111. putting
  112. Gas tank to trunk clearance
  113. 93 GXE drum brake locking
  114. Where to Purchase Used Auto Tranny from Japan
  115. Does anyone tune-up their own car?......
  116. Fastest Ve
  117. ABS Sensor Locations????
  118. 300zx engine question
  119. 93 SE hiccuping and stalling at idle
  120. 1992-89 3.0l MAXIMA Air flow meter
  121. firewall?
  122. White stuff inside distributor cap?
  123. Easiest way to get axle mount(?) off?
  124. Are there any 'charger for a 94 se?
  125. Life of an engine??/
  126. I Think It's Dead!
  127. oil in cylinder
  128. Low fuel light always on
  129. Absolute cheapest place to get tune up parts?
  130. Engine Mounts/wheel Sensor Circuit
  131. trans
  132. New Kid n da Heezie:)
  133. Valves on pistons - quick TB question.
  134. 94 se suspension vs 93 gxe suspension
  135. How to remove backseat?
  136. Tube underneath EGR? help identify
  137. Antifreeze drain plugs
  138. Crank bearings part number
  139. Engine Wont start
  140. Y-pipes, short shifters & hot air...
  141. My Accident....Pics
  142. Pic between these two 5th gen Rims
  143. Gts Headlight cover question
  144. So i may have found my 5.5 gen...
  145. Reverse Light Switch
  146. Original 2000 17" Audi TT rims on a 3rd
  147. Bmw Headlights
  148. Chrome Rocker panel stick ons(stickers)
  149. Wierd exhaust leak
  150. Exhaust leak-manifold??
  151. replacing clutch slave and master
  152. craigs taillight re-wire
  153. Auto tranny woes...
  154. Newbie Tutorial
  155. Overheating
  156. Today is a sad day... My Max was stolen!
  157. what kind of body kit is this?
  158. loose steering
  159. Front end creaking on 94 GXE
  160. 94 Max Headliner
  161. eBay "20hp mod" BS?
  162. 91 - Transaxle/diff problem?
  163. cheap name brand fuel injectors???
  164. Water leaking from engine bay? (long)
  165. Shaky wheel
  166. Cig Lighter not working.
  167. Lowering Springs - What's the best?
  168. Getting 10 more years out of a Max
  169. wsp y pipe heat shield issue
  170. 93SE w/18" Nissan Murano Wheel. Finally.
  171. High Output Altenator
  172. My bulbs are weak.....need some suggestions
  173. anyone ever do a VQ swap?
  174. Good Pricing for swap?
  175. new weridness
  176. blinking air bag light
  177. Fog lights
  178. Max was stolen
  179. Replace Cloth Seat Upholstry
  180. Lose shifter and a list ??
  181. ECU question for 89 maxima
  182. odometer question.
  183. rims
  184. 5-Speed Swap Complete - 1 PITA Problem Though
  185. steering rack woes
  186. Egr
  187. Fixed my broken Moonroof shade!
  188. stock rim weight
  189. Yet another speedometer question...
  190. Se..gxe..4dsc?
  191. water pum
  192. I'm New and have a question
  193. Water leakage?!
  194. Antenna Questiono
  195. Timing Belt Blues - Epilogue
  196. Droopy door hinges
  197. WTH new ignition still running rich
  198. cheapo lowering springs
  199. Holey Situation: Radiator Leak
  200. 1991 a/c problem
  201. Strut Rod Bushing
  202. I weighed in at 3680 weight reduction
  203. My Fuel Injectors Suck!
  204. What OCTANE gas do U put in your 3rd Gen
  205. Is there a separate switch for turn signals
  206. Exhaust Question
  207. Best shocks for under 380$
  208. streamling the max
  209. Check out my window switch refab plan.....
  210. Painted engine bay pics
  211. Hey Ya'll
  212. tokico
  213. neon lights
  214. Well The Dream Is Over.....
  215. fill hole on 92 5 spd??
  216. Beater
  217. front caliper, rear caliper..diff?
  218. Replacing the heater core - DIY?
  219. Strut tower torque specs?
  220. 89 manual tranny overhaul?
  221. Rotor Question
  222. pricing...
  223. Cheap Gen 6 Rims???
  224. Valve Gasket\ Seal
  225. Weird flashing lights problem
  226. Bose radio/stereo light out
  227. How many O2 sensors are on the 94 maxima?
  228. How hard is it to fix front motor mount
  229. front speaker mount to replace bose
  230. Normal when cold, sluggish when warm
  231. auto shifter problem
  232. Door locks are possessed......
  233. radiator fans falling
  234. Electrical problems
  235. Fuel Leakage?
  236. No high beam lights
  237. Bose Radio Interference
  238. Sound Diagnosis
  239. new car need some advice
  240. i want more power...
  241. car stalling, again
  242. Sonar Supension System
  243. strange headlight issue
  244. '90 auto trans -> annoying whine
  245. Look! First 92 SE on 22's.
  246. I need help like so bad!!!
  247. Bad fuel injectors worse when warm?
  248. Power Steering hose replacement! *drip*
  249. Window Switches
  250. drive shaft boots
