- Wrecked!!!!!
- anyone interested in precut E36 lights?
- 2 questions
- Anyone have access to VE Bin files or fuel maps?
- Painting Bumper and RUST Bubbles
- Our "cutting out" problems
- new leather seats....made by you.
- Digital Climate Control lighting???
- Ahh! they butchered my car
- "maxima" door sills
- quick ?
- Turn signal wiring mod
- reverse gear
- Some new pics...
- Engine Rebuild or WHAT?
- Rough idle-wrong air filter??
- Dash temp gauge
- pathfinder intake
- Gotta get some struts!!!!!!!!!!!!
- Nismo Stuff
- brakes?
- auto door locks
- Nissan performance chips?
- Fuse box problem
- Gauges
- Koni's or tokico's?
- bad/old knock sensor
- Painting tips by awsm66.
- finaly got the old VE on the dyno with soso results
- Another possible mod: Hyper Voltage stabilizer?
- Coil Spring Compressor
- "some" info on automotive painting
- Electrical question - wiring from the dimmer
- how do i fix my trunk switch
- Radio wont work
- Temp Sensor (need advice)
- Hahah Irony.
- Brake Squeal
- cup holder?
- smells like gas
- gxe 5speed sign in
- I Failed Emmissions!
- Warpspeed problems
- Speed Rating for GXE Tires
- Pic request: RH c5's on 3rd gen
- lost my keys
- Shift Question?
- quick noobie help
- How much $
- Air Conditioning Back Light
- differance between auto and manual ECUs?
- Rear Taillights Cover?
- 93 accord intake on my max
- maxima spoiler
- maxima intake / tails
- custom stuff
- Should coolant reserve be pretty much full?
- Can you run N20 with the stock ECU?
- Hard starting.
- se rims: 89-91 vs. 92-94
- Bad Day (kind of long)
- help changing stock disc brakes
- Slid out in rain, hit the curb
- I have a leak..
- Fuel Injector question heavy hesitaion.
- internals question
- auto 93 to fit auto 89
- heater problems
- Need Help Vet. Guys Only (asap)
- 89 SE w/problems.. list inside.. pls help
- mas air flow meter
- Seeing discharges through a coil pack?
- some questions about Koni's
- well i got a compressor and ....
- Hood vibrations due to hood release latch?
- oil/ clutch probs
- Few Newbie questions
- Climate control Celsius to Fahrenheit
- slight hesitation prob...
- Leaking oil from top of VE engine near knock sensor
- Nonworking Cylinder 3
- code 12 ??
- tuned up, still bad gas mileage
- alternator
- Clutch Problems
- 5 spd swap
- Temp sensor location on a vg
- Tornado gas saver!
- Idle is a little high ???
- 300z oil filter and pan
- Newbie Talk
- Thermostat shot?
- HID Questions
- prepairing for nitrous
- Any Good Ideas or Pics. of Rims
- Whats The Best Intake
- Fuel Pump comes on sometimes... Only when light on Dash turns on... more and pics...
- Transmission!!!!!???
- stupid and childish but....
- E36 Projectors w/Angel Eyes:
- 1 bad injector (i think)
- Advanced timing question....
- VG crank pully..
- Finding factory charcoal paint
- Clutch replacement!?
- Need advice on my Maxima...
- slug in morning and wet
- JTW Performance Cams
- Interior illumination LED conversion done - Pics
- Keyless Entry went out
- asp pulley belts?
- Need Throttle Position Sensor..WTB?
- Need Tranny help/input for a friend
- Leaking Gas !!!! Help
- asp pulley in! sleeve already on it???
- Whats the Diff. In These RL4FO2A / RE4FO2A
- what kind of exhaust to get
- Vg Breathing Issues - How to add some top end
- Radiator suggestions?
- VE engine to VG transmission
- Side Panels
- Final answer on VG knock sensor?
- VTC's disaster!
- Vibrations
- Bad motor mount???
- 92 se
- Few AAC Questions
- interchangable parts
- 93 SE woes continue.... so many questions so little time
- that black thing in the trunk...
- Manual Tranny
- MPG thread
- door locked permanently
- Anyone knowwhere I can get a good cold air intake?
- fuel pump location
- testing parts
- e town 10-02----10-03
- White smoke?????
- smoking- don't know why.
- e36/LED-bulb/resistor question
- i have cold air blowing instead of hot
- VE turbo dynoed....
- no heat
- 5speed swap now no brakes
- My first car accident
- Keyless Entry Installation Prices
- Suction noise coming from hose
- Sudden hesitation problem
- help 5speed rewire
- cleaning the engine bay
- Transmission fluid check
- Motor won't start can somebody help me out please
- Pictures of my car - nice... (warning large pics)
- heater still inop
- E36 lights installed!!!
- I believe that i have faulty VVT Solenoids causing a terrible top end rap in the engi
- Trans drain plug
- with so many diff. sets which e36's to choose
- suspension Q
- 9004 to 9007 conversion complete
- e36 angel eyes - us spec?
- CV boot
- a few upgrades to my car...
- Bad gas mileage
- Washer sprayers pressure
- bimmer headlights
- wear/tear and shift points
- Drivers-side seatbelt Track
- heated sideview mirrors and lighting
- is there a vin decoder
- Digital Dash Dimmer
- 1994 maxima tranny
- Seat belt no retraction ...???
- GXE Fuel Injector Questions
- will knock sensor make car not start?
- Price range for manifold repair
- How to replace or retread a hub bolt?
- Wet Seat
- Ball Joint Replacement.
- anybody had probs w/underdrive pulleys? n/m
- All parts for a manual conversion
- Hi-flow catalytic converter?
- Possible New Body Kits ??
- its starting to get cold
- Window Problems
- racing gears?
- Ball joints question
- 4 wheel disc brakes
- 93 Maxima GXE with Electrical problem?
- Transmission Slip?
- under motor shields
- Window problem
- Skyline Mirrors
- Idle shmidle??
- Nice sounding/looking muffler
- How to get yellow stuff off bmw headlights and bulb ?
- Free 5 Quarts Valvoline MaxLife - $14 rebate
- Maxima 93 Starting Problems
- I got a 92 SE 5-spd. Needs New Motor
- 2 questions, one thread.
- 92 SE Security System Wiring Daigram
- squealing/scraping sound coming from my wheels
- tranny kit?
- Auto Tranny Oil Change?
- How much oil?
- finally got my pics up!
- sprint or intrax?
- Power Switch
- Stupid Plastic Hat
- School bus hit my car......
- Too many minor annoyances to list... seeking advice on where to look
- question for turbo Vg's out there?
- heavy vibration at 45mph and 65 mph
- How to adjust the e-brake cable?
- Rear Strut Cartridge too long
- What's in your manual tranny?
- Need axles!!! Check in here.
- Speedometer doesn't work!!!
- Engine mounts...advice needed badly!!!
- automatic, rattls/knocks shifter in revers...
- Transmission Resistor
- meet the F-IN new guy
- Getting out rusty O2 sensor
- Koni??
- what seats and steering wheels are interchangable
- Where is the PCV valve?
- what leather color to pick ??
- vaccum hose diagram
- fuel pump just quit?
- Fuel injector/ignition harness replacement
- aftermarket audio questions
- Slight 'hesitation' accelerating from idle
- Will a 91 240 Steering wheel fit
- 1991 Maxima AC
- Search is down sorry
- buying parts online...?
- polyurethane?
- proud owner of triplets
- Is this a sign of a bad clutch?
- I'm Out
- what da next best thing after EIBACH PROKIT/SPORTLINE SPRINGS
- Transferring suspension VG to VE
- Drivers Door Lock Problem
- randomly dies...
- 99 y-pipe in a 92 SE?
- Gauge question
- Making your own hid in E36?
- Gound kit again
- tran cooler lines
- Brake system is driving me crazy......
